Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 06-20-2017, 02:49 PM   #1
cknowlen
Member#: 189077
2011 STI limited
Default 2015 STI suspension swap onto 2011 STI
I currently have a clunk in my suspension which I believe to be attributed to my 2011 OEM struts having Eibach springs on them. In an effort to eliminate this clunking noise and to also improve overall handling, I have decided to swap in a set of 2015 STI struts. I know I know, that's been done before and documented on this site as well as on others. I have also acquired a set of RCE Black springs to install onto the 2015 STI struts during said install. From what I have read on various posts, the 2015 suspension lowers a 2011 Sedan approx. a half inch. That coupled with the more aggressive spring rate and additional 10mm drop provided by the RCE Black's should prove to be a very nice little setup. I will update this thread with my journey and pictures as well once the install happens.
cknowlen is offline   Reply With Quote
Old 06-21-2017, 03:45 PM   #2
GTP_Jav
Member#: 294027
Hmmmm... I'm interested in seeing the outcome and process, first time I've read about this and it does sound very appealing to me. Any links to a good write up?
GTP_Jav is offline   Reply With Quote
Old 06-21-2017, 10:14 PM   #3
cknowlen
Member#: 189077
2011 STI limited
^^ http://www.iwsti.com/forums/gr-suspe...-2014-sti.html
that is the thread i read all about it in. fitment has been confirmed by RCE, however nobody has tried the suspension coupled with the RCE blacks on an 08-14 that i have seen documented anywhere.
Springs arrived on my doorstep today, Struts are on the way and hope to have everything installed this Saturday. I will post comparison pics of how the suspension looks as well as before and afters and a review of handling/ride quality.
Old 06-21-2017, 10:31 PM   #4
GTP_Jav
Member#: 294027
I immediately started researching after reading your thread and I have decided to do the exact same thing, 15+ struts and RCE black springs. That seems to yield the exact drop I am after with the ride quality and performance I need!
Old 06-22-2017, 10:59 AM   #5
cknowlen
Member#: 189077
2011 STI limited
You didn't happen to find any pictures of other people who have done this exact swap did you? I have only seen pictures of it installed on 08-14's with the factory springs, which 08-10 seems to lower close to an inch, and 11-14 about a half inch.
RCE in that thread advised against installing this setup on a GR platform with lowering springs, but this might have been before the release of the 2015+ RCE springs.
A factory setup which lowers my car approx. a half inch, plus the higher spring rate and additional drop of the RCE Black springs should be perfect IMO. I don't see any reason as to why the strut would be 'slammed' or hitting the bump stops all the time, as the travel would be the same as if installed on a 2015+
Old 06-22-2017, 11:42 AM   #6
GTP_Jav
Member#: 294027
I didn't find any pictures, mine is an 11 as well and came to the same conclusion as you.
Old 06-23-2017, 09:45 PM   #7
cknowlen
Member#: 189077
2011 STI limited
All the parts arrived on my doorstep today. Got a set of 2015 struts/springs/top hats w 30k on them for $150. Got a set of RCE Black springs w 1k on them for $250.
Installed the springs on the struts today and also mounted up the front struts to the car. Still have to dial in the camber bolts better, but in comparison it looks like w the RCE Black springs the car is about a half inch higher than it was with my Eibach springs on the car. Gap w eibachs was 1 finger in the front, now it's two. Which I think is perfect.
Picture comparison of the fronts side by side:
You will find that the abs mounting tabs don't line up and don't have a welded on nut or threads, so I just used a zippie.
Picture of ride height w the eibachs:
And with the new struts and RCE blacks:
I will finish the install tomorrow morning and will follow up with a full review on the handling and everything. Cheers
Old 06-23-2017, 10:25 PM   #8
GTP_Jav
Member#: 294027
Very nice! Very nice car as well! Loving the final result.
So what top hats and perches did you use?
All 2015 hardware?
2015 Shocks/RCEs and 2011 perches/top hats?
Were you able to use the 15+ rear RCEs on your 11 shocks?
Old 06-24-2017, 09:36 AM   #9
cknowlen
Member#: 189077
2011 STI limited
Thank you for the kind words. She is coming along nicely.
Everything on the front is 2015 parts now (Struts, RCE springs, top hats).
I have yet to remove the 11 strut assemblies from the car, that's todays project to finish this up. I'm not going to remove the RCE springs from the 2015 rear strut assembly, but i will see if they look similar and take pictures before installing those as well. My bet would be that the 2015 RCE springs cannot be used on the 2011 rear struts as they should be slightly shorter. And RCE lists them as different part numbers.
Old 06-24-2017, 11:56 AM   #10
cknowlen
Member#: 189077
2011 STI limited
Suspension install is complete. Rears went in without any issue. They look pretty identical if you ask me. Overall the ride height is a perfect 2 finger gap in the rear and a 1-1.5 in the front finger gap. Will get actual measurements shortly.
