Welcome to the North American Subaru Impreza Owners Club Saturday May 21, 2022
Old 01-13-2022, 06:19 PM   #1
13SportLimitedCBS
Member#: 331157
Default Brake Ligjt Switch
2013 Sport Limited
My gear shifter has been having a hard time getting out of brake. Traction control ABS and descent light have also been. Found what I believe to be the culprit, a failing brake light switch. Ordered STANDARD MOTOR PRODUCTS SLS 186 (Rock Auto) as the replacement. Pulled old one out and it was a Niles (Nissan) PA66GF33. So needles to say I’m stuck. Why would this be a Nissan part?
And this will fix my problem correct?
13SportLimitedCBS is offline   Reply With Quote
Old 01-13-2022, 07:57 PM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
The Nissan part is the OEM Subaru part. It also failed - A LOT. Subaru had a recall for this issue https://static.nhtsa.gov/odi/rcl/201...9V149-9018.pdf
If the recall has not been performed on your car you could have gotten this fixed for free.
Read the linked recall - it will tell you the proper method to get the switch adjusted correctly.
Oh yeah, Forgot to add - yes, if you brake light switch is bad it will cause that problem.
Elbert Bass is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
