Welcome to the North American Subaru Impreza Owners Club Monday October 19, 2020
Old 08-05-2020, 10:43 PM   #1
Haevn
Member#: 495950
2011 WRX
Default question about fuel and fuel psi
ok so here is my setup. BNM ELH with ewg up pipe, 44mm ewg, fp blue with port and 84mm housing, fp inlet, cobb sf intake, 1050x injectors, cobb fuel pump, TBE, torque solutions tgv deletes, torque solutions fuel rails with -6an lines, aeromotive FPR. i do have the cobb fuel pressure sensor to log with ap, now here is my question. i just noticed on my last log that my fuel psi goes up to about 62-63 psi cause i am running around 21psi of boost, but at the top of the rpm range around 5500 rpm the fuel psi starts to drop down to 55psi at 7k rpm. my afr during pull stays around high 10 low 11. would changing to -6 lines cause my pressure to drop a little since it is bigger lines for feed and return going back to the stock hard lines at the firewall? i am on parallel setup now.
here is link to log thanks much
https://drive.google.com/file/d/1vkh...ew?usp=sharing
Haevn is offline   Reply With Quote
Old 08-06-2020, 12:47 AM   #2
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
I can't view the logs because I need to request access.
Does your boost pressure taper at higher RPM's? If you have a 7 odd psi boost taper closer to your redline, your fuel pressure would drop by that much. That's my first thought.
viper_crazy is offline   Reply With Quote
Old 08-06-2020, 09:01 AM   #3
Haevn
Member#: 495950
2011 WRX
The boost holds 21 pounds all the way to red line
Old 08-06-2020, 11:57 AM   #4
Haevn
Member#: 495950
2011 WRX
Ok I changed permissions on file
Old 09-11-2020, 07:11 PM   #5
Haevn
Member#: 495950
2011 WRX
bump, just to see if anyone else able to help me out with this, thanks