Took the car for a short test drive around the back roads I live on, which are very twisty and bumpy.
WOW. What a difference this made. The dampening of these is night and day. Coupled with the progressive RCE springs, the car handles like a dream and feels much more planted and smooth. The infamous GR braking nose dive is completely gone and quick left right swerves are amazing!!!
I would absolutely recommend this upgrade to anyone with an 08-14!!
Pictures of the rear assemblies side by side:
Installed
Finished product and ride height
Old 06-24-2017, 12:33 PM   #11
GTP_Jav
Member#: 294027
Wow! Loving the outcome! Very interesting about the top hats, has me wondering about RCE 15+ top hats as well...
So you were able to use the 15+ rears as well?
Old 06-24-2017, 02:53 PM   #12
cknowlen
Member#: 189077
2011 STI limited
Yea, everything from the 2015 setup swaps over just fine. Which made the overall swap super easy, as having the ability to swap the springs over to the struts before attempting to install on the car is really nice.
Old 06-24-2017, 03:31 PM   #13
GTP_Jav
Member#: 294027
Perfect! That great to know, makes my search a lot easier as well!
Old 06-24-2017, 06:38 PM   #14
GTP_Jav
Member#: 294027
My friend you have sold me on this project! I just went ahead and ordered a 15k mile set I found on e-bay, the only set I could find in all of e-bay!! Lol! ��
Old 06-24-2017, 07:58 PM   #15
cknowlen
Member#: 189077
2011 STI limited
If you want the lower appearance without sacrificing ride quality, and want to improve overall handling...this is the setup for you!
Old 06-24-2017, 08:35 PM   #16
GTP_Jav
Member#: 294027
Talking
Very much looking forward to trying it out!
Old 07-30-2017, 10:45 AM   #17
cknowlen
Member#: 189077
2011 STI limited
GTP, you get your setup installed and dialed in?
Old 07-30-2017, 07:24 PM   #18
GTP_Jav
Member#: 294027
Yes sir I have and oh am I loving my car now more than ever! Dead on the best money spent on my car so far! Pretty much best money spent on any of my cars!
Old 03-22-2018, 06:36 PM   #19
FRStan
Member#: 354796
2012 WRX STI Hatch
Sorry to bump this thread, I recently did this mod on my 2012 GR, thought I'd attach photos of my drop to help whoever is planning to do this!
Stock wheels and tire size, 20mm H&R wheel spacers
FRStan is offline   Reply With Quote
Old 03-22-2018, 07:20 PM   #20
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Very Nice. I bought a 2016 sti setup for my wifes 13 sedan. Should be a nice upgrade over the old setup with 102k miles. I actually also bought a set for my 11 hatch. Then found a deal on rce t2's for that.
Im interested in what you think of them after you get some miles under your belt...
rexworx is offline   Reply With Quote
Old 03-24-2018, 03:03 AM   #21
FRStan
Member#: 354796
2012 WRX STI Hatch
Itís much more comfortable over bumps even though it is still stiff. If I had to compare it feels kind of like a oem BMW M suspension... body roll slightly improved as well.
Old 06-06-2018, 06:36 AM   #22
cknowlen
Member#: 189077
2011 STI limited
The newer suspension is valved much better than years prior. I am still very pleased with my setup. Took it a bit further with some additional chassis bracing and also upgraded to a new power steering rack for a 17 STI. Much tighter turn radius combined with the extra bracing and the better suspension has me really enjoying this car...Even on New England roads. Cheers
Old 06-06-2018, 06:42 AM   #23
cknowlen
Member#: 189077
2011 STI limited
Nice setup! Did you end up using the stock 15+ springs or aftermarket lowering springs?
On a side note, I love those wheels (yes I know they are OEM) and want to find a set to powdercoat.
Old 11-03-2018, 11:30 AM   #24
redrexmeister
Member#: 111692
04 WRX wagonette
SRR
Default 2015-2018 struts on 08-14 STI
I am planning to install 2015+ OEM struts/shocks/springs assembly on 08 STI hatch. Any tips to complete the job, namely:
- alignment specs for DD. did you need to use camber bolts, etc.
- did you do anything with abs sensor bracket to improve fit?
- what are the final lowering results after the springs settled? do you still like the ride/handling?
- any additional things to consider?
Thanks.
redrexmeister is offline   Reply With Quote
Old 11-30-2018, 01:54 PM   #25
redrexmeister
Member#: 111692
04 WRX wagonette
SRR
So I bought 16 STI suspension. Here is the comparison with 08 rear shock. The 16 MY shock assembly is about an inch shorter, coils are pretty tight on top.
Is this normal?
08 STI vs 16 STI rear shock comparison https://imgur.com/gallery/vV1F7yJ
