Welcome to the North American Subaru Impreza Owners Club Wednesday April 8, 2020
Old 08-19-2018, 06:25 PM   #1
TheShaddix
Member#: 483333
2018 WRX
Default My 2018 WRX Build
Hey everyone. This is my build thread for a 2018 base WRX. Follow me on IG at @craft_tech and @craftech_design. All my work can be seen at www.craftechdesign.com
I've been making videos on most of my mods on my YouTube channel at "TheShaddix". All of the carbon fiber bits on my car are made by me.
Mods (currently installed)
Drivetrain:
Pro-tune by PhatBotti, 327 wtq, 301 whp on 91 octane
- GS intake
- GS TMIC
- TS TGV deletes
- EGR unplugged
- Perrin Charge pipe
- TurboXS Bpv (fully recirc.)
- MAPerformance catted J-pipe
- Invidia R400 Catback Exhaust w/resonator deleted (painted black for a stealthier look)
- Torque solution billet transmission mount & Whiteline positive shift kit
- Soku differential, driveshaft, and subframe lockdown bits
- Cusco front side braces
- Cusco rear diff. brace
- Boomba plate & short shifter, solid bushing, shift stopper, shorty grimmspeed shift knob
- cf pulley cover
Wheels & suspension:
- ESR SR08 18x10.5 +22, 255/35/18 tires
- Silver's Neomax coilovers with swift 10k springs and radial bearings
- ProdigyWerks front 14" 6 piston bbk with stainless teflon lines
- Perrin 25mm sway bar w/ whiteline support beams, links, and lock collars
- Superpro front 26mm sway bar
- Tanabe front strut bar
- Torque solution steering dampener lockout
- Brake master cylinder brace
- Soku bushing set (rear diff, subframe, etc)
Interior:
- Renown 350mm alcantara steering wheel
- NRG hub
- Clutch stopper kit
- Gas pedal carbon fiber kit
- Custom CF ebrake handle
- Perrin ebrake button
- Drift ebrake button
- Alcantara shift boot, e-brake boot & arm rest cover
- Grimmspeed stubby stainless shift knob
Exterior:
- painted headlight housings
- HID low beam kit
- craftech design carbon fiber front blades, canards, rear spats, fender plates, gurney flap, winglets, diffuser, etc.
- custom rear badge vinyl (honeycomb texture)
- black taillight overlays
- fenders rolled and pulled, some bits shaved, rear fender liners removed
- STI style fog light bezels
- Front lip (MP style)
- Sideskirt extensions (STI oem style)
- Custom grill plate, side plates, and badge mount
- tinted windows: 35% front sides, 20% rear sides, 5% back window
TheShaddix is offline   Reply With Quote
Old 08-24-2018, 09:30 AM   #2
baronv
Member#: 490576
Nice!
baronv is offline   Reply With Quote
Old 08-24-2018, 02:24 PM   #3
Seef824
Member#: 477748
2018 WRX
How does the MAPerformance J-Pipe sound with the R400? Everything I have seen says the R400 drones so I have all but written it off. I would really like the R400 if it does not drone on the highway (6th gear 60-80 cruising).
I am also looking at Phatbotti for an e-tune this winter when I am ready.
Seef824 is offline   Reply With Quote
Old 08-27-2018, 03:01 AM   #4
vknyvz
Member#: 381276
2018 WRX Premium
WR Blue Pearl
nice,
how much did the Pro-tune cost?
vknyvz is offline   Reply With Quote
Old 08-27-2018, 12:20 PM   #5
Handsdown
Member#: 29355
Plans to restitch the steering wheel?
Handsdown is offline   Reply With Quote
Old 08-28-2018, 01:05 AM   #6
TheShaddix
Member#: 483333
2018 WRX
You can check my channel for a video with this exhaust if that helps. But I really like it. I got used to the drone within a day and now I don't hear anything, freeway or street, doesn't matter what rpm. When I first installed the exhaust I really hated the drone on my drive home and was disappointed. Every time you give it gas it just droned. But the next day I liked it. No idea of anything sound-wise changed in the car or I just got used to it that quickly, but it sounds awesome. And I definitely recommend an e-tune from them if you can't get a pro-tune. I've had both and there is quite a difference, but e-tune is fine.
Originally Posted by vknyvz View Post
nice,
Hit up Ron for a quote! Mine was 500 total.
It's a stock wheel, wrap is stitched by myself with real alcantara. It's not a subispeed wheel. The wrap was never made to fit 100% as it's the same width all around. I got it for super cheap from someone and he just cut it to the right length/width, that's all. Feels 10x better than stock though.
Old 09-14-2018, 01:25 PM   #7
TifosiWA
Member#: 489993
2019 WRX STI LTD
Pure Red
What is your opinion on the ESR wheels? Are there any center cap options other than ESR caps?
