Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 11-18-2006, 01:22 AM   #1
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
2020 Outback - White
Default HOW TO: Horn Hookup and Turn Signal Auto Canceling on Aftermarket Wheel *NRG Setup*
Well I have looked around and information is all over scattered in pieces.
Everyone have their own way of doing Horn and Signal on Aftermarket Steering wheel and Hub.
This is In My Opinion is the easiest and SAFEST hookup of Horn and Auto Turn Signal Canceling on my 2005 STI.
Products Used:
1. NRG-F009 Steering Wheel
2. NRG SRK-250B Black QUICK RELEASE Kit Generation 2.5
3. NRG SRK-100H Short Hub
Here we go.
Horn Hookup:
All you need is 1 feet of 8 Gauge Wire and some zip ties.
You will find a Screw right under the steering column.
You will use that screw to hold the Red wire (brush) in place and also use couple Zip ties to set it in proper location.
When Hub is installed red wire have to be touching the Copper Ring in the back of the Hub.
You will connect GREEN/RED wire to your 8Gauge red wire that is touching the Hub. If in doubt test this green/red wire
by touching ground (metal steering column) - Your horn will signal with your ignition OFF.
Everything else is pretty straight forward. Here is some pictures.
Auto Turn Signal Canceling:
You Will REUSE the center insert of your Clock spring. You can take it out by prying off four tabs that holds whole Clock Spring together.
The Turn Canceling piece is little too large in diameter so you will have to wrap inside of the NRG hub with electrical tape.
Use about 10-15 full turns and check periodically how the Canceling piece fits. Once it fits snug I used a little bit of 3M trim adhesive glue
to make sure the piece stays in place and put some tape over it.
Take a note from the picture how it goes onto the hub.
Now Install your Hub, Quick Release and Wheel and ENJOY the Luxury of HORN and Auto Canceling Turn Signals. (and just forget about Cruise Control)
ProdriveRex is offline   Reply With Quote
Old 11-18-2006, 01:26 AM   #2
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
Finished product
Old 11-18-2006, 01:49 AM   #3
ockS
Member#: 45438
2005 Subaru "You,
outside, now."
Wow. Looks real nice. Great write up.
ockS is offline   Reply With Quote
Old 12-07-2006, 02:01 PM   #4
Aarron_M
Member#: 68210
2014 Impreza WRX STI
Very good writeup.
Aarron_M is offline   Reply With Quote
Old 12-07-2006, 05:47 PM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I spy 02-03 WRX seats in the STi
djerickd is offline   Reply With Quote
Old 12-07-2006, 08:50 PM   #6
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
daily driver without airbags :banghead:
AbACUZ is offline   Reply With Quote
Old 12-07-2006, 10:28 PM   #7
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
I really dont care about airbags to be honest with you. but i am sure you have many reasons why we have em.... I just dont care
Old 12-07-2006, 10:43 PM   #8
ColesSTi
Member#: 99205
2005 Impreza WRX
You need racing seats and two five point harness and and something to tie
them to then you will just have a different safety setup. I plan on asking for
a steering wheel setup for Christmas.
ColesSTi is offline   Reply With Quote
Old 12-07-2006, 10:50 PM   #9
mikeyc
Member#: 32338
2012 WRX
You think running 5 points without a cage is safer than not having airbags?!
mikeyc is offline   Reply With Quote
Old 12-07-2006, 11:11 PM   #10
dnaL0R
Member#: 109472
2006 shirokuro_STI
what is the green/red wire you are talking about that goes to the other end of the red 8 gauge wire? is it found inside the steering column? or did it come with your "package"
dnaL0R is offline   Reply With Quote
Old 12-07-2006, 11:28 PM   #11
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
Its the Horn Wire. If that wire sees Ground your Horn will honk. it goes into Clock spring.
Old 12-07-2006, 11:29 PM   #12
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
And this is the update.
I ditched that weird shaped leather 009 wheel for 012 in Suede with red stiching. I couldnt get used to that weird shape. I guess I like my wheel Round.
