Welcome to the North American Subaru Impreza Owners Club Friday October 23, 2020
Old 03-03-2014, 12:43 AM   #1
cmyles
Member#: 275572
2007 Built STi
Default STi Blower Motor Replacement
Hey everybody,
I have a 2007 STi and the blower motor bearings seem to be SCREWED!
When the car is cold the motor vibrates and sounds like its attacking my glove box. I've done some searching and all that comes up is forester replacements and such with the 3 screws and the motor just pops right out.
NOT THAT EASY ON AN STi.
So, you have to buy the whole unit essentially? Just looking at tech docs, and posts? It's been extremely cold, and heat is essential .. -40*C .. and the vibration is driving me insane.
If somebody who has done this could give me some tips, or even the best place to find the replacement, that would be amazing. Thanks guys.
Regards,
Chase
cmyles is offline   Reply With Quote
Old 03-03-2014, 08:08 AM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You might have to take the 10 screws out of the glovebox..
Old 03-03-2014, 08:23 AM   #3
cmyles
Member#: 275572
2007 Built STi
I know that, I've torn it all apart. And it looks like a pita to get it all apart.
When it warms up here I'm gonna try and separate it all
Looking for somebody whose done it so I don't **** something up .
But thanks for the awesome help !
Old 03-03-2014, 09:14 AM   #4
JonnyV2889
Member#: 197384
2006 WRX Ltd
Download your FSM and it will give you step by step.
JonnyV2889 is offline   Reply With Quote
Old 03-03-2014, 09:26 AM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Thanks for including that little tidbit about you actually torn it apart..
It really helps us get things done now doesnt it..
On your own now AFA im concerned
Old 03-03-2014, 09:34 AM   #6
cmyles
Member#: 275572
2007 Built STi
Wow, this forum is really filled with useless ****s isn't it..
I'll figure it out.
Old 03-04-2014, 01:09 PM   #7
subyrooo
Member#: 360527
I did this before on my 07. It's not as intimidating as it looks.
Just remove the glove box first. There's only one electrical plug for the fan motor. The entire assembly comes out as ONE piece. IIRC, you can't remove the motor from the housing.
Best place to find a replacement is ebay/junkyard/part-out threads here.
subyrooo is offline   Reply With Quote
Old 03-08-2014, 02:42 PM   #8
Itsawagon37
Member#: 303384
04 Impreza WRX
my 04, the bearing went out, however its the recirculation door and under dash assembly, the fan itself is molded into that entire unit. I found one on ebay from a wrecked 02. its actually a really easy swap. Take the glove box out and there are 2 mounting screws up top and one near the consol. those screws that you see around the outer edge hold the halves together however there are 2 on the top you cannot see with it installed. Granted that was from the bugeye/blobeye generation but I would imagine its likely the same part...
Itsawagon37 is offline   Reply With Quote
Old 02-01-2016, 03:19 PM   #9
usernameTaken
Member#: 439462
2007 Impreza 2.5i
Newport Blue
I wanted to post a new thread for this, but I don't have enough posts. Hopefully this will show up on google for others who have the same problem.
The blower motor on my 2007 Impreza 2.5i started getting really noisy recently (gremlins in the glovebox ). I pulled down the blower assembly and removed the fan/motor. The bottom bearing was shot. Okay, easy enough I thought, just buy a new motor. Much to my dismay, I discovered that you're supposed to replace the entire assembly and not just the motor. That thing isn't cheap, and I didn't like the idea of finding a junkyard one.
Out of desperation, I just searched google images and scoured the pages for one that looked similar.
As it turns out, the blower motor from the 2001-2007 Nissan X-Trail (not even sold in the US, maybe Canada) is the same. The part number is
27225-8H31C
. There's a bunch of other numbers that reference the same part, but I had the most luck with that one.
Anyways, $60 shipped from ebay and it dropped right in.
Here's the old one:
http://i.imgur.com/FrOrulY.jpg
And the new one:
http://i.imgur.com/WUXCTDC.jpg
Hopefully this saves somebody else some money and hassle.
usernameTaken is offline   Reply With Quote
Old 02-01-2016, 03:34 PM   #10
BMOxXZz
Member#: 439464
waw great read, will need this when i replace mine this weekend.
