Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 06-17-2009, 12:15 PM   #26
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Originally Posted by 02wrxRally View Post
and if your used 02 wrx didn't have that bag in the trunk? I looked on subarugenuineparts and found a part called "tow hook", but the diagram shows it's the rear. There's another part called "hook", but there's no diagram for it. Is that it? Is there a reason the stock one won't work for track days? If not, I'm just going to paint them red and call it done (once I hunt down a front, that is).
No clue on the stock front hook part number. Search around it should turn up in either the forums or a parts catalog. It might even be listed under "tool kit" if they don't sell it separately. My kit had a lug wrench, the tow hook, a screwdriver and something else I can't recall.
I think you should still be OK with the stocker. The reason these bigger hooks are popular is that most tracks will come get you with a tow strap and those won't fit through the stock hook. They would have to have a hook or clip of some sort on their strap to hook in.
SonicWRX is offline   Reply With Quote
Old 06-17-2009, 01:29 PM   #27
Admission_Regret
Member#: 131246
2004 STi Snow White
eighteen x ten + thirty
I probably would have used a Button head cap screw in stainless, not bad though, good idea!
Admission_Regret is offline   Reply With Quote
Old 06-17-2009, 01:36 PM   #28
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Agreed on the button head. I went with what I could find and even that took 3 stores.
Stainless will give up a lot of strength, but won't corrode like this SHCS will. It's got a black oxide on it, but it will eventually lose to the elements.
Old 06-17-2009, 01:46 PM   #29
Admission_Regret
Member#: 131246
2004 STi Snow White
True, but do you think your forces are really going to be that high, I would imagine the shackle would fail first.
http://www.mcmaster.com/#92949a769/=2cvqqv
http://www.mcmaster.com/#92488a352/=2cvs3d
Anti corrosion comes at a price.
The oxide should hold up for a while and at that price, you could swap it out at least 10 times.
Old 06-17-2009, 01:47 PM   #30
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Originally Posted by BenGSX View Post
No offense..
what?
domestic_abuser is offline   Reply With Quote
Old 06-17-2009, 02:16 PM   #31
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Working on that answer. I've got the assembly in SolidWorks Simulation and am getting ready to load it and break it.
Anti corrosion comes at a price. The oxide should hold up for a while and at that price, you could swap it out at least 10 times.
So true. The SS is always so high. You can get it with a special black coating also, but that is even more ridiculous.
Old 06-17-2009, 02:46 PM   #32
SubieWReX
Member#: 151080
07 BME AutoX WRX
Awesome mod. If I had a car that I could actually use it on and not be posing I would definitely go this route. Tow hooks would be just meh for my practically stock-looking stage 2.
SubieWReX is offline   Reply With Quote
Old 06-17-2009, 03:15 PM   #33
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
I could be wrong here, but I think most track regs require a 2" inner diameter tow hook. Although whether this applies to the weekend warriors and occasional track goers I'm not sure. If that is the case, the stock one obviously doesn't cut it, and neither would this DIY one.
bcWRX-02 is offline   Reply With Quote
Old 06-17-2009, 03:27 PM   #34
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I am interested in your results with the FEA. I'd like to do this, but I am WAY too familiar with how quickly that black gunk comes off and lets the metal start rusting. Stainless for me.
Old 06-17-2009, 05:47 PM   #35
FunkRider
Member#: 195055
Originally Posted by SonicWRX View Post
Shear strength of the SHCS is just over 31,000 lbs
Tensile strength of the shackle is rated at 4,000 lbs
I would guess looking at the cross section of the stock tow hook that it would be in 15,000 lbs tensile range.
I will see if I can get the assembly into SolidWorks and break it with an FEA analysis to give a better answer.
I would assume that shear strength rating is double shear and not single? Not that it matters I'm just curious. lol
FunkRider is offline   Reply With Quote
Old 06-17-2009, 07:20 PM   #36
dtfdanyo
Member#: 195365
2005 WRX Wagon
looks easy to jack
dtfdanyo is offline   Reply With Quote
Old 06-17-2009, 07:40 PM   #37
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Got all the loads, constraints, fixtures, etc and ran the numbers. With a 10,000 lb pull on the shackle, the stock tow hook gets close to its 30,000 psi yield in the area just above the threads and before the first chamfer. It was by far the most compromised part of the assembly. We were still playing with it when I ran out of time so I'll get some screen caps tomorrow.
Yes, I am trying to find a SS button head but nothing yet and Fastenal doesn't like to sell oneseys.
