Welcome to the North American Subaru Impreza Owners Club Thursday March 4, 2021
Old 04-14-2019, 12:20 AM   #26
chevbo
Member#: 500342
sorry to spam i need 3 real replys
chevbo is offline   Reply With Quote
Old 04-14-2019, 12:20 AM   #27
chevbo
Member#: 500342
thanks super srry
Old 04-25-2019, 01:09 PM   #28
MrSTIGuy17
Member#: 500573
2017 STI
CWP
Has anyone figured out how to wire the fogs so they stay on when you put the high beams on?
MrSTIGuy17 is offline   Reply With Quote
Old 04-25-2019, 08:46 PM   #29
transmutation
Member#: 467769
2018 STI Limited
If you are using one of the aftermarket kits they should all tap into the high/low fuse locations so by default the fogs come on whenever the headlights are on including hi beams. I suppose you could just tap the lows though.
transmutation is offline   Reply With Quote
Old 04-26-2019, 06:15 PM   #30
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
https://www.prolightz.com/subaru/imp...l-harness.html
This is what I installed onto my car.
Old 04-26-2019, 06:33 PM   #31
fullah
Member#: 233053
Someone did the oem sti bezel with fogs behind it for a hidden look..
fullah is offline   Reply With Quote
Old 04-26-2019, 06:50 PM   #32
farid_0926
Member#: 500856
Hey guys I have a 2018 sti,i bought the OEM install kit. Havent been able to install it because i cant seem to find the stock fog plug. Can someone here shed some light on this?
farid_0926 is offline   Reply With Quote
Old 04-26-2019, 09:02 PM   #33
nationuar
Member#: 470898
2018 WRX
CWP
You could run a relay off of the Low Beam switch. But with maintaining factory wiring...
nationuar is offline   Reply With Quote
Old 04-27-2019, 02:42 PM   #34
pdxsilverwrx
Member#: 54935
I read there was no factory wiring for fogs on the 2018 STI. I did not see any plugs or wiring for them when I was under the car installing the fog lights either. I had installed a factory set of fog lights on my 2006 STI back when I owned it so I think I would have noticed the plugs. I used an aftermarket wiring harness when I installed the set on my 2018.
pdxsilverwrx is offline   Reply With Quote
Old 04-28-2019, 12:25 AM   #35
CFM56
Member#: 460834
2011 STi
Dark Blue
What plug?
The instructions are from Subaru, pretty straight forward, the relay goes behind the back of the glove box, the kit has a fog light switch and a bezel that replaces the factory blank bezel on the left of the steering wheel and there should be a plug that is tucked/tied away behind it on a random harness that you plug in on the switch provided.
https://stis.subaru.com/proxy/75344/...FogLampKit.pdf
CFM56 is offline   Reply With Quote
Old 05-01-2019, 01:20 AM   #36
farid_0926
Member#: 500856
This plug. I saw the Subaru install instructions such is the reason I ordered this set. But kinda stuck since I had the bumper off and still couldnt find the damn thing.
Old 05-01-2019, 01:21 AM   #37
farid_0926
Member#: 500856
Taking the bumper off again this weekend to see if I can get to it
Old 05-05-2019, 08:41 AM   #38
Kaykay
Member#: 409353
2018 WRX STI
Let us know if you find it. I was under the impression that it's not there.
Kaykay is offline   Reply With Quote
Old 06-16-2019, 12:27 PM   #39
MaxxPower
Member#: 244920
2010 WRX Limited
Dark Gray Metallic
Any progress?
MaxxPower is offline   Reply With Quote
Old 06-20-2019, 02:52 PM   #40
penak
Member#: 498498
I don't have personal experience with them, but I was considering them when I was looking
penak is offline   Reply With Quote
Old 07-08-2020, 09:38 PM   #41
garyf2132
Member#: 485851
2018 WRX
Got a 20 STI here & been trying to find info on adding the fog lights. Called 2 dealers & they said the Subaru fog light kit isn’t compatible, even though the Subaru parts website said they are, but the fog light harness is behind the panel to the left of the steering wheel ready to be connected. I’m absolutely baffled. Anyone have any luck?
garyf2132 is offline   Reply With Quote
Old 07-08-2020, 10:29 PM   #42
Smunczen
Member#: 501315
Subispeed kit in my 19 sti. Works pretty good changed the lights to the diode dynamics ss3 lights much better.
