06-05-2003, 08:00 PM | #1 |
Member#: 23813
Vehicle:04 STi White |
What boost should be "safe" for the STi?
Disregard my prior post on boosting the STi. After much thought, I am going to not mess the factory boost.
Thanks, Russ
06-05-2003, 08:14 PM | #2 |
Member#: 10507
Vehicle:'04 Ex STi Owner '97 4Runner |
Stock.
That is all. Can we start a death pool on Wagonboy's car? Wait for a reflash damnit! And watch out with that intake leaning you out. Mods - shouldn't this be in FFI? Kevin |
06-05-2003, 08:34 PM | #3 |
Member#: 5743
Vehicle:2007 Kia Optima gold brick |
check this thread:
http://www.clubwrx.net/forums/showth...0&pagenumber=1 sounds like you're following god's mods... netZ |
06-05-2003, 09:08 PM | #4 |
Member#: 456
Vehicle:2008 Forester XT Steel Gray Metallic |
14.5 PSI +/- factory det.
06-06-2003, 01:07 PM | #5 |
Member#: 21618
SCIC
Wagonboy:
You should be safe up to and including 24.7 psi. Don't listen to all those other jealous people; crank it on up! Hey, it's only an engine... --scott |
06-06-2003, 01:09 PM | #6 | |
Member#: 30209
Vehicle:2017 BMW 540i xDrive Alpine White |
Vostok 7 |
06-06-2003, 01:23 PM | #7 | |
Member#: 13831
06-06-2003, 04:22 PM | #8 |
Member#: 27412
Vehicle:1999 New Beetle FOR SALE!! |
if you dont have an EGT gauge or A/F gauge, i wouldnt mess with it.
06-06-2003, 04:50 PM | #9 |
Member#: 34672
Vehicle:2003 wrx WR Blue Pearl |
Good grief man, it's already got 300hp and 300lb/ft of torque. Why risk blowing it up for a few more lousy, unsafe HP?
Wait for a reflash at the very least. |
06-06-2003, 05:57 PM | #10 |
Member#: 1503
South East
Vehicle:2012 2012 WRX Sedan Silver |
Bro, do what I do to all turbo cars...Take your Fuel Regulator's Vaccuum line off, now use that nipple on the intake manifold for a boost gauge...
Get a Tee like a 1/8th or 3/16th tee... Place that Tee into Compressor Outlet's Vaccuum line...Run a vacuum line from the Tee to the fuel pressure regulator...Now you just bumped up the Fuel Pressure under boost by about 3-4psi per psi of boost... That should give you the increased safety margin to turn up the boost to the limits of the turbocharger for the cost of maybe $3... You just increased your injector size when under boost and will not run rich when in vaccuum... You will go thru gas much faster but thats what you have to deal with when you are making more power... Throw in a Walboro and call it a day... I figure you can crank up the stock turbo to about 20psi Max Boost...But break in the motor first and get a 3" or larger turboback exhaust... Zee |
06-06-2003, 07:47 PM | #11 |
Vendor
Member#: 3600
You need an S-AFC II or something to richen it up in the midrange. You'll run into detonation at that boost level. We are getting a little due to both the increased airflow and the crazy timing maps. Top end is good though.
06-06-2003, 10:29 PM | #12 |
Member#: 18150
Vehicle:2002 WRX Wagon EJ207 Velocity Red, Liberal kit |
On TurboXS web site
UTEC standard features include: Plug-&-Play installation with OEM connectors for 2001-2004 WRX (STI coming) No cutting, splicing or additional sensors required 20 minute, do-it-yourself installation |
06-06-2003, 11:16 PM | #13 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Wow, the STI looks soooo nice in white, and I have never liked white cars.
Similar Threads | ||||
What boost should be ran on an EXT GATE | page02wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 09-01-2006 07:34 PM |
Need some feed back on what i should be aming for | scooby-stu | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 0 | 11-12-2005 08:41 PM |
What gauges can be used for the sti? | zigger | Electrical & Lighting | 4 | 06-30-2005 10:18 PM |
I should be studying for the GRE right now | WagonMonster | Off-Topic | 13 | 11-22-2003 03:01 PM |
help with what boost should be at. | Bauhaus | Mid West Subaru Owners Club Forum -- MWSOC | 2 | 05-20-2002 09:46 PM |
