Welcome to the North American Subaru Impreza Owners Club Wednesday October 21, 2020
Old 11-09-2018, 12:58 PM   #76
Fahrenheit85
Member#: 488754
Originally Posted by SirBrass View Post
Has anyone had an issue where in AA maps tries to interrupt with a muted message, audio you were listening to shifts to rear speakers only and never comes back to the fronts without turning the car off then on again?
It's only happened once and I have changed maps alerting to mute all so that even "alerts" won't get through audibly.
It's an AA issue and is fixed in the beta version of the app.
Fahrenheit85 is offline   Reply With Quote
Old 11-09-2018, 01:02 PM   #77
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Thanks. I'll try and go hunt that down.
Is it AA beta or Google maps beta that fixes it?
SirBrass is offline   Reply With Quote
Old 11-09-2018, 01:21 PM   #78
Fahrenheit85
Member#: 488754
AA I believe. I researched the issue when I had it and just decided to wait till it updates itself
Old 11-09-2018, 06:17 PM   #79
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
I couldn't find a beta program for AA but did find one for Maps.
Old 11-09-2018, 06:22 PM   #80
get_schwifty
Member#: 485973
2018 WRX STI
Red
Those aren't substantial downsides really. You can get 30k out of good max performance summers (the class of tire the WRX comes with). Paired with a winter wheel and tire set you can double the time you would otherwise have if you ran one set year round AND you don't give up performance.
UHP all seasons under perform in the cold compared to any winter tire, and under perform compared to any max performance summer tire in the warm. By performance I mean braking capability especially in the wet.
A/S's are compromise tires at best. If you've got a standard grocery getter, it's fine. But a performance car really does need the best gripping tires for your budget for the conditions. So you can't afford two sets of wheels and tires, you're going to be spending a good deal on the best all out A/S's out there.
I'd recommend Michelin A/S3+'s. But I hope you don't get more than very light snow.
I probably should have worded it as "trade off" instead - but you get what I mean - spend a bit more and invest a bit more effort and get more performance year-round as a result.
I ran the A/S 3+...great tire, but in regards to snow, I was most comfortable using it to drive home once the snow started and not using it in anything other than the lightest of accumulation (mind you, it was on a RWD BRZ...but even on a WRX there would still be similar concerns in regards to stopping.) This time around, partly based on all of the feedback here, I'm running all-weather Nokians for my winter tires and plan to keep using summer tires on my fun car in the warmer months.
get_schwifty is offline   Reply With Quote
Old 11-09-2018, 06:26 PM   #81
get_schwifty
Member#: 485973
2018 WRX STI
Red
Originally Posted by Chas2 View Post
Really I would be more worried about you and those around you, as your car spins out of control in even the least bit of slush
Fair point...that is of slightly greater significance.
Old 11-09-2018, 06:33 PM   #82
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
That's a decent setup. Nokians are known for being worth the small fortune that they cost. We've got winter Nokians on the outback (bought in July. The previous owner used them as year-round tires) and they work well.
Old 11-11-2018, 11:54 AM   #83
MtnXfreeride
Member#: 228010
2019 WRX Limited
Crystal White Pearl
Happened to me at least 2x.
MtnXfreeride is offline   Reply With Quote
Old 11-11-2018, 06:31 PM   #84
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
Anyone know whether the steering column plastic is just a snap together or not? I couldn't find a screw holding the top and bottom halves together.
I ask because I was cleaning my car today and figured out where the rattle was coming from inside the steering column cover.
oichan is offline   Reply With Quote
Old 11-11-2018, 09:05 PM   #85
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Happened again to me today, and it repeated itself upon a restart too. Then it fixed itself and didn't repeat. No clue why. I'm signed up for beta on maps and the beta version out now was supposed to have fixed it. However, it did this even without AA being active on the HU and it had all audio in rear-only including HU radio. So my guess is that it's a bug in the HU firmware.
Which means I doubt it'll ever be fixed despite the HU being able to connect to wifi to check for updates.
Old 11-14-2018, 02:20 PM   #86
Aleja333
Member#: 494021
2018 WRX STI
I have a 2018 STI with very low miles, both the glove compartment and dash have a decent rattle that drives me nuts. I sometimes drive with the glove compartment open just so it's quiet.
Aleja333 is offline   Reply With Quote
Old 11-14-2018, 10:43 PM   #87
Chas2
Member#: 486914
2019 WRX Limited
CWP
In other cars I have had a latch adjustment does the trick. Maybe two screws....
