07-03-2006, 03:57 PM | #51 |
Member#: 87653
South East
Vehicle:97 Supra / 17 GTR 16 Z06 / 07 STI / 05 Evo |
07-03-2006, 03:58 PM | #52 |
Member#: 51981
SCIC
Vehicle:03 fast wrx-e55 blue/desert silver |
[IMG][/IMG]
[IMG][/IMG] i think this guy can do it. mike moran can get 2200 whp from a small block chevy. if you take 4 cylinders away thats 1100 yay~! |
07-03-2006, 03:59 PM | #53 | |
Member#: 94350
07-03-2006, 04:40 PM | #54 | |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
07-03-2006, 05:02 PM | #55 | |
Member#: 94533
Vehicle:2006 FXT Limited Aspen white /w MT |
07-03-2006, 05:30 PM | #56 |
Member#: 117017
Vehicle:03 2.0fpred wrx!! blue |
if this idea does work out i wanna see video and dyno chart...watch out ams..
07-03-2006, 06:21 PM | #57 | |
Member#: 100878
07-04-2006, 12:49 AM | #58 |
Member#: 56468
Vehicle:04 Improved STI Dirty White |
Not for $50K.
07-04-2006, 02:11 AM | #59 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
EZ30R sleeved and bored out (forged internals & long rod too), built heads, GT47R, intke manifold (exhaust duh) and then all the supporting mods (fuel pumpS, injectors, rails, etc)....NOS to help make it easier
drivetrain should be interesting... 50k with hook ups and doing the work himself = possible 50k paying someone to do it = not very likely (R&D isn't cheap) |
07-04-2006, 02:56 AM | #60 |
Member#: 1140
SCIC
Vehicle:2000 S201 #78, '95 L '13 F150 Ecoboost |
I don't believe that that is a realistic goal for any subaru with that kind of budget, and I can't imagine why you would want something like that. If you want that kind of power for less $50k you'd might as well switch vehicles. It would be a lot easier to use a viper or a Z06. a Large displacement, high reving turbo motor would do the trick, although I wouldn't think it could be had for so cheap. Why does it have to be 1000whp? Is the 900whp car they have too slow?
07-04-2006, 02:03 PM | #61 | |
Member#: 104164
Vehicle:'95 Impreza 800+hp 9.1 152mph |
I got almost 700whp without sleeving the 2.5 4cyl. So wouldnt 1000 be possible in the 3.0 with just pistons and rods on the bottom end? Maybe not. Just thinking how to keep the budget down. |
07-04-2006, 02:17 PM | #62 |
Member#: 61749
yea i would think a ez30r with built internals, heads and a gt42r or gt47r will be more than enough for 1000awhp.
07-04-2006, 02:30 PM | #63 |
Member#: 1140
SCIC
How would you fuel this beast? How about cooling it? I'd like to see it when it's done in two months.
07-04-2006, 02:31 PM | #64 |
Member#: 38946
Vehicle:199? 6 diff ones bag o' skittles |
the biggest prob in all honesty wouldn't be the motor issues (we allready have broken the 800whp mark) as so much the fact the transmission which quite simply suck would NEVER hold that, built, frozen,whatever.....maybe if you went built auto rwd via adapter plate....
07-04-2006, 02:44 PM | #65 | |
Member#: 33782
07-04-2006, 02:46 PM | #66 | |
Member#: 33782
07-04-2006, 08:56 PM | #67 |
Member#: 38946
lol i didn't even read the budget part
07-04-2006, 09:38 PM | #68 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
$50,000.00 why not just buy a supra
07-05-2006, 03:19 AM | #69 |
Member#: 64673
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
I think the H6 can do it, given time. But I want to see the clutch that can handle it......Then the tranny.....then the axles.......
I watched a Camero shear off all the lug nuts today at PIR........... |
07-05-2006, 03:25 AM | #70 | |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2008 Black Miata |
07-05-2006, 04:38 AM | #71 | |
Member#: 38946
07-05-2006, 11:14 PM | #72 | |
Member#: 4498
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
The topic of 1000whp has been something we have been discussing for some time. Adding something like Alky injection only allows the engine to make the most of the available air, not create horsepower where additional air is not available. With the H6 at 3.0L, there are two limiting factors that make 1000whp challenging. First, the longer stroke puts some limits on RPM (as does the VERY heavy variable lift buckets). The second is of course the amount of boost you would need. As a rough calculation, 3.0Ls at 85% eff at 6500rpm at 40psi yeilds about 70 lbs/min of air. Using something around 10-11hp/lb/min of air gets you about 700hp. If you jump the boost to 50psi, you are talking about 80lb/min, or a bit over 800hp. You would then need a turbo that can flow that kind of air at those pressure ratios. A 40 couldn't do it, but a 42R could. You would be at the top of the PR map at 50psi, but still workable. If you then added a 200 shot of NOS, you would be in the right ballpark. If you really wanted 1000hp with no NOS, you would need something on the order of 60psi at 7000 rpm, which would be very very hard to do on any normal turbo. Even looking at a GT60, there is not enough PR height. If you could rev to 8000rpm at 45psi, you would be at 90+ lb/min, which might be tweakable to 1000hp. If you could increase VE at high RPM to 92%, 8000 rpm at only 40psi would be close to 1000hp, and right on the GT42 map. Just some food for thought. Even with a turbo, displacement makes a big difference. Jeff |
07-06-2006, 12:23 AM | #73 | |
Member#: 94494
Vehicle:2005 Element 92x Black |
Maybe a large twin-turbo design. Twin GT35R's maybe? |
07-06-2006, 12:43 AM | #74 |
Member#: 103518
Vehicle:2011 Subaru WRX Silver |
I know which vendor this is coming from, I spoke with them about a week ago and this was brought up so I'll chime in, but since Unabomber does not disclose who, I won't either, in regards.
BUT, as keanie says, a twin-turbo design could be called for possibly.. I know I've seen a couple custom built EJs with a twin turbo design, not to say that they'd make a whopping load of power like what this guy wants.. but its a start towards something. If Supra's can do it on an Inline-6, then can it be done on an H-6, sleeved and closed? These guys are highly reputable and based on that and my experience, can imagine they're well up to the ask as they seem. As usual. |
07-06-2006, 01:00 AM | #75 |
Member#: 103518
mm..k for jokes I had an idea..
http://www.turboneticsinc.com/turbo_thumper.htm By the time this baby spooled up................ yeah, it wouldn't spool up. Ever. |
Similar Threads | ||||
What is Variable Turbine Geometry and how does it work? | ka mano | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 26 | 10-22-2011 04:16 AM |
Is 280 WHP possible on stock turbo 2.0 | Rudywrx04 | Newbies & FAQs | 17 | 07-09-2008 09:29 PM |
Help me out: is this dealer desperate and how firm do I stand? | sonicblue | Off-Topic | 40 | 08-23-2007 12:37 PM |
Who is using Motul 8100 and how do you like it? | hauvis | Service & Maintenance | 9 | 09-05-2005 06:34 PM |
What is this "tornado warning" and how am I supposed to feel about it? | semabe | Off-Topic | 37 | 01-01-2005 06:24 PM |
