Welcome to the North American Subaru Impreza Owners Club Friday May 14, 2021
Go Back   NASIOC > NASIOC Technical > FB Series Normally Aspirated Powertrain
View Poll Results: Please report your oil consuption here for the vehicle you own(ed)
2011-14 Forester - Excessive Consumption 13 13.68%
2011-14 Forester - Normal/No Consumption 8 8.42%
2013 Legacy - Excessive Consumption 2 2.11%
2013 Legacy - Normal/No Consumption 4 4.21%
2012-13 Outback - Excessive Consumption 4 4.21%
2012-13 Outback - Normal/No Consumption 5 5.26%
2012-13 Impreza - Excessive Consumption 34 35.79%
2012-13 Impreza - Normal/No Consumption 30 31.58%
Multiple Choice Poll. Voters: 95. You may not vote on this poll
Old 08-14-2017, 07:53 PM   #326
424wrx
Member#: 171948
20 wrx limited
world rally blue
Originally Posted by JordanOfGilead View Post
The dealer told me that they resolved the short block issue, but manuals drink some oil between changes, just not enough to be considered "excessive" by Subaru (about a quart every 4k). My excessive consumption may have been brought about by some recent abuse, I pulled a Saturn out of the mud a couple weeks ago. We will see how it turns out, but I don't expect to fail the consumption test.
how the hell does your dealer think that a manual transmission has remotely anything to do with motor oil consumption? did you laugh at them after that response?
Old 08-14-2017, 08:22 PM   #327
JordanOfGilead
Member#: 446722
2016 Impreza 2.0i
Dark Gray Metallic
No, I didn't, because it makes sense. With a CVT, the revs stay low when you aren't on the throttle. In a manual they stay wherever they are when you let off. If you engine break or downshift at all, it creates negative pressure in the combustion chamber during the intake cycle and, in cases with thinner oil like 0w20, can pull oil vapor up into the combustion chamber. Over time, this burns more oil than a CVT that keeps revs as low as possible when you're not heavy on the throttle and almost never engine brakes. The CVT can still burn about 3/4 of a quart between changes and varies from engine to engine. Their explanation makes sense and is consistent with what I have read elsewhere about both Subaru and other manufacturers that use 0w20.
JordanOfGilead is offline   Reply With Quote
Old 02-18-2018, 08:05 PM   #328
iandv23
Member#: 482281
is there such a thing as normal oil consumption for our cars?
mine is a 2010 subaru STI and been consuming oil despite good leakdown test and compression test.
Installed crawford V3 AOS and it helped a lot but during trackdays would still consume oil
iandv23 is offline   Reply With Quote
Old 02-19-2018, 04:33 AM   #329
GBMaryland
Member#: 430820
Well, with the 2013 outback the issue was bad rings.
I had a 1997 Honda prelude and I was getting compression of about 240 PSI per cylinder. The car had no performance issues, but I was burning a quart of oil every 2000 miles.
Eventually I decided to replace the engine with a JDM version. When I took the engine apart I noticed unbelievably light scoring on the number 1 cylinder wall. You could easily miss it if you didn't have a high-intensity light.
I guess my point is that it doesn't take much.
GBMaryland is offline   Reply With Quote
Old 08-14-2018, 12:49 PM   #330
~The_Duke~
Member#: 215109
2014 WRX-STi 5-Door
Plasma Blue
I recently switched from the 0w20 oil that is recommended to a 5w30 oil, this cut my oil consumption in half from what it was. Personally the 0w20 oil makes me uncomfortable...
I was going to through about 1.5-2 quarts per 5,000 mile oil change interval.
2015 Forester
~The_Duke~ is offline   Reply With Quote
Old 08-15-2018, 02:30 PM   #331
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
2015 Forester
Any notable performance decrease? Supposedly the lighter weight oil aids in fuel efficiency
Blur125 is offline   Reply With Quote
Old 01-17-2021, 06:16 PM   #332
Skeet6
Member#: 520409
My 2012 Forester was eating a quart every 750 miles or so near the end of her time with me - made it to about 245k.
Made no difference which oil I used.
Mike B
Skeet6 is offline   Reply With Quote
Old 01-31-2021, 11:56 PM   #333
newsubyguy
Member#: 522069
Default Interesting
This is an interesting thread. Glad someone is doing a poll.
newsubyguy is offline   Reply With Quote
