Welcome to the North American Subaru Impreza Owners Club Sunday May 27, 2018
Old 02-28-2007, 10:24 PM   #1
Jutboy
Member#: 114371
Default EJ22 to EJ22T swap
Ok, I'm really going to try to post this right. First I searched for at least half an hour and didn't find any answer. Then I tried my hardest to find the right section....so now the question.
I have a guy offering me a EJ22T crank, rods and pistons for $150. I was thinking about doing a swap but this seems like it might be more cost effective.
I understand my deck will be open but is that a big deal?
Please tell me your opinions on my decision, I'd appreciate any help. Feel free to tell me he's ripping me off or if you have anything to sell.
I assume I'm also going to need the turbo, turbo cooling, exhaust manifold and up pipe and down pipe.....is that right?
THANKS SO MUCH - Jutboy
Jutboy is offline   Reply With Quote
Old 02-28-2007, 10:31 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I am making 300 whp with the open deck and the turbo pistons myself....
Old 03-01-2007, 12:16 AM   #3
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Whao doug! You got 300whp!?
That with the Turbo Supercharged 2.2?! Where is the dyno graph, I wanna c!?
Sko is offline   Reply With Quote
Old 03-01-2007, 12:58 AM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Look how lean I was!
I have since replaced the 550s with 820s, and retuned it. Its easily over 300 whp at 22 psi.
This is a STOCK internal NA 2.2 open deck block with STOCK ej22t pistons and internals.
Old 03-01-2007, 01:17 AM   #5
IllNastyImpreza
Member#: 36333
98 RS
GT30R, closed deck madnes
dooooooooooood 150 bucks??? go for it !
IllNastyImpreza is offline   Reply With Quote
Old 03-01-2007, 01:36 AM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I also have the rotating assembly out of my 2.2turbo motor I'd like to get rid of. $150 seems like a fair price.
I have the heads as well.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 03-01-2007, 01:39 AM   #7
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
Yea, definitely. Not so sure you need the crank. Although my ej22t crank looks a lot nicer than a NA crank i used to have so there might be some advantages to it. The open deck is fine until you get into really high horsepower applications. go for it!
tonzo is offline   Reply With Quote
Old 03-01-2007, 02:23 AM   #8
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
like I said on USMB....the 22t and 22e cranks and rods are the same....
just get yourself a set of pistons, and start forcing some air on it!
Numbchux is offline   Reply With Quote
Old 03-01-2007, 01:34 PM   #9
IllNastyImpreza
Member#: 36333
98 RS
u sure about the rods? I don't see how subaru would put the same rods in a turbo engine with more HP....
but iether way, if they've got less Miles on em...
Old 03-01-2007, 02:08 PM   #10
Numbchux
Member#: 71658
'84 Brat
90% sure....
either way, eagle rods aren't that pricey, and the stock ones aren't very good....if you've got the motor apart, throw in some eagles and call it a day.
Old 03-01-2007, 02:41 PM   #11
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
the ej22t rods have been disputed for a long time with no real concrete evidence to support either side. at least that ive seen. but Numbchux is right, if you have an extra 300 just chuck in the better rods bbbuuuutt on the other hand. if you dont want to make more then 300 hp then these internals will do fine. if it breaks down on ya then id say replace things with forged internals. otherwise you're good to go
Old 03-01-2007, 02:41 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
90% sure....
How about I bump that up to 100% sure. Just like Ej18 rods are identical to early Ej20G Sti rods (and cranks). It may not make sense to some people that Subaru used the same forged parts across the board, but that's what they did.
As for the original question? Just buy the pistons if you can. You don't need the other parts...
Old 03-01-2007, 02:52 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
Just for reference, I just checked my Legacy parts catalog and they are showing 12100 AA030 for the rods for both the NA and turbo EJ22 engines.
And it does actually show 2 different numbers for crankshafts. The NA one is 12200 AA040 and the turbo one is 12200 AA050. I once asked the owners of CCR about this and they told me that there was no discernable difference between them. I have seen it claimed on the intraweb that the turbo one is shotpeened, and thus the different pn, but I have never found a tech document that would back that up...
