#1 |
Member#: 495427
Vehicle:2012 Sti Hatch SWP |
![]() I'm not sure if this has been attempted before, but I figured I'd ask the question.
Will seats from a VA(15-20) sti fit into a GR(08-14) sti? I know that GR sedan seats will fit into a GR hatch, and based on images, the rear seats on a VA(sedan) look to be very similar in shape to a GR. The "latches" are in the same spot, the split is the same, and the release lever is in the same place on the shoulder. For the bottom, I haven't seen the brackets that hold the cushion in place. As far as the fronts go, I would just need to know if the seat brackets are compatible, and if the plugs for the occupancy sensor, and side airbags are the same. I figure the OEM Recaros from a VA would look/feel mighty nice in a GR, and the prices from a wrecker are substantially cheaper than trying to import JDM Recaros from the GR. So NASOIC, tell me what you know!
#2 |
Member#: 254317
Vehicle:2011 STi |
![]() Interested to know too, will be watching this thread. Thx for asking the question.
#3 |
Member#: 495427
![]() So, after more research, looks like I answered my own question...
Here is a seat bracket for the front seat for the GR: and here is one for the VA: While the brackets aren't in the same orientation in the pic, looks like the new VA just uses 4 vertical bolts, while the GR has 3 vertical bolts and one sideways/angled bolt on the rear centre. I've viewed the OEM brackets in various youtube videos to confirm that (but can't post screenshots here). Too bad ![]() |
#4 |
Member#: 284221
Vehicle:2011 WRX GV SSM 2013 MacLeod |
![]() Also the passenger seat in the GR/GV sits lower than the driver, not sure if that is the bracket.
