#1 |
Member#: 54415
Vehicle:A strange Tercel attraction |
![]() I've got a 2005 MINI Cooper at the house. The fuel mileage has been going down, so i ordered a couple universal Bosch sensors for $48 each from www.Rockauto.com. Almost immediately after installing them, i got a check engine light, bank 1 sensor 1. Checked the wiring, all ok, cleared the code, it came on a day later. I talked to a few technicians I know, and none of them had faith in the Bosch sensors.
I'm reluctant to go back to MINI, because we had one of those fail early on, and they are $250 each. I'd like to find a quality direct fit sensor, don't want to pay more than about $150 each. From Rockauto: BOSCH Part # 15730 More Info {OE SmartLink - Universal Fit} Downstream; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles Upstream; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles Part Image $48.79 $0.00 $48.79 The above are the ones I bought. No bueno. ACDELCO Part # 2132908 More Info {#19107252} SENSOR,HTD OXY(POSN 1) IN EXH MANIFOLD/CROSSOVER-4 WIRE Part Image $109.79 $0.00 $109.79 Add to Cart DELPHI Part # ES20222 $130.79 $0.00 $130.79 Add to Cart BECK/ARNLEY Part # 1564395 DIRECT FIT,Pre Catalytic Converter DIRECT FIT,Post Catalytic Converter $149.79 $0.00 $149.79 Add to Cart ACDELCO Part # 2134632 {#19239900} SENSOR,HTD OXY(POSN 3) POST CONVERTER-4 WIRE SENSOR,HTD OXY(POSN 1) PRE CONVERTER, 4 WIRE * Non-stock item--shipping delayed up to 5 business days $137.79 $0.00 $137.79 Add to Cart DENSO Part # 2344457 Wire Length 24.45; # of Wires 4; O.E. Quality Replacement Sensor; Rear Wire Length 24.45; # of Wires 4; O.E. Quality Replacement Sensor; Front * Non-stock item--shipping delayed up to 2 business days $159.79 $0.00 $159.79 Add to Cart BOSCH Part # 13878 More Info {OE Type - Exact Fit} Downstream; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles Upstream; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles * Non-stock item--shipping delayed up to 4 business days
#2 |
Member#: 133439
Vehicle:2003 WRX Sonic Yellow - Stage Taxi |
![]() I'd buy the fancy OE fit expensive Bosch or the Denso. I thought the rule was Bosch for German cars?
#3 |
Member#: 54415
![]() I have no faith in any Bosch O2 sensor right now.
I think the OE ones were NTK or something like that. |
#4 |
Member#: 133439
![]() Well the OE fit > the universal one. I've heard of a fair amount of issues with the universal one but the OE fit ones have worked just fine for me in three cars including my current one. I think they're the same as Denso or something actually.
#5 |
Member#: 51282
SCIC
Vehicle:98 RS black & blue from parking |
#6 |
Member#: 54415
![]() The universal ones came with a pretty impressive waterproof splicing kit. I have a hard time believing that was the issue. So, what makes the Bosch direct fit so much better than the Universal?
#7 | |
Member#: 133439
![]() Quote:
No but really, I don't. I just always thought Bosch was good stuff for the Deutschmobiles. ![]() |
#8 |
Member#: 193989
South East
Vehicle:2007 Stormy Blue Blown Roadster |
#9 |
Member#: 54415
![]() The sensor tip on the universal is certainly different than the OE. Didn't think that would be a problem, but I could be wrong.
#10 |
Member#: 54415
![]() The NGK is winning.
#11 | |
Member#: 133439
![]() Quote:
And like I said, I think the Bosch one I got for my WRX was actually a Denso unit (or at least they looked 100% indentical) so I'd put my money on that one too, as long as it's OE fit. |
#12 |
Member#: 98645
NESIC
Vehicle:2002 WRX Wagon PSM |
![]() what was the code you got? the exact number
#13 |
Member#: 54415
#14 |
Member#: 23676
NESIC
Vehicle:. |
![]() off topic is definitely the best place to post this.
#15 |
Member#: 54415
WTB: 4-wire O2 sensor | clsmooth | VIC Private Classifieds | 2 | 05-07-2010 01:21 PM |
Who makes the best 4-wire or sensor? | camshaftprelube | Service & Maintenance | 1 | 01-29-2010 01:57 PM |
Who makes the best CF pieces for the money? | shemoves | Interior & Exterior Modification | 0 | 08-16-2005 03:47 PM |
Who makes the best CF trunklid for the least money? | 67kevin | Interior & Exterior Modification | 2 | 05-05-2005 07:13 PM |
Who makes the best coilovers for the STI? | AMG Eater | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 11-11-2003 03:56 PM |
