12-02-2012, 06:08 PM | #1 |
Member#: 336712
Vehicle:2002 bugeye wrx silver |
Previous owner said always filler with Mobil 1/ royal purple. What kind of oil would I get for my 02 bugeye wrx. Thanks.
Assuming Mobil1 xxxx 5w-30 should be a good one? Is that Mobil one
12-02-2012, 06:13 PM | #2 |
Member#: 248761
Vehicle:2011 Civic Si White |
Did it come on or just faintly glow?
My 02 would faintly glow when it was really cold out and would go away when it warmed up. I think it has something to do with the sensor. |
12-02-2012, 06:13 PM | #3 |
Member#: 248761
And for oil, a lot of people use shell rotella t6
12-02-2012, 06:15 PM | #4 |
Member#: 127359
Vehicle:2006 WRX TR CGM PPG's,Polka pickled,ewg |
Any 5w30 full synthetic oil will suffice. I would opt for a 5w40 though. Most tend to have good experience with Shell Rotellla,which can be had at most any store including walmart. I personally run Motul 5w40 on the street in my car. Unfortunately the fact that your oil light has illuminated is the bigger issue at hand imo. I would not drive it until your absolutely sure your oil level is at the full mark.
Brand of oil is not nearly as important at this point as making sure that your oil level stays full at all times. A lot of members will warn against using Mobil1 oil, but honestly as long as the oil is changed when its supposed to be and kept full, you should have no issues. These motors a very prone to spin bearings when ran low on oil. You should be checking your oil level at every fill up especially if this is a new car to you. This way you get a feel for how much oil the car consumes as well as making sure its always topped off! If your oil level is at the full mark and you still see the oil light illuminated then most likely your oil pickup has developed a crack and needs to be replaced asap! I don't here about this very often on your model year but I'm sure it is possible! Good luck! Last edited by blazzin06wrxdude; 12-02-2012 at 06:26 PM. |
12-02-2012, 06:16 PM | #5 | |
Member#: 336712
I only drove it like 100 feet before noticing. So going to get oil now Also if I out oil in it till its in the like full zone. Will the light definitely go away an what if it doesn't. I have work in the morning and don't want to drive to work with that scaring me |
12-02-2012, 06:28 PM | #6 | |
Member#: 127359
If you add oil and the light is still illuminated, shut your car off and find another ride. Your oil pickup has most likely began to fail and will lead to severe engine damage if driven in this condition. |
12-02-2012, 06:31 PM | #7 | |
Member#: 336712
Willll it go off right away or will I have to drive for like 2 minutes |
12-02-2012, 06:40 PM | #8 | |
Member#: 127359
It could also be something very simple..here's a quote from KILLERBmotorsport who is a vendor on this forum. "Your oil pressure is fine, you have a bad connection from sensor to block. Usually caused by corrosion or moisture. The sender is below the alternator on the top of the block. Remove, clean and reinstall. If you had low oil pressure (the light comes on at 2.1psi) the light comes ON." hope this helps Last edited by blazzin06wrxdude; 12-02-2012 at 06:49 PM. |
12-02-2012, 06:42 PM | #9 |
Member#: 127359
Link to thread with the above quoted from Killerbmotorsport.
http://forums.nasioc.com/forums/show....php?t=2262081 |
12-02-2012, 06:49 PM | #10 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
And if your oil light is on, shut off the car until you figure out why and fix it. If it's full, I'd be getting the killer B oil pickup. Subaru oil lights usually only come on to tell you "I'm done, go buy a new engine".
12-02-2012, 06:51 PM | #11 |
Member#: 336712
I think I'm low on oil.. That's just it. I'm glad I caught it..just bought oil so ill put it in inike 5 min
12-02-2012, 06:52 PM | #12 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
If the light is ON or flickers turn the car off ASAP! Personally, I'd get a cheapo mechanical gauge and install it at startup. If the pickup is cracked (and the oil isn't hot) it may or may not light the light, but your pressure could still be really low. A mechanical gauge is cheap and will give you a very accurate reading.
FYI, cracked pickups go back to the begining of the EJ engines in the early 90's. The oldest car I've personally seen a broken pickup in was a 1997 with over 200K on the clock. |
12-02-2012, 06:54 PM | #13 | |
Member#: 198281
Remember, your viscosity is different cold/hot so the symptoms will change. |
12-02-2012, 07:01 PM | #14 | |
Member#: 127359
Good to know! And I apologize for misleading the op! So essentially that light will not illuminate unless the oil pan is pretty much empty? The pickup has to be uncovered? |
12-02-2012, 07:03 PM | #15 |
Member#: 336712
Put in two quarts And light went off. Should I be all set now?
12-02-2012, 07:04 PM | #16 |
Member#: 127359
12-02-2012, 07:06 PM | #17 |
Member#: 336712
I'm going to take it for a small calm ride and ill check it. No different sounds at all while starting throughout this whole thread
12-02-2012, 07:06 PM | #18 | |
Member#: 92003
SCIC
Vehicle:04 bicycle! |
Personally i've had the oil light come on while driving up hill through the rockies running 1.25 quarts low. Nothing out of the ordinary showed up when I sent the sample to blackstone labs. The car went on to live 20,000 miles more before the transmission blew up edit: I'd personally switch over to a different oil that subarus don't drink like water |
12-02-2012, 07:09 PM | #19 |
Member#: 336712
Car seems to be running fine no issues at all just the light scared me. Low on oil. So going to recheck now that I've warmed it up
I went to like read the dip stick. And now it looks to be reading like to much oil now... Like wtf Last edited by lvlatthew; 12-02-2012 at 07:21 PM. |
12-02-2012, 07:30 PM | #20 |
Member#: 336712
I think I'm gonna get an oil change tomorrow because I think there may be to much now... But what's a recommended oil to change and stick with? Ill ask the person I go to to get it
12-02-2012, 07:53 PM | #21 |
Member#: 139955
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
Royal Purple and Mobil1 5W30 are teh 2 worst oils you can put in a turbocharged Subaru.
12-02-2012, 07:57 PM | #22 | |
Member#: 79643
Vehicle:2021 STI TE Terminal black pearl |
12-02-2012, 08:03 PM | #23 |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
KillerB (basically the king's of Subaru oil issue solving) said if the light is on, don't start or drive. I wouldn't touch the car.
12-02-2012, 08:22 PM | #24 | |
Member#: 336712
12-02-2012, 08:44 PM | #25 |
Member#: 198281
If it were my car I would drop the pan ASAP, no driving. Pain in the butt, YES. Worth it vs thousands for a blown engine/turbo? God yes!!
You'd be kicking yourself if something like this happened because you didn't check it out. Worse case you find a problem with the pickup and replace it. Best case you find nothing, know there's nothing wrong, and don't loose any sleep over it. no one wants this... |
