Welcome to the North American Subaru Impreza Owners Club Saturday October 1, 2022
Old 09-26-2003, 07:43 PM   #1
scottjua
Member#: 2937
2013 2019 Type R
2006 STi Aspen White
Default Need help with Tanabe springs on a WAGON
Given that the wagon has different spring rates than the sedan...and that Tanabe doesn't list a specific kit for the wagon... which spring set would be best for me?
I will be using the stock struts... so they have to atleast fit that requirement. The car is a daily driver but may also be used for the odd track day (road course, not drag)...
can anyone who may have these on a Wagon advise...or help me figure out what I need or don't need???
Thanks guys!!!
scottjua is offline   Reply With Quote
Old 09-27-2003, 02:53 AM   #2
scottjua
Member#: 2937
2013 2019 Type R
also...after install of the springs and a settling period for the new springs... will I need to get an alignment? Will it affect the ability to get a proper alignment???
Old 09-27-2003, 07:47 AM   #3
Bolster
Member#: 22290
2002 STI Ver 9
Spec C Wagon
You'll need an alignment after the install regardless, since you'll be pulling the struts off. I imagine you'll be able to get your alignment back to within factory specs unless it is a severe drop from stock. How much do the springs lower the car?
Bolster is offline   Reply With Quote
Old 09-29-2003, 08:26 AM   #4
scottjua
Member#: 2937
2013 2019 Type R
that's I'm not entirely sure... (hoping for someone who may have them equipped could reply) but I think it's close to 1.75" front and 1.5" rear...???
I recall reading about people needing camber kits to get back to factory spec, but is that a SEDAN only issue, or also a Wagon problem? The factory spec on the tow body style is different isn't it?
Old 09-29-2003, 08:43 AM   #5
Bolster
Member#: 22290
2002 STI Ver 9
Spec C Wagon
If it drops 1.5" rear, you might need camber bolts, because the rear probably won't go that low and be able to get within factory specs without them.
Old 10-14-2003, 01:01 PM   #6
scottjua
Member#: 2937
2013 2019 Type R
bump
need help with wheel fitment on 05 wagon with brembos. Yellow2 Tire & Wheel 2 10-02-2009 03:14 PM
NE Region: need help with strut/spring/tophat swap this week The Modaholic Brakes, Steering & Suspension 7 03-14-2005 08:45 AM
Need help with aftermarket springs 98LegacyGT Brakes, Steering & Suspension 1 08-07-2003 11:52 PM
need help with tanabe pillow mounts bryan2.5rs Brakes, Steering & Suspension 1 08-27-2002 10:36 AM
Need help with 5Zigen spring install... -=DriftxKing=- Brakes, Steering & Suspension 2 08-19-2001 12:59 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
