Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 05-28-2007, 05:56 PM   #1
submada
Member#: 133449
Default Opinions on my engine project please.
Hello to all readers, i would like to have your opinions on my engine built project, if you have any suggestions it will be welcome, i m planning to run a 8cm^2 FPgreen with 3" intake with the following engine setup:
Shortblock:
-EJ207 semi closed casing
-EJ207 STI crank cross drilled
-ACL bearings for conrod and crank
-Tomei Buffle Stiffner
-Eagle H conrods
-wiseco Forged pistons
-EJ207 Oil pump
Heads:
-EJ205 heads casing with:
-Ferrea dual springs with titanium retainer
-Ferrea super alloy valves Intake and Exhaust
-STI shimless buckets
-crower 272 cams
-ARP head studs
-polish to mirror intake and exhaust port
-cosworth 1.2mm metal head gasket
-power enterprise super strong timing belt
-stock pulleys
-Sti v7 intake manifold
-fuel Sard 800cc injector and sard fuel press regulator
-stock fuel line
i m going to run this engine set up with a jdm 6 speed sti gearbox from a type RA and a utec with a jdm version8 type ra STI ECU, what do you guys are thinking about my setup?
submada is offline   Reply With Quote
Old 05-28-2007, 07:43 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
what is a buffle stiffner?!!!
EJ207 crank is already cross drilled.
don't polish the intake to a mirror..actually leave it roughed. Do polish the crank and combustion chamber though.
I wouldn't use a utec personally...and the ver 8 ecu is a waste being there is no AVCS...
just reflash or get a real EM.
keep in mind wiseco forged pistons are spec'ed for a .040" decking on the block...this is a no no for subarus
EJ207 oil pump is the same as the EJ22t, is the same as the EJ257 is the same as the EJ205.
Old 05-28-2007, 08:51 PM   #3
wrxzzz
Member#: 137105
Homemade WRX, what do you mean by 0.40" decking on the block and why is it a no no?
wrxzzz is offline   Reply With Quote
Old 05-29-2007, 05:54 PM   #4
Homemade WRX
Member#: 33782
96 3MI Racing LLC
.040" worth of material removed...they lower the compression height of the piston making room for .040" removed from the block...the 0.040" they removed will ruin your quench height if you don't have the block decked or run a thicker gasket to put the quench height back to factory. On a subaru decking the block changes your cam timing (the no-no) as well as misaligns a few things (which are normally an issue).
Old 01-17-2011, 04:14 PM   #5
nedalrabadi
Member#: 244358
1996 impreza
orange & black
then ?
what's the right pistons to run ? ?
nedalrabadi is offline   Reply With Quote
Old 01-17-2011, 10:54 PM   #6
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Wow bumping a 4 year old thread...
Seraphinwolf is offline   Reply With Quote
Pretty much decided on my engine build ej205/ej22t/TS OPINIONS? hotshot2109 Built Motor Discussion 0 12-05-2009 06:02 PM
Final opinion on my setup, please.. vaj Brakes, Steering & Suspension 12 02-11-2006 12:10 AM
Opinions on my latest stupid idea please. Puckaveli Subaru Conversions 2 05-13-2003 11:22 PM
Opinions On My Winter Project CarbonFiberWRX Interior & Exterior Modification 17 02-15-2003 12:07 AM
Opinions on my Project. XT6Wagon General Forum Archive 9 08-28-2000 10:26 PM