Chas2 is offline   Reply With Quote
Old 11-14-2018, 11:09 PM   #88
littledrummerboy
Member#: 94408
17 STI Sport-Tech
20 Corolla Hybrid Premium
Pop off 2 clips just under the gauge cluster under the cloth-like shroud, take off the steering wheel (the hardest part... lots of youtube guides for this), then remove the two screws that are now visible with the steering wheel off. If you have push button start, you have to pop off the cover blank where the key cylinder would be... then separate the top and bottom halves of the steering column cover.
littledrummerboy is offline   Reply With Quote
Old 11-15-2018, 12:02 AM   #89
oichan
Member#: 492327
19 WRX 16 STI
Thanks, that makes sense. I wonder if I can crack open the halves partially to get a peak inside without removing the steering wheel. I’ve removed steering wheels on past cars so not a big deal but rather not mess with the SRS if I don’t have to..
I think maybe the wiper/turn signal stalk module might be making the noise where it attaches to the steering assembly. Will have to see if I can mute the noise while holding it down tomorrow while going over the same rough roads. Only makes the noise when the plastic is cold though.
Old 11-15-2018, 07:17 AM   #90
littledrummerboy
Member#: 94408
17 STI Sport-Tech
Thanks, that makes sense. I wonder if I can crack open the halves partially to get a peak inside without removing the steering wheel. Iíve removed steering wheels on past cars so not a big deal but rather not mess with the SRS if I donít have to..
No problem I don't think you'll be able to separate that part you want to look at without taking off the steering wheel, though. The 2 screws are right by the stalks just behind the steering wheel so its pretty secure right at that area. I was looking at that area this morning before leaving for work and no matter how I rotate the steering wheel, I can't get a clear shot at those screws. Good luck though.
Old 11-15-2018, 07:31 AM   #91
oichan
Member#: 492327
19 WRX 16 STI
Got it, thanks!
Old 11-15-2018, 03:16 PM   #92
humpthebobcat
Member#: 443793
2016 WRX m6 ISM
2005 F-150 FX4
My steering column was making a noise with it out all the way, pushed it in just a tad and the noise went away...
humpthebobcat is offline   Reply With Quote
Old 11-15-2018, 06:54 PM   #93
oichan
Member#: 492327
19 WRX 16 STI
Huh! Thanks, I will try this tomorrow. I can't remember if I had mine telescoped all the way out but I will push it in a bit.
Old 11-16-2018, 08:49 AM   #94
oichan
Member#: 492327
19 WRX 16 STI
My steering wheel was only telescoped about half way, but pushed it in another 10mm. It was kind of warmish this am at 33F so not sure if the setting change helped or if the temp was just too warm but no rattling.
Old 11-16-2018, 02:23 PM   #95
evan_sti
Member#: 493102
I posted a solution to this issue on page 3, here's what I did to completely solve the issue. Granted, this was a week and half ago, it may be fixed in a normal release by now.
""For those of you struggling with Android Auto issues like I was, specifically with the volume control being stuck on "maps" when you plug your phone in / volume in rear speakers only, there's a beta update for Google Play Services that appears to fix the issue. You'll have to go into Settings > Apps > Google Play Services > More info, that takes you to the play store where you can opt-in for beta testing, then you'll receive the update to version 14.5.75.
Hope this helps others out there that were extremely frustrated with AA not working correctly.""
evan_sti is offline   Reply With Quote
Old 11-16-2018, 03:56 PM   #96
Sean Mac
Member#: 195837
2013 Subaru WRX
Contemplating trading my 2013 wrx limited in for a 2019 STi... should I reconsider?
Background - havenít modified my current wrx but have the stage 2 parts lying around I never installed. Do not plan to mod the car but want a fun car to drive around.
Sean Mac is offline   Reply With Quote
Old 11-16-2018, 04:17 PM   #97
oichan
Member#: 492327
19 WRX 16 STI
STI is definitely fun to drive and probably more so on the 19ís. Do it!
Old 11-19-2018, 08:48 PM   #98
TurboWRX
Member#: 7632
2019 STI Limited
Lapis Blue
The rigidity and suspension of the 19 STI is epic... previously had a 12 STI and a 15 Golf R and the STI is the most fun of the bunch by far IMO. I still can't get over how great the stock suspension is on this car.
TurboWRX is offline   Reply With Quote
Old 11-19-2018, 09:49 PM   #99
Sean Mac
Member#: 195837
2013 Subaru WRX
Thanks. I had a chance to quickly drive a friends and the suspension was night and day when compared to my car.
Old 11-20-2018, 06:39 PM   #100
oichan
Member#: 492327
19 WRX 16 STI
Not really a complaint, but I've been noticing on my WRX it making a high pitched noise while slowing down (without the brakes) just coasting below 15mph. It almost sounds like a faint squealing of the brakes, but I think it's the ECU or something electrical making the noise. Might be the steering, not sure. It's not the stereo.
I have good ears and since I didn't notice this earlier, I'm thinking the colder weather has something to do with it...? Anyone else hearing such noise?
