Welcome to the North American Subaru Impreza Owners Club Wednesday March 3, 2021
Old 01-21-2019, 03:28 PM   #3151
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Looks great. Is that strut brace custom?
T-37 is offline   Reply With Quote
Old 01-24-2019, 01:10 PM   #3152
ItzNotLuCk
Member#: 496896
Looks really nice
ItzNotLuCk is offline   Reply With Quote
Old 01-24-2019, 06:18 PM   #3153
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Basically his car is custom, LOL. Go make a bag of popcorn and get ready for a LONG good read!!! Seriously go look at his build thread for that car.
Scuby04STi is offline   Reply With Quote
Old 01-25-2019, 11:18 AM   #3154
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Yeah, I found it after posting that. I had subscribed to his thread a while back but forgot about that.
Old 03-29-2019, 09:32 AM   #3155
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Just thought I'd share a few pics of the harness Brian at IWire made for me to clean up the engine bay. All sheathed in DR-25 and heat shrink boots and all connectors are labeled. I'm going rotated turbo and rotated intake so Brian mocked it up for me to show how to route it. I'll post detailed pics of the harness later tonight.
Turpid Porpoise is offline   Reply With Quote
Old 04-01-2019, 03:27 PM   #3156
batesd1994
Member#: 461268
Looks nice. Gonna have to talk to them about that!
batesd1994 is offline   Reply With Quote
Old 10-18-2019, 09:05 PM   #3157
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Bump for more custom engine bays!!! Let's keep this one alive
master c is offline   Reply With Quote
Old 10-07-2020, 04:05 PM   #3158
Smurftastic
Member#: 243697
2002 TOPSCOOB031
HighwaystarGarage
Alright, posting here to keep the thread alive. I have a relatively aggressive engine bay tuck and shave job, but about to full send the bastard. Will provide updates.
Smurftastic is online now   Reply With Quote
Old 10-20-2020, 11:16 AM   #3159
skwrl
Member#: 359878
Originally Posted by remski View Post
My god that looks clean.
Short of rerouting all the wiring and a full breakdown, is there a way to clean up all the engine bay wires?
I've done all custom cables for my PC, wondering if there's sleeving or something similar we can do for all the wires to at least freshen it up a bit? It's frayed, falling apart, and in parts inside wires are showing through.
skwrl is offline   Reply With Quote
Old 10-20-2020, 01:09 PM   #3160
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Any place you have exposed wire element showing through the insulation, or frayed wire ends you should absolutely replace those wires or connectors. You risk a short and a fire if something were to contact a live wire.
As for tucking or cleaning it up, that should come secondary to making it safe. Get on ebay or find a partout and get a replacement for the section of harness you need (or just buy new OEM.)
For sheathing, check out DEI products, they have plenty of wiring products that should be safe for underhood use.
Old 10-20-2020, 01:23 PM   #3161
skwrl
Member#: 359878
Oops I meant the wrapping material on the harness has worn through showing the wires, but not the wires themselves.
Anything I could use or should stick with actual products for safety?
Old 10-20-2020, 10:37 PM   #3162
iceman967
Member#: 275798
2005 2.61L WRX
Ridiculous Red Metallic
I used some split loom for it. Heat shrunk ends. Hopefully the photo comes through as well.
iceman967 is offline   Reply With Quote
Old 01-17-2021, 06:59 PM   #3163
Smurftastic
Member#: 243697
2002 TOPSCOOB031
HighwaystarGarage
Okay, elbow deep in the delete project with a box of Chase Bays stuff.
I deleted AC completely - how are people plugging the AC holes on the firewall? Welding a piece of metal over it is always an option, but I assume there are other methods for plugging.
Old 01-17-2021, 10:09 PM   #3164
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I just put fire tape over those, I have done mostly practical deleting so never waned to jump down the "fill/weld" rabbit hole. I will some day but for now its safe but ugly.
If I was going all in I would be filling every hole that is unused and filling all the gaps, not sure what your goal is for a end result.
Old 01-24-2021, 09:56 AM   #3165
Smurftastic
Member#: 243697
2002 TOPSCOOB031
HighwaystarGarage
Updates and question
Updates
AC gone
ABS, brake boost, hardlines gone
Power ran behind firewall, up quarterpanel to fuse box in the quarterpanel
Soon
Metal plate over AC plug in firewall
New wiring ducting in driver side quarterpanel
Question
* For ABS module plug by intake, plan is to cut back the wiring harness and simply pull back the ABS module stuff into the passenger quarter, instead of cutting it out. Who else has done this?
Old 02-23-2021, 05:59 PM   #3166
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Updates
AC gone
Soon
Question
I de-pinned and removed all of the wiring from my front harness when I did my ABS delete. Saves a ton of wiring from dangling around.
Old 03-01-2021, 09:50 AM   #3167
Smurftastic
Member#: 243697
2002 TOPSCOOB031
HighwaystarGarage
So after weeks of rerouting wiring and a ridiculous amount of sanding, I put the first base coat down this weekend. I have a ways to go in the paint department, but it feels so good to finally reach that step.
I've had a partially shaved bay before, but finally decided to get more serious with it. ABS, proportional valve, and AC are all gone now.
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 10:12 AM
spilled oil in engine bay bugeye4life Newbies & FAQs 8 06-03-2010 04:51 PM
07 ABS actuator and all Engine bay lines TraviST185 Suspension/Brakes/Handling 1 04-08-2009 09:38 AM
06 STi attempted wire tuck, polished manifold, samco hoeses, baller custom intake reallyslow Member's Car Gallery 34 06-19-2007 02:11 PM
Wiring TT and keeping engine kill feature sssp Electrical & Lighting 2 08-16-2004 12:58 AM
