Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 03-21-2018, 02:23 PM   #176
MG9783
Member#: 121877
2006 WRX STI
Does anyone know where I can pick up the internally threaded Rubber plugs? I need a whole new set for an OEM STI lip that is going on a 2015.
SUbaru didnt seem to sell these individually and I cant find them at an auto parts store either.
Thanks guys!
MG9783 is offline   Reply With Quote
Old 03-21-2018, 02:45 PM   #177
IndecisiveS12
Member#: 463349
2017 WRX Sport
World Rally Blue
Thanks guys!
I'm in the same boat and I found these but I'm not sure what the quality is like.
https://www.ebay.com/itm/25-pieces-P...53.m1438.l2649
IndecisiveS12 is offline   Reply With Quote
Old 03-21-2018, 08:59 PM   #178
K1nG DZ
Member#: 406503
2015 WRX
Galaxy Blue Pearl
I bought these similar ones from amazon and will try them out when weather permits
K1nG DZ is offline   Reply With Quote
Old 03-21-2018, 09:32 PM   #179
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Those clips are used all over the car. They break or get stepped on or get lost. I bought one of these(link below). The clip you're looking for specifically in that kit is the second to last one. But the last one is a longer version that comes in handy too
https://www.amazon.com/dp/B01ACB56QE...detail_1?psc=1
Why would they be breaking, unless you are running over things?
Thanks guys!
You don't need the rubber well-nuts. Just get stainless-steel bolts, oversized washers, and nyloc-nuts and you'll be fine.
Old 03-23-2018, 01:44 PM   #180
IndecisiveS12
Member#: 463349
2017 WRX Sport
World Rally Blue
They're all over the car, and quite a few in the engine bay. so those ones especially will get brittle over time or get stuck when you remove them so they'll break.
So they're not just randomly breaking on the car, its when you're working on the car and trying to remove them or if you store them improperly and you step on one. it's really handy to have some just sitting around.
Old 03-23-2018, 06:52 PM   #181
K1nG DZ
Member#: 406503
2015 WRX
Galaxy Blue Pearl
So for those who still want the rubber well nuts, I got mine on amazon 25pk m5x.8
https://www.amazon.com/dp/B0040D2P7E?ref=yo_pop_ma_swf
They worked fine. I did notice there was a little gap on my driver side you canít really tell thereís a gap when looking at it. I think the side where you screw into the well nut might be a little thicker hence causing a little space.
Old 09-14-2018, 01:03 PM   #182
SoSideways
Member#: 80035
2015 WRX
Sorry to dig this thread up from the grave, but I feel like this is probably the best place to find the information that I'm looking for.
I was unfortunate enough to hit a piece of tire carcass on the highway awhile ago, which resulted in breaking a clip on the driver side of my front lip as well as the sideskirt.
The clip is the #6 clip on the diagram, which secures the lip to the fender. It is a smaller clip than the rest of the clips around the fender liner and pretty much everywhere that I've looked on the car. The clip that secures the sideskirts onto the rear wheel arch is very similar to that clip used for the front lip.
If anyone could help me find replacement for that clip, that would be greatly appreciated. Thanks!
https://i.imgur.com/BFrXGjs.jpg
https://i.imgur.com/LYn4Kv8.jpg
SoSideways is offline   Reply With Quote
Old 09-14-2018, 01:16 PM   #183
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
It's a pretty standard clip.
I would take the other side off and go to a hardware store and see if you can find something similar.
jasonwrx86 is offline   Reply With Quote
Old 09-14-2018, 01:16 PM   #184
Obviously Tyler
Member#: 395955
2021 Mazda 3 Turbo
2017 MX-5 RF Club
This is my guess.
This is the clip that's right above the front lip area in your image. Inside of the wheel well. It holds the bumper on.
To remove it, you push the center in first, correct?
https://estore.subarupartswarehouse....909140062.html
Obviously Tyler is offline   Reply With Quote
Old 09-14-2018, 01:17 PM   #185
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
Make sure you push the lip up all the way when you tighten the well nuts because I notice when you put the screws in, the weight of the lip would pull the well nuts out of the bumper creating a gap.
Old 09-15-2018, 12:37 AM   #186
prelude/2.5rs
Member#: 9355
2013 STI Hatchback
2015 BMW X6
I think I have a couple of those clips in my glovebox...new
prelude/2.5rs is offline   Reply With Quote
Old 09-15-2018, 01:33 PM   #187
SoSideways
Member#: 80035
2015 WRX
Originally Posted by Obviously Tyler View Post
This is my guess.
That is correct. There is a tiny nub to push in to lock it into place. I have not taken the bumper or the front lip off on this car, nor have I taken the front fender liner off for any reason since owning it, so I wouldn't know if the clips holding the bumper on is the exact one I needed. I'll check it out later.
Thanks for the help! ***128077;
Old 01-10-2021, 02:12 PM   #188
Jboggie
Member#: 77233
2017 WRX STi
LBP
Thank YOUUUUUUUU! I just did the lip on MY2017STi, but I took the bumper off because I also did the JDM grill and it was so easy!!!
Jboggie is offline   Reply With Quote
