#1 |
Member#: 89041
![]() i recently just bought a rebuilt 04 transmission and made it fit with my 05 wrx
![]() ![]() ![]() kevin
#2 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
![]() You better stay on top of your transmission lubrication till this gets resolved. Sounds like the seal was possibly damaged during replacement, not hard to do by the inexperienced and experienced alike. Get that sucker back to the dealer, or whoever is responsible for the work and the rebuild.
#3 |
Member#: 89041
![]() thanks guy!
#4 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp [email protected] |
![]() Been there, done that. Probably just ripped the seal when putting the half shaft in. No biggie.
http://forums.nasioc.com/forums/showthread.php?t=842844 |
#5 | |
Member#: 89041
![]() Quote:
#6 |
Member#: 89041
![]() hey guys hopefully you can help me out i did change out my seal at school today in the garage..but would you guys know how many turns it takes to tighten up that right side cap to the axle??? i tightened it around 4 turns? i tried to call subaru but a55 cracks just put me on hold for years and years..so was wondering wouuld you know how many turns it takes to tighten up the cap seal from the axle stub..also i did tighten it up 4 turns but that piece of **** is still leaking!!! help????
#7 |
Member#: 60116
Vehicle:1999 RS Coupe Silver Thorn |
![]() Ewwww. You should have marked a tooth and then counted the number of turns until you were able to pull it out. You may have to get the gear lash set unless you know how to do it.
#8 | |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
![]() Quote:
#9 |
Member#: 93667
Vehicle:'03 Build'n a 2.12L 331whp/331wtq |
![]() If you only turned out one side then crank it in until it stops (easily) then crank it tight one tooth. This sets the pre-load on the carrier bearings. If you loosened both your going to have to drop the trans to get it set 100% correctly.
Each tooth rotation is equal to .0020". Backlash should be .005-.007 Kev |
#10 |
Member#: 82741
NESIC
Vehicle:2007 350Z Silver |
![]() Kinda related to my problem.
I have the case split open right now and installing a new diff. I mount it carefully to the drivers side and lower it until the bearings rest on the race. Then I remove to check if I did anything wrong and noticed a spring thats out of place. I believe it was wrapped around the oil seal lip. Should I remove the diff side retainers, mate the retainer to the bearings then install the retainer to case? |
#11 |
Member#: 1015
![]() That's the tension spring for the seal. It's easy to dislodge when lowering the axle stub through the seal and is probably the cause for the original poster's leak. If this is out of place or the seal lip gets folded over then a leak is likely. Just put the spring back in position, lube the seal (very important), and lower the diff into postion carefully making sure the axle stub isn't catching the seal lip as it goes through.
How in the HELL is Chrysler going to offer the Challenger.... | BhamRoadrunner | Off-Topic | 6 | 01-09-2009 10:13 AM |
What the hell is my manager talking about? | roffle | Off-Topic | 19 | 09-29-2005 07:11 PM |
Where the hell is my fumoto valve? | gerbs | Off-Topic | 10 | 11-13-2003 02:14 AM |
where the hell is my alcohol thread? | [27] | Texas Impreza Club Forum -- TXIC | 2 | 03-29-2002 11:17 AM |
Urgent...where the hell is my flange?!? | kid22 | Technical Forum Archive | 2 | 08-20-2000 09:54 PM |
