Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 09-22-2019, 12:27 PM   #251
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Originally Posted by Subarudunk View Post
Compared to my 2004 and 2007 Sti this one feels very hard to drive smooth. The clutch is very light and seems to engage higher than on my previous cars. Anyone else experience this?
It makes shifting from 1-2 a pain. Thinking about getting new engine mounts and rear diff bushings to see if it makes shifting more solid.
Sadly the STI is light-years better than the WRX in that regard.
I think you'll get used to it after some time. Try driving around in intelligent mode for a while to see if that helps at all. My wife struggled for a while even in sport mode.
If you're still unhappy, maybe the Group N trans mount, diff bushing inserts and shifter bushings would help? You could also try bleeding the clutch fluid.
WRXnick16 is offline   Reply With Quote
Old 08-02-2020, 10:01 AM   #252
Michaelepstein86
Member#: 516880
Default Way too much lumbar
Originally Posted by Scorpius View Post
Title states it all.
Head unit has a rattle inside it. It drives me nuts. I don't really want the dealer tearing the dash apart to fix one rattle and make ten more.
What bugs you on your 2019 WRX and STI?
I got a used 18 with the recaros and the Lumbar has been driving me insane. Does any one know if there is a way to REDUCE the lumbar support? Itís like being punched in the back every time I drive this thing!!!
Michaelepstein86 is offline   Reply With Quote
Old 08-02-2020, 12:33 PM   #253
Mr.Impreza.
Member#: 480424
2018 WRX STI....around 5,000KM started to get rattles in both front door cards and rear left door card. Also a little around the front dash on right side.
I installed front and rear tower bars and all the rattles went away ^__^
Mr.Impreza. is offline   Reply With Quote
Old 08-02-2020, 05:09 PM   #254
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
Hummm, not sure about light years better. I own both VA STI and WRX and while they are quite different in their own ways I can shift the WRX as smooth as my STI no problem.
As you said, just need to get use to the clutch and throttle.
If I was to make a suggestion, I'd get the AP Stage1 as it cleans up the throttle response quite a bit to the point it makes shifting a lot more consistent.
oichan is offline   Reply With Quote
Old 08-02-2020, 10:30 PM   #255
Arcanum_STI
Member#: 511103
2019 WRX STI
I have a 2019 STI bought brand new last year so far 16,000 miles. The only thing that annoys me is the brake - squeal when pressing the brake pedal.
Arcanum_STI is offline   Reply With Quote
