Welcome to the North American Subaru Impreza Owners Club Monday October 19, 2020
Old 09-09-2020, 12:35 AM   #1
Jp925
Member#: 510046
Default Ej257 experts, help identifying bolts!
Had my engine rebuilt, have most of the long block together minus the intake manifold. I have 2 bolts that don’t seem to have a home, wondering if any of the experts out there could shed some light on where these might go.
They look like coolant bolts, but I have the correct bolts on the crossover pipe, thermostat, and water pump.
Jp925 is offline   Reply With Quote
Old 09-09-2020, 04:58 AM   #2
niemkij
Member#: 141922
2017 Impreza Sti
Originally Posted by Jp925 View Post
Had my engine rebuilt, have most of the long block together minus the intake manifold. I have 2 bolts that donít seem to have a home, wondering if any of the experts out there could shed some light on where these might go.
A size would help. They look to be a M6 x 1.25 x 20? They could be bracket bolts or used at the ends of an oil tube.
niemkij is offline   Reply With Quote
Old 09-09-2020, 09:26 AM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Those are very generic bolt in our cars, could be used for multiple things. could be holding down wire harness, could be holding down cross piping, etc...
BlackFighter is online now   Reply With Quote
Old 09-09-2020, 10:17 AM   #4
cdska
Member#: 458809
2005 wrx wagon
My best guesses -
1 thermostat housing bolt
1 oil cooler line bolt 010406200 https://parts.subaru.com/images/part...3_03301039.png
cdska is offline   Reply With Quote
Old 09-09-2020, 03:28 PM   #5
truck7575
Member#: 516780
2008 Subaru wrx sti
Maybe oil pump bolts?
truck7575 is offline   Reply With Quote
Old 09-09-2020, 09:44 PM   #6
Jp925
Member#: 510046
Pulled the timing cover and checked the oil pump, all 7 are there.
Checked thermostat and cross referenced with parts picture online, the correct ones are in.
Same story for the water pump and crossover pipe, the correct bolts are in.
Whatís unique about these is the gap near the head of the bolt before the threads start. These couldnít be oil pickup tube could they?
Old 09-09-2020, 09:46 PM   #7
truck7575
Member#: 516780
2008 Subaru wrx sti
Definitely could be, did u switch to an after market pickup that came with bolts?
Old 09-09-2020, 10:19 PM   #8
Jp925
Member#: 510046
New OEM pickup tube, if I remember correctly the pickup bolts had a little 6 on them.
Old 09-09-2020, 11:57 PM   #9
blue wrench
Member#: 349542
I don't think they are oil pickup bolts, they are too dirty. Those bolts along with the oil baffle tray bolts are all usually pretty clean but tan-ish colored from the oil.
Kinda looks like a stock TGV bolt, or a valve cover bolt.
blue wrench is offline   Reply With Quote
Old 09-10-2020, 01:44 AM   #10
Jp925
Member#: 510046
I had wondered if they were valve cover but the rest of my valve cover bolts have that fat part to fill out the portion that presses against the seal.
They are definitely not TGV bolts, I have those in and they are way longer.
Old 09-11-2020, 11:26 PM   #11
Jp925
Member#: 510046
is the 8 on the bolt head a hardware grade rating? It seems like each set of bolts has a different number.
Old 09-12-2020, 03:42 AM   #12
05-rsx
Member#: 101188
MY07 WRX Wagon
They look like the pair of M8s that hold the A/C pulley on, but as someone has already mentioned they are pretty common and could be for anything - P/S pump (uses 3- 2 shorter and 1 longer), timing belt idlers (might've used another bolt instead which is why these ones look clean), etc
05-rsx is offline   Reply With Quote
