Welcome to the North American Subaru Impreza Owners Club Monday October 19, 2020
Old 09-08-2020, 12:27 AM   #1
Zeluhs
Member#: 505672
2018 WRX STI
World Rally Blue
Default [SOLVED!] 18 STI misfire on boost no CEL
[SOLVED!] When ever I hit 5+ PSI of boost I get misfire, no CEL so I can't tell which cylinder it is. I've put in new cold NGK plugs gapped to .025 and it's still bad tuner suspects bad coils since the ARF readings are normal until boost, he think's because of weak spark but before I spend 400 on a new set of coils I did some resistance readings on every coil and got .8k ohms on the first and about 7K ohms on the second for every coil. I compared them to a AutoZone replacement coil and got readings of 1.2K ohms on the first and 4.5 on the second. I'm going to get a new OEM coil from Subaru tomorrow to see what it's readings are but I doubt all 4 of my coils are bad unless the AutoZone coil is closer to OEM which I doubt. What are y'alls thought?
Mods:
Type RA short block
TGV delete
1050 CC injectors
AEM 340 Fuel pump
Cobb FPR
Cobb Fuel pressure sensor
Cobb FlexFuel
AIG AOS
Catless downpipe
Muffler delete exhaust
Zeluhs is offline   Reply With Quote
Old 09-08-2020, 08:13 AM   #2
Haevn
Member#: 495950
2011 WRX
Have you checked for boost leaks
Haevn is offline   Reply With Quote
Old 09-08-2020, 12:33 PM   #3
Zeluhs
Member#: 505672
2018 WRX STI
World Rally Blue
Yes tuner used a smoke machine and patched them all
Old 09-10-2020, 10:14 AM   #4
Zeluhs
Member#: 505672
2018 WRX STI
World Rally Blue
Default Update
Mods:
Type RA short block
TGV delete
1050 CC injectors
AEM 340 Fuel pump
Cobb FPR
Cobb FlexFuel
AIG AOS
Catless downpipe
Update New ignition coils have been installed and still misfires
Old 09-11-2020, 03:42 PM   #5
kharmicresonance
Member#: 461898
Pull your plugs and double check the gap?
kharmicresonance is offline   Reply With Quote
Old 09-12-2020, 12:50 PM   #6
Zeluhs
Member#: 505672
2018 WRX STI
World Rally Blue
I did when before I installed the new ones. Would it help to send a data log?
Old 09-12-2020, 01:29 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
so how do you know its a misfire? and did it misfire before the tune and other stuff?
subaru_gc8 is offline   Reply With Quote
Old 09-20-2020, 05:09 PM   #8
Zeluhs
Member#: 505672
2018 WRX STI
World Rally Blue
Default Solved!
Figured it out, first tuner I went to is a massive moron. It was a massive boost leak from the turbo L pipe to the intercooler. No idea how they missed that but I will never be going back to them. Had to go to Dallas to see AWDTuning they know subies.
