Welcome to the North American Subaru Impreza Owners Club Tuesday October 20, 2020
Old 04-11-2014, 01:17 PM   #76
AlxSti
Member#: 94615
2017 VW GTI S1+
2006 STi 341WHP/356TQ
These reviews are awesome. Thanks guys!
AlxSti is offline   Reply With Quote
Old 04-11-2014, 01:18 PM   #77
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Originally Posted by Redeemed77 View Post
Holy restriction! There has to be a better solution than that in the aftermarket.
You'd be surprised at how unrestrictive most ugly and convoluted intake pipes are these days. Manufactuers don't leave HP on the table because HP is a major selling point for performance cars and cars in general. They spend millions in R&D to deliver maximum power, the most consistent power, best driveability for all situations, and probably most importantly, reliability.
Aftermarket companies need to be very careful when designing parts and must bench test the OEM part vs the aftermarket "solution". Just because it looks ugly and restrictive does not mean that's really the case and just because the aftermarket part can flow way more air doesn't mean the motor can do anything with it.
Old 04-11-2014, 01:20 PM   #78
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Mishimoto-
Can you look at the steering rack and see if the bushing design is same as the GR/GV gen? The word is the WRX/STI use much stiffer steering rack bushings and I'd like to use OEM parts where I can.
It's great news that the rear 20mm swaybar is a swap onto the GR/GV.
Old 04-11-2014, 01:34 PM   #79
Traumlik
Member#: 248805
^^ This
From looking at the intake piping, it seems to me that except for the final little bit right before the turbo, the pipeworks look like they are "mandrel bends".
From the looks of the intake scoop, I wonder how directly the intake is drawing air straight from the front without any blockages. Drawing fresh air straight from the front of the car in a ram-air kind of manner has a huge effect on the IAT (intake air temps) and how the engine / ECU responds to heat soaking. But I think because of reliability considerations, most manufacturers take a more conservative approach and do not have a wide open front facing intake.
Traumlik is offline   Reply With Quote
Old 04-11-2014, 01:41 PM   #80
Redeemed77
Member#: 378138
2019 Stinger
You'd be surprised at how unrestrictive most ugly and convoluted intake pipes are these days. Manufactuers don't leave HP on the table because HP is a major selling point for performance cars and cars in general. They spend millions in R&D to deliver maximum power, the most consistent power, best driveability for all situations, and probably most importantly, reliability. Aftermarket companies need to be very careful when designing parts and must bench test the OEM part vs the aftermarket "solution". Just because it looks ugly and restrictive does not mean that's really the case and just because the aftermarket part can flow way more air doesn't mean the motor can do anything with it.
Words of wisdom...very true!
Apparently GM not only likes cover up's (lol) but they also do half ass work, or did, on their G8's V8.
Redeemed77 is offline   Reply With Quote
Old 04-11-2014, 02:34 PM   #81
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Originally Posted by Traumlik View Post
^^ This
It's the same exact intake layout as the previous gen, even the intake snorkel is the same. The snorkel pulls air from the air pressure area (measurable pressure only occurs at 60+mph speeds) at the grill and the snorkel is blocked off from the engine bay by some rubber flaps on the hood. It's a good a setup that keeps IATs lower and consistent and throttle response as snappy as possible. It's been well documented that the stock intake can flow way more air than even a Stage II setup can inhale, at least on the EJ25 cars. Short of perhaps removing the silencer to gain some more induction noise, there's not much of anything left on the table with the airbox and snorkel.
Old 04-11-2014, 02:43 PM   #82
Redeemed77
Member#: 378138
2019 Stinger
Interesting, good info
Old 04-11-2014, 02:53 PM   #83
Traumlik
Member#: 248805
^^ Yes, snorkel was the word I should have used. It is very good to know that the stock intake can already flow way more air than the (stock) engine can handle -- if it is enough to feed a 25% larger EJ25, it has to be enough to feed the smaller FA20. But having measurable pressure only at 60+ mph is a little disappointing even when it is not at all surprising.
Old 04-11-2014, 03:57 PM   #84
Mishimoto
Member#: 207954
Please excuse my ignorance, but what is the "milk jug" for? And what advantages / disadvantages might there be in removing it?
This "milk jug" serves as a resonator for the factory intake system. Among other purposes, this component reduces intake noise. Many enthusiasts choose to remove this to promote a louder noise from the turbocharger.
We shall see! We have quite a bit of testing and development to do!
Originally Posted by RallyDrivR13 View Post
Mishimoto KICKS AZZ, I will be using all the products they have available for my 2015 STI
Thanks for following! We will be starting development on the new STI soon as well.
With what these guys are doing here for the board I agree, I like to reward them with a purchase if they come up with something that gives good gains at reasonable cost.
Thanks! It is our pleasure to provide this information. We will have numerous components available, all products will be fully tested to ensure safe operation as well as optimal performance. The dynojet will not be getting any days off!
Originally Posted by mikereiser View Post
I don't know how deep/where you guys are digging into this car, but Im curious about the design/quality of the oil pickup.
My intentions with my 2015 is to keep it pretty stock, just an accesport and probably a downpipe, but I also want to fix any reliability issues with it. I'm curious if 1) it's the same part that we see on the ej255/ej257 and can use aftermarket ones already available and 2) if different, are they still using the flux/braze design that is known to fail
I appreciate the videos, some very good information.
Thanks for the kind words! Although we do not have plans to drop the pan, we should be able to use part numbers to see if the pickup remains the same from the EJ. If not it would be great to take a look and check out the construction/design.