Old 03-01-2007, 04:26 PM   #14
IllNastyImpreza
Member#: 36333
98 RS
^ good to know.... so at least get the turbo crank
Old 03-01-2007, 04:57 PM   #15
Numbchux
Member#: 71658
'84 Brat
I can think of 2 different local guys using 22e cranks in 22t blocks shooting for much more than 300whp.
the 22e crank is definitely forged, and the same dimensions.
Old 03-02-2007, 04:32 PM   #16
Jutboy
Member#: 114371
Thanks for the input guys - I think I may go for it......the only that worries me is my auto tranny.....I hear the turbo version should bolt up easy enough but I'm not sure if I want to spend all the cash....I'm going to rebuild the engine no matter what and I was thinking, while I'm at it I might as well do some performance upgrades.
Old 03-02-2007, 04:41 PM   #17
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
if you upgrade the valve body and torque converter then you should be alright with the auto. It all depends on how much power you are shooting for.
Old 03-02-2007, 04:42 PM   #18
Jutboy
Member#: 114371
I'm looking at just getting the pistons ~$50,the exaust manifold~50, the up-pipe~25, the crossmember~125, the turbo~75
The total there is about $325......that should be easily enough....besides some tubing thats all I need, right?
So, I'm still unsure if I need the Turbo version of my tranny....and how this will fit in my car.....I've done engine work but not any tranny work and didn't want to make this a huge project.
Old 03-02-2007, 04:44 PM   #19
Jutboy
Member#: 114371
Also red-devil, I'm so glad your around.....you and Numbchux are probably going to be the reason I'm doing this project. Can you PM me your instant messanger info or email address....or some way to contact you - I'd love to be able to chat .
THANK YOU SO MUCH!!!!
Old 03-02-2007, 04:48 PM   #20
tonzo
Member#: 94903
1996 Impreza Wagon!
Satin Black
oh yea, and as for transmissions, a lot of them are the same trannies in different cars. I'm not so sure about the automatics tho. They will all fit into your car tho. No worries.
Old 03-02-2007, 04:53 PM   #21
Jutboy
Member#: 114371
I think you posted Tonzo when I was typing.....how hard is it to upgrade the valve body and torque converter?...also how much about?.....my tranny has 120,000 on it and I probably it's about time to open it up and make sure everything ok......not that I know anything about it but my friends do.
Old 03-02-2007, 05:28 PM   #22
Matt Monson
Member#: 832
99 2.5RS, '85 911
The auto trannies (even on the NA cars) are stronger than the manual transmissions. I wouldn't worry about anything on the tranny other than maybe a fresh torque converter. They are known to fail around 125-150k mi.
And in case I wasn't clear above, I wouldn't spend a cent on the Ej22T crank. The Ej22e unit is forged and good for plenty of power...
Old 03-02-2007, 05:31 PM   #23
IllNastyImpreza
Member#: 36333
98 RS
^ auto good for more power you say? how much more?
Old 03-02-2007, 05:43 PM   #24
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
My homemade EJ22t "was" pushing 24-25 psi today. But the pressure plate couldnt handle the torque, so i have turned the boost down for now.
Old 03-02-2007, 06:22 PM   #25
Jutboy
Member#: 114371
The my auto would be able to handle the turbo fine?
This seems a bit hard to believe though I really, really want to.
It has begun: GC4 EJ22 to EZ30R swap. Slack Subaru Conversions 1584 01-14-2014 04:54 AM
Converting my EJ22 to EJ22T masky43 Subaru Conversions 8 05-20-2005 02:57 AM
Ej22 to Ej20g swap, difficult? d4d4d4d4 Subaru Conversions 3 03-28-2004 01:59 PM
SC EJ22 or EJ22T swap Witckraft Normally Aspirated with bolt-on Forced Induction Powertrain 8 01-02-2002 01:44 PM