TifosiWA is offline   Reply With Quote
Old 09-21-2018, 11:58 AM   #8
TheShaddix
Member#: 483333
2018 WRX
I like them. The quality is great for replica wheels. Your only other option for caps is plain black ones from ebay. I'd just run with no caps as I do. Their caps are hideous. Their rotary forged series has decent caps though, not sure if those fit.
Old 09-28-2018, 03:02 PM   #9
Luizwrx17
Member#: 489282
2017 WRX
Is mid 300 whp a bit too much to ask for the wrx?
By the way, your channel is super underrated!
+1 subscriber
Luizwrx17 is offline   Reply With Quote
Old 09-28-2018, 03:20 PM   #10
TheShaddix
Member#: 483333
2018 WRX
+1 subscriber
Thanks man! And to answer your question, it's not the hp that stresses engines, it's the torque, specifically at lower rpm. 350 wheel torque is the most anyone should run on stock rods. I've met someone who ran 400 tq and bent a rod. Mine is 302 hp 327 tq. It's the torque you feel when you accelerate anyway, so i wouldn't worry about hp numbers. Also, make sure you go to a really good tuner. For me that's phatbotti hands down. Ron knows what he's doing so you won't hurt the car even at higher power levels.
Old 09-28-2018, 03:27 PM   #11
Luizwrx17
Member#: 489282
2017 WRX
Ah that makes sense.
I've heard him name quite a bit but I don't live in California. I was considering his E-tune when it's time, but for the money i might as well get a pro-tune, apparently there are some good techs out here in Dallas.
Old 09-30-2018, 01:06 AM   #12
fullah
Member#: 233053
Just watched your c.f. pedal and headlight videos. Great stuff. I subscribed! Do you have rubbing issues with such negative offset wheels?
fullah is offline   Reply With Quote
Old 09-30-2018, 01:09 AM   #13
TheShaddix
Member#: 483333
2018 WRX
Thanks! No rubbing anymore. If you watch the last video i made (overview), i talked about the fender work I did to make the setup work without rubbing. Too much work if you ask me, but really wanted 10.5" wheels no matter what.
Old 10-04-2018, 08:38 PM   #14
aFreshNAP
Member#: 405329
2018 WRX
Those wheels look awesome. Looks mean af
aFreshNAP is offline   Reply With Quote
Old 10-28-2018, 02:39 AM   #15
TheShaddix
Member#: 483333
2018 WRX
Front lip installed (got it on ebay)
Old 10-28-2018, 09:30 AM   #16
fullah
Member#: 233053
Looks great. I just did the sti style fog bezels on my 18 base as well. I moved my turn signals to where the high beam would go in the headlight. How did u do yours?
Old 10-28-2018, 02:15 PM   #17
TheShaddix
Member#: 483333
2018 WRX
yeah exact same thing that I did! I wedged the bulb bases into those holes and used the gasket maker silicone to seal them. Worked out perfectly. The sti bezels look awesome on these cars. I look back at the old pics without them and it's borderline gross with the fake fog light bezels and amber signals.
Old 10-31-2018, 10:26 AM   #18
MattSpano
Member#: 480838
2018 WRX 6spd Prem.
World Rally Blue
Gorgeous scooby...how did u wrap that wheel? Stitched while it was on the steering wheel?
MattSpano is offline   Reply With Quote
Old 10-31-2018, 01:29 PM   #19
TheShaddix
Member#: 483333
2018 WRX
It's just a generic wrap, not fitted. I stitched it on without removing the wheel. Took a few hours. It's worth it as a temp wrap. Authentic alcantara but has gaps, etc. I will eventually look into getting a new wheel. For now this works fine.
Old 11-06-2018, 12:05 PM   #20
yelof
Member#: 493669
2019 WRX series.gray
CKG
did you cut those taillight vinyl's yourself? just picked up a '19 CKG and im dying to get the white filled.
beautiful car btw!
yelof is offline   Reply With Quote
Old 11-07-2018, 09:13 PM   #21
TheShaddix
Member#: 483333
2018 WRX
beautiful car btw!
I got those from subispeed. You can also find them on ebay but the subispeed ones are cut nicer and thinner. The best way to apply them is to spray both the tailights and the vinyl with slightly soapy water, then maneuver the vynil until you get it perfect, and squeegee out the liquid. Once it dries it'll never come off by itself.
Old 11-12-2018, 07:29 PM   #22
rrrrrrrz
Member#: 493962
That poke! Clean ride, love it!
rrrrrrrz is offline   Reply With Quote
Old 11-14-2018, 12:25 AM   #23
TheShaddix
Member#: 483333
2018 WRX
Old 01-19-2019, 09:13 PM   #24
TheShaddix
Member#: 483333
2018 WRX
Latest additions to the car
Old 01-20-2019, 04:30 PM   #25
YangerD
Member#: 360966
Nice clean build my friend!
YangerD is offline   Reply With Quote