Thanks for watching!
Great points! In developing several other intake kits we have found that the factory units are usually fairly efficient. Despite this we have been able to provide improved power output without effecting long term reliability. We will be performing extensive testing on both the factory intake system as well as the components our team develops to be sure we are providing optimal, yet safe power.
Thanks for your comment!
Mishimoto-
Absolutely! Unfortunately the new rack mounting setup is completely different than previous generations. Check it out below.
Mishimoto is offline   Reply With Quote
Old 04-11-2014, 04:15 PM   #85
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
At least it appears that you can upgrade the front sway bushings in ~4 minutes with just one socket+wrench!
oaklandish_WRX is offline   Reply With Quote
Old 04-11-2014, 10:24 PM   #86
mikereiser
Member#: 291941
2010 Wrx sedan
I'm also curious as to the strength/design of the stock intercooler, my 2010 end tanks were separating with only a downpipe and a tune, I'm hoping this intercooler can handle higher than stock boost levels.
mikereiser is offline   Reply With Quote
Old 04-12-2014, 04:27 AM   #87
mrz415
Member#: 334988
2015 Subaru WRX(CVT)
Ice Silver Metallic (ISM)
One more picture/photo request for MISHIMOTO,
once again its in regards to the LED head lamps...
can you take a picture of the back of the LED head lamps..
Subaru (soa) said the LED head lamps are not compatible . . .
so if possible for reference sake. . .
mrz415 is offline   Reply With Quote
Old 04-12-2014, 02:10 PM   #88
nicsye
Member#: 385676
2015 WRX
Default Hitch options?
Mishimoto,
I know this isn't exactly your cup of tea since it isn't performance related, but you're the only guys that have looked at the underbody in enough detail to perhaps answer this question...
What are things looking like for trailer hitch options? I assume the Curt receiver for the 2014 sedan will not work. Tried finding info online for the 2015 to no avail. I hope something comes out soon, I want a bike rack and not in the form of a fugly roof rack!
Something that sits behind the diffuser and pokes out the JDM brake light hole would be soooooo ideal
nicsye is offline   Reply With Quote
Old 04-14-2014, 03:27 PM   #89
Mishimoto
Member#: 207954
Indeed, very simple!
Check back in a bit later this afternoon. Our next video features information about the stock TMIC and intercooler pipe!
Absolutely! Check out the images below and let me know if you need any others.
Originally Posted by nicsye View Post
Mishimoto,
Not a problem! We would be happy to help. I skimmed some of the Curt install guides and it looks as if they use the holes under the heat shields for the mufflers. We snapped a few shots of this area, which was simple now that the exhaust is removed. Let me know if you need any other images!
Thanks for all the questions and comments!
Old 04-14-2014, 05:13 PM   #90
rwfloberg
Member#: 327538
2012 WRX (307/344)
This is great to see a company responding to requests.
Kudos.
rwfloberg is offline   Reply With Quote
Old 04-14-2014, 05:27 PM   #91
Redeemed77
Member#: 378138
2019 Stinger
Gosh....you all are helping us all out with all these pictures and info, I cant say it enough...THANK YOU!
Old 04-14-2014, 05:54 PM   #92
Mishimoto
Member#: 207954
Kudos.
Sure thing! The car is just around the corner so capturing images is simple. Keep the requests coming!
Old 04-14-2014, 05:58 PM   #93
Mishimoto
Member#: 207954
Check out the next video in this series! In this installment we highlight the intercooler and piping for the 2015 model. We also compare this to the 2008-2014 intercooler! Check it out below or on our Engineering Blog!
Follow up with any questions or comments!
Old 04-14-2014, 06:34 PM   #94
Wriggly1dog
Member#: 382247
2015 WRX Limited CVT
Dark Gray
http://youtu.be/zRRq2vG-koc
Videos and posts are great.......but who's that Jason guy?
Wriggly1dog is offline   Reply With Quote
Old 04-14-2014, 07:01 PM   #95
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Mishimoto: please review the actual CVT and how it drives. I'm surprised this topic was not touched so far in any detail.
moonrider_99 is offline   Reply With Quote
Old 04-14-2014, 07:03 PM   #96
Wriggly1dog
Member#: 382247
Dark Gray
I have one.....it goes Zoom zoom.
Old 04-14-2014, 08:08 PM   #97
poodlchu
Member#: 286746
2015 WRX
Ice Silver Metallic
Keep it coming guys! These reviews are great!
poodlchu is offline   Reply With Quote
Old 04-14-2014, 10:31 PM   #98
Redeemed77
Member#: 378138
2019 Stinger
Good stuff.
Old 04-14-2014, 10:48 PM   #99
mikereiser
Member#: 291941
2010 Wrx sedan
Thanks for the video. Looks to me like the intercooler is still going to be a weak point. Also looks like previous aftermarket intercoolers will possibly fit with different piping. I hope so, maybe my process west will fit.
Old 04-14-2014, 11:12 PM   #100
boost-o-matic
Member#: 248364
2010 Huevos grandes
WRX Dom 1.5XTR E85 silver
Do you plan on being the guinea pigs by pushing the CVT to it's breaking point? I remember hearing a few years ago that CVT's weren't really capable of supporting high output engines. Surprised frankly to see one in the WRX. What will be the limiting factor with the CVT, and what are the expected upgrades to it in order to be able to support more power?
Also, haven't seen anything on this yet, but how does the size of the turbo compare to the outgoing model?
boost-o-matic is offline   Reply With Quote
