#1 |
Member#: 491668
![]() I wanted to see what you guys opinion on what direction I should go.
I have an 08 WRX Hatch with a VF52 turbo (from the 09 up), tuned by Eric from Torqued Performance running his Stage 3.52. Recently, I purchased the cobb flex fuel kit with the aem pump and 1050cc injectors. Well, we tuned for 93 but something happened in the engine when tuning for E85. Long story short, I need a new engine as mine has nearly 190,000 miles anyway. My question is- what is the best (and cheapest) option to get this car back on the road? Ive looked at used engines from ebay and other places but most are selling JDM replacements which is the 2.0L vs the 2.5L in the car. Would those still be a direct swap? I can get a short block from rallysport and rebuild the head as also an option but itll be a bit more in cost. What do you guys recommend?
#2 |
Member#: 481754
Vehicle:2017 STi Base Black |
![]() What are you going to do with the car? Whats your expected hp, mods?
#3 |
Member#: 491668
![]() Well..Its not my daily but I do enjoy driving the car more often than usual when I get bored driving my DD (Audi A4). I plan on starting to do track with this car, hoping to do it this summer. It has all your basic bolt ons; catless dp, exhaust, ebc, intercooler, radiator, intake, etc. It is basically my backup/fun car that I want to keep somewhat reliable and able to track it if decided to do so. Eventually I would want to upgrade from the vf52 turbo.
#4 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
![]() What is your power goal? Are you planning to upgrade the turbo? How much PSI are you planning on pushing? If you plan to stay around stock power, or below 350hp then just get a RA block and call it day, but if you plan on making the eng work hard, then go built block stage 1 or 2. If you plan on using E85 at 350whp, the RA block would be fine for your needs. But if you are then kind of person who will want more power a year later, then build the block for the future.
#5 | |
Member#: 491668
![]() Quote:
If I opt to get the STI EJ257 short block, will my WRX heads and supporting parts bolt right up to it? Sorry for the noob questions. |
#6 |
Member#: 518830
RMIC
Vehicle:2009 WRX dark grey metallic |
![]() yeah the STI short block bolts up- it's very similar- you'd have a slight change in compression as a result since the Sti uses different cylinder heads.
also the sti has an oil cooler and yours doesn't- but that just means you need to buy the plug from subaru. And make sure to get a WRX water pump. https://forums.nasioc.com/forums/sho....php?t=1667168 EJ257 pistons on B/V25 STi head: 8.28:1 EJ257 pistons on D25 WRX head: 8.78:1 EJ255 pistons on D25 WRX head: 8.55:1 |
#7 | |
Member#: 491668
![]() Quote:
#8 |
Member#: 518830
RMIC
![]() I'd suggest doing that as well. I'm about finished building mine- cleaning the intake cam gears out was quite a bit of work- and I've got a parts washer and everything. It's worth the money unless you really like to tinker with everything to buy new ones.
#9 |
Member#: 518830
RMIC
![]() ![]() ![]() to give you an idea of what lurks in there. and showing the parts cleaner shot so you can see all the holes that can hide metal debris. |
#10 | |
Member#: 491668
![]() Quote:
Eric from TP said the log looked fine when I did the last 3rd gear pull where it started knocking. He said most likely I lost oil pressure that caused it. I read the log and noticed that even before the pull, the LS AVCS stopped advancing the intake cam where the RS was working normal. It was still working on a small WOT from 3k-4k that I did prior to the 6k pull. Dont know if that had anything to do with it, but everything else looked good. I has a very noticable knock now at around 2k rpm and goes away as it climbs and not noticeable during decel. Oil pressure at idle is also very low as well (via pressure gauge). |
#11 |
Member#: 193940
![]() So unless you like working with your hands and have lots of patients, I would just get a new set of cam gears. After you put in a block that can hold 350 hp, don't forget about your tranny. The 5 speed can not hold as much power as the 6speed, so pushing over 400 will be gamboling with tranny.
Mixing heads with blocks will make your setup a hybrid. Read up on that, there are lots of threads on here about hybrids. |
#12 |
Member#: 518830
RMIC
![]() it could well be that debris from the bearings had already caused the AVCS to seize and fail to change position and only when the wear got bad enough was a knock audible. Could also be that the bearing material just plugged the banjo bolt screen and then there wasn't any oil able to pushed through it to actuate the AVCS.
#13 | |
Member#: 491668
![]() Quote:
I dont remember anymore what I found on mine. I dont remember finding anything but then again, I dont remember if i checked all the bolts. ![]() ![]() |
#14 |
Member#: 491668
![]() I checked the LS AVCS banjo - no filter
#15 |
Member#: 273868
![]() Left side is usually behind the timing cover
#16 |
Member#: 491668
#17 |
Member#: 491668
![]() Ok Ive been pricing things out.
From Import Image Racing, with the RA block, oil pump and new cams is only about $200 cheaper vs if I was to purchase a bare block, nitride crank and their build package '1B' with Manley Rods/Pistons. I used to be a technician back in the day and went to school to be a certified toyota tech so im capable of putting the parts together if it yields a better result than just getting the RA block. What do you guys think? |
#18 |
Member#: 149347
NESIC
Vehicle:05 LGT ,09 SpecB Black/silver |
![]() Let the experts do what they do, that's not a big price difference.
#19 |
Member#: 239822
South East
Vehicle:2010 WRX pandiculation |
![]() Don't forget to factor in any tools you need to buy in any calculations.
Built isn't always better. At your power levels, just go with the RA block and probably get more miles in before needing another rebuild. |
#20 | |
Member#: 193940
![]() Quote:
#21 | |
Member#: 491668
![]() Quote:
#22 |
Member#: 481754
![]() You should have no problems with the RA block at your power levels. Its the track life that I'd worry about. Theres a few guys pushing 500whp+ but I don't know how much tracking they're doing.
#23 | |
Member#: 491668
![]() Quote:
It states on there that the WRX head should not be used on an STI block. "Because of the difference in piston dish and combustion chamber volume, it is not recommended to pair a D25 head with an STI block, or one that was designed to work with B25 heads." Is this a matter of using the correct pistons? Again, sorry for the noob questions. |
#24 |
Member#: 193940
![]() Im sure they meant to say they are not direct bolt on. Need to change pistons, head gasket thickness, ect...
#25 |
Member#: 518830
RMIC
![]() However if you buy forged pistons they usually are the same dish volume as the STi and so will increase compression. Maybe they say that cause you’d need to tune differently to avoid detonation.
