Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 08-21-2008, 01:36 AM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Impreza GC8 NEED HELP on Ej20g plugs/wiring.
I need help finding homes for these plugs and stuff... i have a JDM 94 wrx motor... i took off the wiring and i thought it would be pretty simple to put them back on... but i cant find where they are suppose to go... i think i plugged all them in.. except these.
Please help me identify them and if u can give me the location on where they go.. THANKS.
1.
2.
3.
4.
5.
6.
7.
CLOSE UP
this is my car so far. gc6 converted to gc8 w/ej20g
azn0boi04 is offline   Reply With Quote
Old 08-21-2008, 09:52 AM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
1. plugs into the ignitor
2. boost solinoid
3. Oxygen sensor
4. plugs into the ignitor
5.
6.
7. MAF
I'll have to get back to you on 5 and 6
Zephyr is offline   Reply With Quote
Old 08-21-2008, 11:09 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
map and purge?
Old 08-21-2008, 04:07 PM   #4
johnny p
Member#: 141232
02 v7sti wagon
signal green
5. BCS.
6. engine harness to 02 sensor plug.
johnny p is offline   Reply With Quote
Old 08-21-2008, 06:44 PM   #5
silentt
Member#: 119995
2004 Outback XT
Peachy
6 looks like the ABS plug.
silentt is offline   Reply With Quote
Old 08-21-2008, 09:50 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
THANK U EVERYONE for all the info... the engine Turns over... but i got no spark tho... i dont know if this is the problem.... but i have 1 plug that is unused... and i dont know what it goes to...
Close up.
Old 08-21-2008, 11:14 PM   #7
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
2. Pressure exchange solenoid
3. Oxygen sensor
5. Wastegate solenoid
6.
7. MAF
Made an edit and added one. Not sure what the grey one is with two wires. If you can post what the wire colors I might be able to help you.
Anything that is on the engine should have a home. Look for what they could plug into. If you have not plugged in the ignitor the car will not get spark. It looks like you have a few items in there from the L that are no longer needed and need to come out of the engine compartment.
Z
Old 08-21-2008, 11:37 PM   #8
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Close up.
That plug looks like one of the plugs for the coil packs
RSmatt is offline   Reply With Quote
Old 08-22-2008, 01:19 AM   #9
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
ill look for the wire color tomorrow.... and also my fuel pump is only getting 4 volts.... and it supose to have 12.... no fuel is pumping throught.. im going to check the wires between the ecu and the pump... does this give me an excuse to upgrade my fuel pump? hha
Old 08-22-2008, 01:21 AM   #10
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Old 08-22-2008, 10:30 AM   #11
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Does the CEL light up when you turn the key to acc.?
Sounds like you may be missing the diode.
Old 08-22-2008, 08:32 PM   #12
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
CEL? whats that... when i turn the key to the ON position... the wipers work and the lights and stuff... but i dont hear the fuel pump, pumpin... u can usually hear a lil buzzing..
Old 08-25-2008, 12:10 PM   #13
RSmatt
Member#: 8039
94 v2 STi RA - RHD
CEL= Check Engine Light
If the cel is not turning on, then your ecu/fuel pump won't turn on.
Old 08-26-2008, 08:30 PM   #14
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah my CEL is on.... along with the oil light...my fuel pump is still not pumping... my ECU has power to it....
Old 08-28-2008, 11:58 AM   #15
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
why wont the ecu work if the CEL is not on?
bugeye-brawler is offline   Reply With Quote
Old 08-28-2008, 01:29 PM   #16
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Sorry, i worded that poorly. If your CEL is not turning on then the ecu is not turning on.
azn0boi04 Are you positive the diode was wired in?
Old 08-28-2008, 02:43 PM   #17
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well i got it started... but a few bugs here and there..my CEL is one... but i think its cuz my O2 sensor isnt plugged in.... cuz i have to buy one....
my car stays on even with the key out...
my temp sensor doesnt work...
and i think my speed and RPMs... gas works tho =).
Need help on fuel pump wiring! powerneedy Subaru Conversions 5 11-20-2008 05:56 PM
EJ20G Merge..need help with some yellow wires xlur8ed Pre-2002 Factory Turbo Powertrain 0 03-25-2008 05:06 PM
$50 JDM EJ20G Plug wires -individual coilpacks supermoose Private 'For Sale' Classifieds 16 10-17-2005 06:51 PM
Need help on plug wires yukon1 Alaskan Impreza Club Forum -- AKIC 10 05-26-2004 10:51 PM
need help on 02RS ecu wiring diagram SFimpreza411 Normally Aspirated Powertrain 8 06-13-2002 10:38 PM
