#1 |
Member#: 222318
E. Canada
Vehicle:1993 RHD GC8 Silver |
![]() Bought my car with a tubular manifold so i never got to see the stock manifold o2 sensor location.
It's currently in one of the manifolds runners what i was wondering is if it should be in the downpipe right after the turbo which make's more sense to me ?
#2 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() g is in the right hand headder the k is in the dp neck
#3 |
Member#: 159682
NESIC
Vehicle:1995 WRX 2015 F150 |
![]() I have an aftermarket downpipe on my EJ20G that has a bung in it. I put the O2 sensor there in the DP. It just seems like a more logical place for it. I know it's just a narrowband sensor, but O2 sensors are more accurate when not subjected to pre turbo exhaust pressure. It's also less likely to get damaged by road debris in the DP, unlikely I know, but it happens. Mine runs fine with it moved to the DP, no issues.
#4 |
Member#: 101865
NWIC
Vehicle:88 GL-10 STi silver |
![]() i too moved my O2 from the manifold to the downpipe. works just fine...
-=Suberdave=- |
#5 |
Member#: 184977
South East
Vehicle:99 Impreza RS '13 BRZ |
![]() I run PFC so I didnt need a 02 sensor but I did install the wb-02 in the bung right in the mouth of the dp
#6 |
Member#: 143416
W. Canada
Vehicle:1971 Super Beetle EJ20g Platinum Grey |
![]() I thought the reason they had it in the manifold is because its a lot closer to where the action is, and since its only used for idle/cruise feedback a) there isn't as pressure at these operating points when the sensor is actually used and b)it can respond a lot faster to needed changes.
Although everything is happening fast enough I can't see having it in the downpipe being an issue. |
stock o2 sensor location | alphagoose | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 09-26-2007 02:48 PM |
EJ20G TWO wire O2 sensor | AsphaltsCry | Subaru Conversions | 3 | 03-30-2005 02:01 PM |
WBO2 in rear O2 sensor location | drdeuce | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 09-14-2004 02:16 PM |
O2 sensor location?? Replacing..DIY job? | Sobelizard109 | Legacy Forum | 4 | 03-06-2003 10:45 PM |
O2 sensor location and wire to tap for AFR? | camz911 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 04-11-2002 05:22 PM |