That was the number reported on the manufacturer's website. I pretty much ignored it in SolidWorks by going through and defining actual materials for the individual components.
You could be right. This one would not make the grade and I doubt if this approach would work due to clearance issues I mentioned above.
Old 06-17-2009, 07:40 PM   #38
JavaBot
Member#: 156723
17 2.5i foz dgm
rip wrx/rs/2.5i/foz1
Does it wobble when you're driving? Is it tightly torqued? Otherwise it will F up your bumper, looks good but I'm not a huge fan of the droopyness.
JavaBot is offline   Reply With Quote
Old 06-17-2009, 07:52 PM   #39
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Not at all. Replacing the shackle pin with a SHCS allows you to tighten the shackle so it won't move unless forced and the split washer keeps the SHCS from backing out.
Old 06-18-2009, 10:02 AM   #40
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Ground off the cast-in text, repainted the shackle, painted the stock hook black and got this: (still need that button head!)
Here is the graphical output from an FEA in SolidWorks Simulation Pro. I constrained the stock hook at its threaded section then loaded the assembly with a 20,000 pound pull using a big ring (since I don't know how to draw a tow strap). The yield strength of alloy steel is around 90,000 psi (not 30,000 like I said above) and you can see from the colored von Mises scale that anything red is bad.
There are two stress risers in the stock hook: one just up from the threads and one not as bad near the first chamfer. You can also see some high compressive stresses where the ring meets the shackle, but with a tow strap those will go away.
CN: Stock hook will break before the stuff I added.
Old 06-18-2009, 12:48 PM   #41
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
^^ thats pretty neat
bigolrig is offline   Reply With Quote
Old 06-18-2009, 12:48 PM   #42
98Legacy_757
Member#: 183874
95 Integra SE
w/ 01 ITR exterior!?
wow thats pretty legit
98Legacy_757 is offline   Reply With Quote
Old 06-18-2009, 02:13 PM   #43
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
CN: stock tow hook will break first at the most annoyingly difficult to remove place possible.
Old 06-18-2009, 02:16 PM   #44
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
For sure. That's a written rule right close to "Fasteners dropped while working in the engine compartment will either go down the intake or not make it to the floor if they somehow miss the intake."
Old 06-18-2009, 03:00 PM   #45
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
Epic Solidworks sim. Well done sir. You must have some sort of engineering background because I've played with that program before (without an engineering background) and it took me literally a couple hours to design a bolt
I just picked up all the stuff to do this. Originally I was gonna design something similar to the nukabe and have a friend cut it out with a waterjet, but I almost like this look better, and I really only need it there for the winter, whereas the nukabe would be on there all the time.
Old 06-18-2009, 03:06 PM   #46
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Thanks. And yes, 22 years of mechanical engineering behind me so far. I'm not a SolidWorks jock by any stretch, but I have some guys working for me who can really kill it. When I get stuck, they help me out.
Old 06-18-2009, 04:39 PM   #47
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
solidworks FTW..lol..mechanical engineering student myself and am actually doing an intern right now where i make car suspension parts (mostly suspension mounts and end links) in soldiworks and then send out the drawings to get made..this is an awesome mod..will be heading to home depot when i get out of work
jcbluescooby is offline   Reply With Quote
Old 06-18-2009, 04:43 PM   #48
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Sweet! The guys at TiC did the same thing for their new "drag racing ALK". Part was designed in SW then laid down by a 3D printer for test fitting/prototyping.
I NEED a 3D printer!
Old 06-18-2009, 06:54 PM   #49
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
If I can throw out a suggestion. First, I like the tow hook looks great. Second, you can add a piece of clear vinyl under the D ring to prevent it from scratching the paint on the bumper.
recce02 is offline   Reply With Quote
Old 06-19-2009, 02:43 AM   #50
jcbluescooby
Member#: 113012
'04 XT red LIFTED
its on their tight i believe so that the wind wont be able to push it back against the bumper
Front tow hook w/ FMIC Vahnatai Interior & Exterior Modification 45 09-09-2008 04:35 PM
Front Tow Hook? With FMIC?? Thran Interior & Exterior Modification 8 02-05-2008 03:24 PM
front tow hook subwrx03 Interior & Exterior Modification 15 05-31-2006 12:48 PM
APS FMIC, bugeye WRX and the front tow hook. Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-19-2004 01:25 AM
Do '93-01 Impreza's have two front tow hooks? annointed Tri-State Area Forum 3 07-06-2004 12:12 AM
