Welcome to the North American Subaru Impreza Owners Club Friday March 5, 2021
Old 08-16-2020, 12:58 PM   #3201
steve30avs
Member#: 426821
Default TSB work not fully covered
Make: 2016 WRX CVT
Mileage: 74000km (46000mi)
Time Out Of Use: 2 weeks, can't drive for more than 30 mins at a time
Problem And Likely Cause: CVT fluid seepage, low power coming from a stop, lurching. TSB 16-103-16R should fix this.
Modifications: Radio
Submitted For Warranty Work (Yes/No): Yes
Reason Given For Denial: Work is covered, but CVT fluid not covered under warranty, despite needing to be drained to do the work
Your Story: I've noticed some fluid seepage in the transmission, similar to what's in TSB 16-103-16R. The car starts to lose power after driving for over 30 mins, which I saw on here could point to torque converter issues (lack of fluid from the seepage maybe).
I brought it into my dealer and they agreed that this issue fell under the TSB and that the work would be done under warranty.
6 hours later, on the phone, they mentioned that 'oh yeah, you'll need to pay $350 CDN for the CVT fluid when we reopen it'.
This doesn't seem right to me, as they would obviously have to drain the fluid to do the resealing work, so you think it would be covered.
On the WRX CVT Facebook group, most responses have said this is indeed the dealer trying to rip me off, but the other Canadian also mentioned he had the same issue and had to pay, in another province too.
Any thoughts?
steve30avs is offline   Reply With Quote
Old 08-16-2020, 01:06 PM   #3202
Supraru
Member#: 23313
99' 2.5Rs
black
Originally Posted by steve30avs View Post
Make: 2016 WRX CVT
Any thoughts?
I’m sure Canada does some things different but in the USA if we were performing a tsb and was done as a warranty job everything is covered.
Supraru is offline   Reply With Quote
Old 01-22-2021, 11:49 PM   #3203
Rtec94
Member#: 514836
2019 Subaru Wrx STI
Red
Default Warranty issues
I curious on what i should expect in the coming days. Just sent my 2019 sti to the dealership. At 20k miles it looks like i either spun a bearing or broke a rod. Never raced, daily driven, but i have an aos and an intake. So i suspect it might be a battle to have this covered under warranty.
Rtec94 is offline   Reply With Quote
Old 01-23-2021, 08:50 AM   #3204
Supraru
Member#: 23313
99' 2.5Rs
black
One of two things here. Simply having an intake on your car should deny you. Subarus tuning from the factory when you throw on an intake makes it run lean. So you either had the intake on and didn’t do your research to realize you need a tune too or you also have a tune and aren’t admitting it. Either way you’re probably screwed. Maybe you’ll get lucky but I doubt it.
Old 01-23-2021, 05:47 PM   #3205
Rtec94
Member#: 514836
2019 Subaru Wrx STI
Red
No i had an AP on it, cant run intake without it. Talked to the dealership, and they seem pretty understanding. We will see how it plays out. I was honest with the service rep, and i think that went a long way.
Old 01-23-2021, 06:02 PM   #3206
Supraru
Member#: 23313
99' 2.5Rs
black
So then why are you lying on here? You said you had an AOS and intake. Nothing of a tune. If your tune was on there you have to call in to Subaru to verify your cid and cvn numbers. If it doesn’t match more than likely your going to be denied. If you removed the tune you’re clearly hiding something and either way a a mod report gets filled out.. Like I said originally maybe you get lucky and the dealership doesn’t care. If you came to my dealer you’d probably be denied.
Old 01-29-2021, 08:24 PM   #3207
Rtec94
Member#: 514836
2019 Subaru Wrx STI
Red
Default Supraru your funny
Why am i lying on here?!? You obviously have something wedged firmly up your butt. I asked some simple questions and got alot of great answers none of which came from you. I didnt lie to the forum nor to the dealership. Im sorry im not obviously as intelligent when it comes to subarus as you are. Its my first 4 banger and first turbo car ever. Now granted im pretty old at 41. But your god complex can go. The dealership is going to warranty the engine. And i made it very clear how thankful i was about it. It will have the stock parts put back on and will keep it that way knowing what i do now about how temperamental the engines are now. Hope you have a great day, and please see your proctologist...
Old 01-29-2021, 08:49 PM   #3208
Supraru
Member#: 23313
99' 2.5Rs
black
While you were making it sound like you baby the car you conveniently left out you were tuned. Hence my “lying on here” comment. You clearly left it out for a reason because clearly you have an intake and know it needs to be tuned. So why did you leave that part out? I assumed because you wanted to sound like you were innocent in the matter.
Old 02-07-2021, 12:45 PM   #3209
leblancc_99
Member#: 61520
2000 impreza
Make: 2017 Legacy
Mileage:51000 miles
Time Out Of Use: 6 days
Problem And Likely Cause: Clutch disk worn out
Modifications:
Reason Given For Denial: Clutch is a wear item, pilot bearing not covered under drivetrain warranty
Your Story: At first I suspected an oil leak from the engine or the gearbox to the clutch compartment but the picture showed that the clutch was 100% dry and not contaminated.
Turns out that the clutch disk was worn out. The technical dvisor tells me that the traction control of the Gen6 slips the clutch and it is the reason why he clutch wears faster
I have many manual cars in my life and I never have to change a clutch before 100k miles
anybody ears of that story before?
leblancc_99 is offline   Reply With Quote
Old 02-19-2021, 09:33 PM   #3210
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
What? So the traction control operates the clutch pedal when activated...?
Originally Posted by leblancc_99 View Post
Make: 2017 Legacy
Mileage:51000 miles
Modifications:
murrdogg24 is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 143 07-23-2020 07:21 AM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 58 10-19-2019 05:03 PM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 97 09-27-2019 01:46 PM
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 146 03-02-2019 01:31 PM
Trouble/Warranty Denial Report Thread: Interior North Ursalia Warranty Issues & SOA Problems 71 11-14-2018 09:18 AM
