Welcome to the North American Subaru Impreza Owners Club Monday October 19, 2020
Old 09-11-2020, 02:04 PM   #1
GothamDrew
Member#: 503624
Default Cobb Catback Exhaust adding 20hp at 4k RPM?
Hi all, reading through the article below, it says that they manged to get some significant hp gains on a Subaru STI just from the Cobb catback exhaust throughout the dyno graph and around 20hp at 4k rpm. Does anyone know if this is accurate and achievable on a stock STI? I was under the impression catback exhausts on a stock STI doesn't really add any gains and only improves sound. Thanks!
https://dsportmag.com/the-tech/showc...-back-exhaust/
GothamDrew is offline   Reply With Quote
Old 09-11-2020, 03:19 PM   #2
ChongChong
Member#: 493104
Catbacks generally do not add much power-if at all. You can attribute these horsepower gains to testing variables such as dyno, location, etc. Most power gains will come from a
less restrictive downpipe because this is where most of the exhaust restrictions on these cars are.
ChongChong is offline   Reply With Quote
Old 09-11-2020, 03:36 PM   #3
Jedi03
Member#: 491095
2009 STi Blue
catbacks do flow more and a larger exhaust would allow for more top end flow...i would suggest look at more dyno's like suggested above to see how other factors affect the data
Jedi03 is online now   Reply With Quote
Old 09-12-2020, 08:00 AM   #4
Jay11STI
Member#: 492422
2011 STI
I guess if you are looking at actual hard numbers based on dyno plots and results then yeah. Like stated above i think this can also be attributed to testing on different types of dynos. When it comes to dyno results, there are so many variable factors that will dictate what kind of power the car will make at that time.
I wouldnt really look to far into this. Its just a catback we're talking about here. It doesnt make anything to write home about in terms of gains. Upgrading the down pipe and header is where the power is made on these cars.
Jay11STI is offline   Reply With Quote
Old 09-17-2020, 02:38 PM   #5
SprinterWRX2018
Member#: 477013
2019 STI Limited
Ice Silver Metallic
https://dsportmag.com/the-tech/2017-...aust-shootout/
According to the article above they tested 12 different exhaust systems on the same dyno, same exact sti. Could it be possible some cat back systems do increase power?
SprinterWRX2018 is offline   Reply With Quote
