Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Alaskan Impreza Club
Old 05-26-2004, 12:31 AM   #1
yukon1
Member#: 4730
07 Legacy Spec,B
Diamond Gray Metallic
Impreza GC8 Need help on plug wires
Need some help advice, on my rs. Can't get the plug wire caps out of the valve cover on the drivers side. The pass. side were hard but they came out. Ive pulled on em but im afraid im going too break em if i keep pulling on em. Any advice would be helpful.
Dan
yukon1 is offline   Reply With Quote
Old 05-26-2004, 01:21 AM   #2
SQUAD_907
Member#: 10104
WOW! JUST WOW!
I make posts disappear
easier to pull the boots off when the engine is warm....
SQUAD_907 is offline   Reply With Quote
Old 05-26-2004, 03:30 AM   #3
yukon1
Member#: 4730
07 Legacy Spec,B
So i need too warm it up then pull the plug wires?
Old 05-26-2004, 03:46 AM   #4
SQUAD_907
Member#: 10104
WOW! JUST WOW!
yah...easier to remove the boots...then let the engine cool and remove the plugs....
Old 05-26-2004, 05:12 AM   #5
eurojax
Review Crew
Member#: 34269
Only marginally
funny.
Dude, it took me like 5 minutes each to get those bitches off, and I'm a big guy. My boots were covered in motor oil so they were all slippery. I just kept pulling and pulling.
On the drivers side, I took off the windshield washer resevoir and moved the battery a little bit, gave me some more room to work with.
I don't think they will break, they are pretty tough rubber and plastic, just wrap two fingers around the boot and rotate it back and forth and then pull.
eurojax is offline   Reply With Quote
Old 05-26-2004, 06:57 AM   #6
WRXnFX
Alaskan Mafia
Member#: 10398
To prevent this in the future, add a little dielectric grease to the spark plug and then replace the boot. It'll make the next time so much easier.
Winslow
WRXnFX is offline   Reply With Quote
Old 05-26-2004, 07:07 AM   #7
eurojax
Review Crew
Member#: 34269
Only marginally
funny.
I thought Dielectric grease was just to make sure your contact points don't rust over? I saw no rust on mine, so I didn't put any on, next time i'll add some for sure.
Old 05-26-2004, 08:21 AM   #8
WRXnFX
Alaskan Mafia
Member#: 10398
Right, dielectric grease is used to prevent "corrosion" and improve the connection. Corrosion comes in other forms than the typical redish rust. It really depends on the type of metal. I think the type of metal that forms the contacts will produce more of a whiteish dust.
Winslow
Old 05-26-2004, 09:47 PM   #9
yukon1
Member#: 4730
07 Legacy Spec,B
Just got home engine was nice and warm and they still will not come off. Im pulling and turning too get em off. Dont see any oil on the other two plugs and they looked really good shape.
Dan
Old 05-26-2004, 10:19 PM   #10
eurojax
Review Crew
Member#: 34269
Only marginally
funny.
I asked the oil question in the N/A forum a couple weeks ago.
http://forums.nasioc.com/forums/show...es+OR+bonnetts
Pretty easy to fix if you ever get that problem.
Old 05-26-2004, 10:51 PM   #11
yukon1
Member#: 4730
07 Legacy Spec,B
Finally came off, about time lol.
NEED HELP on Ej20g plugs/wiring. azn0boi04 Subaru Conversions 16 08-28-2008 02:43 PM
Need help on some wiring problem! vicdeng Electrical & Lighting 1 01-18-2006 08:21 PM
Need Help on Injector Wires subiekid Subaru Conversions 1 03-19-2004 12:57 AM
need help on 02RS ecu wiring diagram SFimpreza411 Normally Aspirated Powertrain 8 06-13-2002 10:38 PM
