Welcome to the North American Subaru Impreza Owners Club Wednesday October 21, 2020
Old 03-04-2010, 01:10 AM   #1
crrider80
Member#: 184789
Default 5eat to 6mt/5mt swap questions. (05+ LGT)
Hi everyone. I'm looking to do a manual swap on my 05 LGT. I've heard reasons not do perform this swap ie: "It would be more feasible to trade in your car for a manual LGT" or "An IPT upgraded trans would be easier" First of all, it is not at all feasible in my case and the feedback from a MT cannot be simulated from a subaru 5eat. If I did so, I would have more payments and a much slower car. I have yet to see a 5eat to MT conversion. A manual swap would enable me to unleash more power than my 205k 5eat can not handle. Being mechanically inclined, I am up for a new project and a challenge. I know I will be needing the following.
- Manual driveshaft
- Manual cross braces (possibly?)
- Pedal box assembly
- Master, slave
- R160 diff
- And a plethora of wiring
I understand a Spec-b or 4eat drive shaft is compatible with the 6mt trans. and that the ECU and TCU are seperate so a MT ECU may not be necessary. It would be nice to keep my current 5eat ecu so I can retain my tune.
My questions are:
-What are the differences between the GD's Pedal box assembly and that of the Legacy's? Will I be able to use a GD pedal box?
-Can the 5eat cross braces be altered to fit a manual?
-What type of wiring will be needed?
Other questions may arise. Thanks in advance guys.
~Steve
crrider80 is offline   Reply With Quote
Old 03-04-2010, 12:05 PM   #2
JohnnyGT'08
Member#: 199588
2008 Legacy GT
There is a reason it has never been done, it simply is not worth it. If you want a manual that bad, bring your car back to stock, sell it,and buy a comparable 5MT car.
JohnnyGT'08 is offline   Reply With Quote
Old 03-04-2010, 01:51 PM   #3
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
There will always be opinions on it, but I think the reason it hasn't been done is cause there are so many LGT's out that are 5mt's still, the rarity bug hasn't hit on the newer ones yet.
Once you get passed the petals, and basic wiring, you're going to need an ECU, the 5eat ECU is going to hate the fact there is a 5mt trans hooked to it, and Idk what will arise from that. Just an additional comment. There is a guy here in AK that did a 5mt to a sti swap on his 05, so if you're serious you could pm me and I'll let you know who so you can ask about axels cause he has a huge issue with axels I remember that. And drive shaft.
greenspeed is offline   Reply With Quote
Old 03-05-2010, 08:41 AM   #4
Dodik
Member#: 122609
2002 Outback H6 BE
82 GS750E
if you find ecu tcu and tranny from 05+lgt spec b or something along those lines than it shouldn't be that difficult imo. first find ecu tcu pinouts to see whats different and go from there. gl
Dodik is offline   Reply With Quote
Old 03-29-2010, 10:25 AM   #5
20thgti2lgt
Member#: 155284
2005 M3
Alpine White
i actually have an 05 LGT ECU for 5MT sitting around, let me know if you do this
20thgti2lgt is offline   Reply With Quote
Old 03-30-2010, 02:41 PM   #6
RHollywood
Member#: 222027
2005 LGT
I think its more trouble than its worth. Theres going to be alot of headaches whole doing a swap like this.
RHollywood is offline   Reply With Quote
Old 03-30-2010, 07:31 PM   #7
i<3mylegacy
Member#: 215206
+1000000000000
i<3mylegacy is offline   Reply With Quote
Old 03-30-2010, 10:43 PM   #8
Jubert69
Member#: 167739
15 Forester
NA dat gas mileage
http://forums.nasioc.com/forums/show....php?t=1863125
WRX, but wiring is going to be very similar.
May or may not help you. Let me know if you have any questions.
Jubert69 is offline   Reply With Quote
Old 01-02-2011, 03:36 PM   #9
climberd
Member#: 183019
05 LGT Stg3 Wgn
bump! This has been done twice at least on the LGT, and documented thoroughly on legacygt.com.
climberd is offline   Reply With Quote
Old 01-02-2011, 07:29 PM   #10
loose Subie
Member#: 262067
Wire a microtech computer in, get rid of all the other ecu's take it back and get it tuned. That ecu and others like it can control everything water meth injection timing and duration, run down times,boost extra injectors say for running pure methanol whatever you want. Not sure how much they are in the states but there like $1500 cad. All you need is a wiring diagram for your car and away you go.
loose Subie is offline   Reply With Quote
Old 07-28-2011, 10:00 PM   #11
cashjac
Member#: 261262
noob here
have some problem about 6mt swap
I have a 2010 legacy GT 5EAT
and want to swap the STI 6mt
but my local tuner says STI just can't fit with my car cause the different design
can anybody helps??
my goal is to make 400~450 whp so the strong transmission is needed.
thanks a lot
BTW, is the legacygt.com down???
cashjac is offline   Reply With Quote
Old 08-01-2011, 04:44 AM   #12
jab83
Member#: 284516
Its not down. And I'm no help here cause i know nothing about the new ones i'm 2nd gen. But I know that subarus are pretty much lego's lol.
jab83 is offline   Reply With Quote
Old 12-24-2019, 12:44 AM   #13
MitchS134
Member#: 510062
2006 Outback 3.0R
Garnet Red Pearl
Originally Posted by cashjac View Post
noob here
can anybody helps??
thanks a lot
Bump with similar question - looking to do a EZ30R 5EAT -> 6MT swap this summer and interested in learning more about the wiring and how to pull it off correctly. I'm sure my shop can do it but any extra info I have going in would be a great help.
MitchS134 is offline   Reply With Quote
A few Engine Swapping Questions. 05 WRX shortblock into an 05 2.5rs CousinVin Newbies & FAQs 2 03-18-2010 05:13 PM
Any shops in the NY area that can perform a 4eat to 6MT sti swap?? Alan l. Tri-State Area Forum 6 09-11-2007 09:50 AM
swap questions, 05 STI into... zc911 Subaru Conversions 30 11-07-2006 02:16 PM
Legacy GT 5EAT to WRX 4EAT swap? Snoring Dog Transmission (AT/MT) & Driveline 0 07-11-2004 10:54 AM
RS 4EAT to WRX 5MT swap....? Boost4U Subaru Conversions 1 07-24-2003 07:30 AM
