Welcome to the North American Subaru Impreza Owners Club Friday January 27, 2023
Old 11-09-2022, 12:22 PM   #1
zotethemitey
Member#: 527044
Default Help me track down what's causing +15.64 AF Learning 1 on Decel
I have a 2017 STI. Protuned by TPG.
Engine Mods are Cobb Accessport, Cobb SF Intake, Cobb EBCS, ID 1050s, Cobb FPR, AEM 340 fuel pump, Invidia R400 turbo back (catless)
I have been on the same tune for about a year. AF Learn 1 has always been a little high ~10-12 but my tuner said this is normal and to ignore unless it gets worse. Well it got worse. And now because of greenspeed I can't have my tune adjusted so I'm going the other direction trying to find if there is a leak somewhere.
Checked my hoses and hose clamps, took off the intercooler and checked the hose to the turbo, replaced BPV gasket, etc.
I'm not sure what else it could be. I'm going to replace my exhaust gaskets in the next few days but IDK that that could be the cause of anything. If the gasket before the front O2 sensor is toast, could that cause high AF Learning 1?
What else should I check? Any advice is appreciated. I'm still a fairly new subaru owner (~2 years). I have been trying to do as much as I can myself but I'm still learning.
If I can't find what's causing it I'm going to have to take a day off work and take my car to get the intake track smoke tested.
zotethemitey is offline   Reply With Quote
Old 11-09-2022, 12:31 PM   #2
Jedi03
Member#: 491095
2009 STi Blue
how much gas are you giving it while decelerating?
Jedi03 is offline   Reply With Quote
Old 11-09-2022, 01:36 PM   #3
zotethemitey
Member#: 527044
Zero. Totally off throttle
Old 11-09-2022, 03:17 PM   #4
Jedi03
Member#: 491095
2009 STi Blue
well that would likely cause it...not enough fuel during decel...others may chime in but i would expect very lean conditions at this time, which is what my ap and widebands have all indicated and is no issue
Old 11-16-2022, 10:50 PM   #5
siete
Member#: 499183
2019 STI
~10-12 all the time even at idle?
Yes, an exhaust leak before the front o2 can cause messed up fuel trims, but I think it would show more around the idle learning range.
I'd pressure test or smoke test the system first, and clean the MAF sensor.
siete is offline   Reply With Quote
Old 11-25-2022, 12:04 AM   #6
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
If the exhaust gaskets arent leaking I wouldnt change them. Could just be a false reading from the o2 sensor. Try unplugging the maf and monitor the o2 readings.
Also check your ground wire at the transmission. And add a ground to the exhaust system. If your mount on the transmission is crudy. Might help.
spoolinsti05 is offline   Reply With Quote
Old 11-29-2022, 07:00 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
you might want to check your turbo inlet that is a pretty bad leak
subaru_gc8 is offline   Reply With Quote
Old 11-30-2022, 12:01 AM   #8
a5m
Member#: 519868
2010 Impreza WRX
Satin White Pearl
An exhaust leak past the rear O2 can cause high AF Learning during decel. I recently went through this after installing a new downpipe that wasn't mating with the catback all that well. Finally did a smoke test that revealed a massive leak so used a Remflex gasket that thankfully fixed the issue and the AF Learning is steadily coming down, both on decel and at idle.
a5m is offline   Reply With Quote