Old 12-08-2006, 12:41 AM   #13
ColesSTi
Member#: 99205
2005 Impreza WRX
Petter, What part number is that wheel?
Old 12-08-2006, 12:56 AM   #14
WgnWheel
Member#: 63605
04 Wrx Wgn TimeAtk
10 Golf TDI, 08 Stang GT
That wheel is the st-012s (s for suede).
http://www.surgestreetshop.com/shop/...oducts_id=1547
WgnWheel is offline   Reply With Quote
Old 12-08-2006, 01:15 AM   #15
WRXDriftR
Member#: 65065
2004 EJ205 STi
2007 Forester STi
that suede wheel looks GREAT!
WRXDriftR is offline   Reply With Quote
Old 12-08-2006, 01:41 AM   #16
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
And you have to make sure they order the right one for ya. because part numbers for Black and Red stiching some how the same. I got one with black stiching but NRG was nice enough to send me replacement free of charge and included Prepaid postage to return the incorrect one.
Old 12-08-2006, 02:10 AM   #17
ColesSTi
Member#: 99205
2005 Impreza WRX
What made you get that wheel over the one with two buttons? I was thinking left for 2 stage boost controller right for the 3 hellas.
Old 12-08-2006, 10:22 AM   #18
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
I just like my Horn to be in the middle. Plus I like to keep my hand on the place where the button is, sometimes when I drive. And I am sure I would accidentaly hit it. And what if you are turning and you need to use your Hellas, you might hit your boost button instead of Horn.
Old 12-08-2006, 06:09 PM   #19
ColesSTi
Member#: 99205
2005 Impreza WRX
It wouldn't be much higher boost just good enough to get threw some of my
gears to help the drive train. Good point though. On your old wheel you
touched on you had some trouble seeing your cluster is this wheel any
better? Reason I ask is, I have a auto meter dual cluster pods.
Old 12-08-2006, 06:29 PM   #20
ProdriveRex
Member#: 53921
2019 F150 EB - Grey
i can see cluster better with round wheel.
Old 12-10-2006, 03:49 PM   #21
dnaL0R
Member#: 109472
2006 shirokuro_STI
ok im trying to put in my steering wheel in, but i can't make it work... better yet, i dont know wtf im doing... i got the steering wheel off half way, i just have too many harnesses thats holding the wheel in still [it's basically dangling off]... and also, whish piece is the clockspring or whatever... there are two black piece inside, one with the yellow sticker on it and another one right behind that... which one do i need to retain? or do i just get rid of all of them? can i just cut off all the harnesses? thnx in advance
Old 12-10-2006, 04:31 PM   #22
njskatchmo
Member#: 94618
2002 Bugeye
Stick the prodrive emblem in teh center or get a prodrive shift knob, it is very similar to whats there now and will match the knob, but looks good.
njskatchmo is offline   Reply With Quote
Old 12-10-2006, 05:10 PM   #23
living4surf
Member#: 85216
great write up i will geting the same wheel as your first one soon
living4surf is offline   Reply With Quote
Old 12-10-2006, 11:44 PM   #24
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
There must be some other place to mount the cruise control lever...
Counterfit is offline   Reply With Quote
Old 04-05-2012, 02:48 AM   #25
Razlin
Member#: 146635
06 WRX STI
Satin White Pearl +
^ nope forget about it!
Razlin is offline   Reply With Quote
HOW TO: Horn Hookup and Turn Signal Auto Canceling on Aftermarket Wheel *NRG Setup* ProdriveRex North West Impreza Club Forum -- NWIC 23 12-13-2020 04:36 PM
How to turn off auto-learn on 04 sti 04sti the famlfax Open Source Reflashes 6 06-04-2008 02:03 AM
Dash Swap = Turn signal/auto locks problem (help) Axion541 Subaru Conversions 3 09-23-2006 12:02 PM
Anyone experience coilover spring rubbing on aftermarket wheel/tire setups? caterpill Tire & Wheel 6 03-24-2006 06:01 AM
headlights go out whenever turn signal switch is on aesthetect Electrical & Lighting 3 08-30-2005 05:12 PM
