11-08-2018, 10:19 PM | #1 |
Member#: 465113
Vehicle:2011 Impz Otbck Sprt Red |
Knocking Sound Went Away
Car Details: 2011 Subara Impreza Outback Sport
So, today while driving home my car started making a knocking sound, specifically around 3,000 RPM when sustained. Upon further investigation I discovered that my car had run out of oil... again... this time without any warning lights. I just changed the oil back at the end of Sept and have driven probably around 2,000 miles (tops) Anyway, I added some more oil and the knocking sound has gone away. My question is, how long do I have until I need to rebuild the engine? I'm pretty sure it's ****ed.
11-08-2018, 11:57 PM | #2 | |
Member#: 301554
BAIC
Vehicle:2002 WRX Wagon PSM 2002 WRX Sedan JBP |
It looks like you answered your own question. Secondly, cars don’t run out of oil, they either leak it or burn it, most likely the latter. If you’re not doing regular maintenance on your car yourself, then you need to hire a mechanic to do it for you at regular intervals. If you ignore your lady, is she going to love you? |
11-09-2018, 07:55 AM | #3 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
You should be checking fluids every other gas fill max, more often is better, especially if it is burning or leaking.
As to how long it will last, could be 5 miles, could be 20K miles. |
11-09-2018, 05:46 PM | #4 |
Member#: 474556
South East
how in the world is a 2011 going through oil like that
11-12-2018, 11:54 AM | #5 |
Member#: 465113
11-12-2018, 05:46 PM | #6 | |
Member#: 448581
The only real fix would be fixing the internal issues but that'll cost a good amount. But one thing you want to consider the more you drive a car burning oil the more likely you are to burn up your cat and damage o2 sensors. |