Smunczen is offline   Reply With Quote
Old 07-08-2020, 11:37 PM   #43
brian_freep
Member#: 193433
2018 STI Limited
Crystal White Pearl
18's, 19's and 20's all use the same kit from subispeed. I have an '18 and recently received the same kit from subispeed but also ordered the JDM S4 DRL (+fog) bezels. I am going to be running new fog light wiring, and using the switch from the kit to install next to my steering wheel. Ill tap the DRL LED's into my existing DRL lights. Should be a snap.
brian_freep is offline   Reply With Quote
Old 07-13-2020, 10:54 PM   #44
super_subie
Member#: 344431
2020 STI
CWP
any pics of final product?
super_subie is offline   Reply With Quote
Old 07-18-2020, 10:01 PM   #45
brian_freep
Member#: 193433
2018 STI Limited
Crystal White Pearl
Default 2018 STi with JDM S4 + Fog
These were installed using the Subispeed 2018 complete fog light kit. It actually came with 3 different interior switches. One of the interior switches was the perfect size to fit my stock interior switch bezel. So, although the kit came with the OE bezel in case it needed to be swapped - I was able to use my existing bezel w/o modification.
I ordered the JDM S4+fog bezel direct from japanparts. It came surprisingly fast for being on back order (13 days). I ordered the complete kit from Subispeed. It came with stock OE bezels but those are also not used in my setup. I selected the Morimoto XB LED's as the ~$150 upgrade - but after 5 weeks, I'm still waiting on those. I ended up ordering the OLM Midnights from RSD and they were overnighted to me.
The DRL's are tapped using the "add-a-fuse" method. When ignition is on, the DRL LED bar is on. The Fog light wiring was ran by my installer. I was lazy. He installed the fog light wiring as well as the switch button. It was a very clean installation.
https://d1nktod873oxpw.cloudfront.net/IMG_2943.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2944.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2945.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2946.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2947.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2948.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2949.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2950.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2951.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2972.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2973.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2976.jpg
https://d1nktod873oxpw.cloudfront.net/IMG_2977.jpg
Old 07-21-2020, 09:19 AM   #46
altonka035
Member#: 516299
2019 STI
ISM
I installed the Winjet WRX / STI 2018+ off Rallysportdirect and works perfect in my 19 STI. Tapped switch power from the Accessory fuse in the car and wired the relay to the battery, lights can come on anytime. Tossed the cheap fogs and got some Diode Dynamics SS3's instead.
altonka035 is offline   Reply With Quote
Old 07-21-2020, 03:44 PM   #47
transmutation
Member#: 467769
2018 STI Limited
What does the switch look like that came with the Winjet kit? I've been looking at retrofitting my install with an interior switch but don't really want to buy the entire subbispeed kit...
Old 07-21-2020, 08:18 PM   #48
altonka035
Member#: 516299
2019 STI
ISM
Not as bright as the pictures let on. I had thought about seeing if I could find an OEM switch to match the interior lights when on.
Key on:
Lights on:
Old 07-21-2020, 08:35 PM   #49
transmutation
Member#: 467769
2018 STI Limited
Thanks! Does it stay lit up green when the car is on but the fogs aren't on?
Subaru does make an OEM foglight switch that would go into the cutout to the left of your dimmer.
Old 07-21-2020, 09:04 PM   #50
altonka035
Member#: 516299
2019 STI
ISM
It does, green 24/7 when the car is on, "red" when fogs are on. I wired it to the Accessory fuse right there at the interior fuse panel so they can be on whenever I want and are independent of hi/lo beams.
I'll look into the OEM switch, right now the current setup doesn't bother me as it out of my line of sight.
