#1 |
Member#: 378600
TXIC
Vehicle:09 Subaru WRX STi Black |
![]() Hello NASIOC! I under to own a 2005 WRX but had to sell it last year...I am now proud to say I own a 2009 WRX STi hatch! Yes with a story..haha
As attention grabbing as the title is, the journey was pretty uneventful thankfully. Car is in amazing condition. One ding on the driver side is the only one on the car. Hood scoop has started to fade and the front bumper has some pitting. And that’s the end to the bad of the car! Car is completely stock with no modifications other than aftermarket rear suspension arms and a stereo. Engine runs great and has no leaks or weird sounds! Pics will be forthcoming... just thought I’d share this unique story!
#2 | |
Subtly Outspoken
Moderator Member#: 238
Vehicle:OG05 STi 51E |
![]() Quote:
Congrats ![]() Lots of info here.. don't be afraid to ask if you have a question and can't find the answer... Search is your friend.. ![]() Enjoy Bill |
#3 |
Member#: 378600
TXIC
![]() As far as the future goes I’m going to leave it untouched mostly! I want to keep it stock as far as powertrain goes as I’m enjoying the amount or power. A few cosmetic things and that’s about it.
Thank you for the welcome! |
#4 |
Member#: 431618
SWIC
![]() Congrats! It would be fun to restore it as much as possible to a showroom stock experience. I hope to tackle a such a project in the future on an earlier model.
#5 |
Member#: 378600
TXIC
#6 |
Member#: 378600
TXIC
#7 |
Member#: 378600
TXIC
![]() Got it!^
#8 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
![]() Would you mind sharing what you paid for it ?
Looks really good, congrats. |
#9 |
Member#: 378600
TXIC
#10 |
Member#: 338863
Vehicle:PSM 05 WRX WGN 5MT 95 Caprice 6spd Track Rat |
![]() Looks pretty nice and clean for the age and mileage
#11 |
Member#: 110078
#12 |
Member#: 378600
TXIC
#13 |
Member#: 378600
TXIC
#14 |
Member#: 519643
Vehicle:2019 WRX WRB |
![]() Congrats on the purchase. Car is in amazing shape for the mileage and year.
#15 |
Member#: 378600
TXIC
#16 |
Member#: 82720
RMIC
Vehicle:1993 any 93 + subaru dirty or snowy |
![]() I think I saw this for sale here in colorado... it looks CLEAN enjoy
#17 | |
Member#: 378600
TXIC
![]() Quote:
So far so good! A loose and kinda stiff power steering belt is what was squeaking and that’s it so far. I’m going to get the transmission and differential fluid changed here in the coming weeks just to make sure it stays good. Just some minor mods in store for it but remaining stock powertrain for now! Works and don’t want to mess that up ![]() |
#18 |
Member#: 378600
TXIC
![]() Small Update: First issue with the car! After a few really cold days it’s developed a small oil leak somewhere on the passenger side and it’s dripping on the headers which makes a wonderful smoke show. Without tearing into it I can see it looks like it’s coming from the timing case.
#19 |
Member#: 10854
SCIC
Vehicle:'02 WRX; '08 OBXT; '08 G37 (S/C'd); '09 XF |
![]() It could be that, or run your finger around the LH valve cover. They tend to leak with age, and they drip right on the header/uppipe. Good thing is that it's an easy fix.
One thing you might want to take a look at, (but maybe not since you've had pretty good luck with it so far), is to have it tuned. They tried to make the 09-11s have better gas mileage by keeping them lean long after the initial throttle tip-in, and they also ran the #4 cylinder 1-2 degrees leaner to get that cylinder to knock first and set off the knock sensor, which is mounted closest to that cylinder. Those factors seem to get the blame for the dreaded ringland failure, so it's a good idea to get it tuned just for safety. You could probably just get an Accessport and flash their canned Stage 0 tune and it would be safer than the stock tune. I have an 08 OBXT and as soon as I got it, I looked at the stock tune, all those things were there. But congrats on the new car, looks super clean! Now that I've had a couple of Subarus, I wish more people would talk about how long the car has been good to them, instead of the usual power bragging. |
#20 | |
Member#: 378600
TXIC
![]() Quote:
Thank your for all the knowledge! I will take up that suggestion on what to check. As far as tuning goes I would love to get it it tuned but none are anywhere close to local sadly. One day though. One day. Do you happen to know if that lean issue persists even in S# mode? Since that changes the throttle mapping? Yea so far so good other than little cosmetic things so this oil leak isn’t super concerning. I have a great Subaru mechanic here and he’s going to help me out tracing it down. |
#21 |
Member#: 10854
SCIC
![]() Not 100% sure on the Sti tune, but it was there on my OBXT tune. Different ROMs are setup differently, but on my tune, the I/S/S# mode differences lie mostly in the throttle and load maps, not the timing maps, so the lean #4 cyl is on all maps and the open loop delay setting is global as well.
If you don't have a local tuner, you could get an Accessport and it would come with a tune that you could flash. If you keep an eye out in thee classifieds, people sell them fairly regularly. |
#22 |
Member#: 378600
TXIC
#23 |
Member#: 378600
TXIC
![]() Update 1/22/21
Oil leak has been found and partially repaired! Main oil leak was coming from both valve cover gaskets and I had those replaced. The oil cooler is also leaking a little bit so on the next oil change I will be changing out the O-ring on that. Feels good to know the issue and have it fixed |
#24 | |
Subtly Outspoken
![]() Quote:
![]() ![]() Bill |
#25 | |
Member#: 378600
TXIC
![]() Quote:
Yes I agree! Just to have piece of mind it’s worth it. I will be doing the timing belt and related accessories later this year for the same reason. |
