11-11-2005, 05:03 PM | #1 |
Member#: 79160
Vehicle:2011 WRX DGM |
replace oil pump at 117,000mi.?
I am going to replace the timing belt and the timing belt tensioner adjuster on my 97 OBS(ej22-mt). While I'm in there I plan on replacing the water pump,t-stat,cam seals,and the oil pump seal and o-ring.
My question is would you replace the oil pump or inspect and reinstall?
11-11-2005, 06:23 PM | #2 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
Are you having an issue with oil pressure? I would probably inspect/reinstall.
11-11-2005, 07:30 PM | #3 |
Member#: 16517
Vehicle:'13 BRZ |
Theres no need to replace the pump unless you are having an issue with it, just get a new seal clean it up and reinstall it.
11-11-2005, 07:31 PM | #4 |
Member#: 79160
thanks for the quick reply
No issues with oil pressure that i'm aware of. I found the inspection specs for the oil pump-tip,case,and side clearance. If its within spec it looks like I just might have saved $100 |
11-12-2005, 09:03 PM | #5 |
Member#: 32846
Vehicle:1998 Impreza L-SOLD Arcadia Green |
oil pump
I just helped a fellow the other day with his oil pump. Most issues with the oil pump are from the screws in the back coming loose. Just take them out, apply loc-tite, and tighten with a big handled phillip screwdriver.
Oil pumps aren't usually replaced unless the housing is cracked. -Charles- |
12-08-2005, 05:49 AM | #6 |
Member#: 85112
nevermind...
Similar Threads | ||||
Replaced Oil Pickup Tube - 2006 STi, 54,000mi Stock | Slaven | Warranty Issues & SOA Problems | 10 | 04-29-2010 06:19 PM |
Replacing Oil Pump Seal? | pittsburghscoobie | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 10-21-2009 09:22 PM |
replaced oil pump, now won't start | sureshot007 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-06-2008 03:35 PM |
Replacing Oil Pump on 1.8L - Advice Needed | speedblind | Service & Maintenance | 10 | 06-06-2005 10:08 PM |
Replaced front main seal and oil pump o-ring | archer | Normally Aspirated Powertrain | 4 | 12-28-2001 03:28 AM |