BMOxXZz is offline   Reply With Quote
Old 02-01-2016, 05:27 PM   #11
z
Member#: 41762
04 STi
in ur Floriduh
Good find! Thanks for posting!
I went through this with my blower motor. (in the summer heat in Florida)
I was shocked that you couldn't just buy the motor also, and the new box/assembly was like $240 iirc.
I ended up lucking out and found a used motor only on eBay but I will definitely note this thread for future reference.
Old 02-04-2017, 05:33 PM   #12
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Good piece of information right there.
Bought that motor off ebay. Fit perfectly.
For those interested - you remove the blower housing, remove a single phillips screw in the bottom of the motor (below the motor connector), and pull hard. The old motor will slide out, though it will be pretty stubborn.
Shove the new one in, swap on the old fan, and reassemble. Pretty easy.
sniper1rfa is offline   Reply With Quote
Old 10-15-2017, 06:02 PM   #13
dbrown89441
Member#: 476117
Thumbs up
Thank you, usernameTaken!
Your advice worked like a charm...
The hardest part of the motor replacement was working the old motor out of the assembly, but nothing a rubber mallet and some patience couldn't fix. Much less painful than paying $250 for an entire blower motor assembly!
In searching for Nissan blower motor 27225-8H31C, I found that it fits not only the Canada 2001-2007 X-Trail, but that model is also the blower motor for the US 1997-2013 Nissan Maxima.
I did go with the aftermarket 27225-8H31C on eBay. Just $40!!
(Amazon has it with Prime shipping for $50)
These Nissan part numbers are interchangeable:
27225-8H31C, 272258H31C, 27200-9H600, 3J110-34300, 27225-95F0A, 272009H600, 3J11034300, 2722595F0A
dbrown89441 is offline   Reply With Quote
Old 10-15-2017, 11:45 PM   #14
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Good find on the alternate PN's.
RockAuto only shows this.....https://www.rockauto.com/en/catalog/...wer+motor,6916 and it has a note for.....WRX TR
Shrug.
Old 12-11-2017, 11:45 PM   #15
Tsubadu
Member#: 476228
Hey guys! A little confused here..
I got underneath the dash and removed the foam-lined cover at the bottom of the assembly and found the single screw that I believe sniper1rfa mentioned. It has a green QC mark on it or something so I was kind of afraid to remove it. Even if I did remove it, I can't see it doing much, everything looks pretty well sealed together.
But do I indeed remove this screw and what part should I be pulling on?
Thanks!
Tsubadu is offline   Reply With Quote
Old 02-06-2018, 08:13 AM   #16
crisco555
Member#: 56339
2005 saabaru x 2
"wash me"
Been looking for this info for a long time! Thanks just ordered mine.
crisco555 is offline   Reply With Quote
Old 07-24-2019, 09:19 AM   #17
Roland3
Member#: 404510
2005 wrx hatchback
white 169K & counting
Got you beat!! Just dropped that description of the Nissan blower motor into Ebay and found it for 26$ shipped. its obviously a Chinese motor but for my 05 impreza wrx, with 204K miles on it going to give it a shot.
**UPDATE** installed the motor and it works great, make sure to put the screw in the back as the fit is a little loose on the press fit but other than that can beat the price! it does weigh less so im guessing less copper in it but who cares, the AC is blowing and defrost is working.
https://www.ebay.com/itm/Fit-for-Nis...72.m2749.l2649
Roland3 is offline   Reply With Quote
Old 08-31-2019, 07:26 PM   #18
06hawkeyeSTI
Member#: 374846
06 Impreza WRX STI
Midnight pearl
Just did this my 04 Sti, it was an exact replacement. Identical motor and replacement was very easy, the old motor came right out of the housing. I wish I could buy the guy who figured this out a beer! For sure saved me a lot of money
06hawkeyeSTI is offline   Reply With Quote
Old 09-08-2019, 03:48 PM   #19
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Well crap, found this thread too late! Bought a new oem a few months ago. The original lasted over 100k in Utah, so surely the new one may last longer where I live now. It's also messed up my car is also a 07 2.5i, like UsernameTaken, Dang it!
Maybe someone can change the thread title to include the part about an alternative to oem.
