Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 11-30-2018, 11:05 AM   #26
vincent9993
Member#: 464101
Originally Posted by ggogle View Post
When is your projected end date? How much do you work on it? I might be attempting a FA swap on a bugeye and wonder how long it would take me.
ETC (ie: Driving to an event as these are never really completed right?): Next May to Carlisle Import & Performance.
I only work on it on week-ends...
There were some challenges along the way but so far so good...
What transmission are you planning on using?
vincent9993 is offline   Reply With Quote
Old 11-30-2018, 11:16 AM   #27
ggogle
Member#: 440611
2016 WRX
Gray
I definitely get that lol.
I would probably attempt to use the tranny from the donor. I was hoping to eliminate as many difficulties as possible and transfer as much as possible.
ggogle is offline   Reply With Quote
Old 11-30-2018, 12:21 PM   #28
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I don't think the tranny would make much difference with these. The only big difference is the newer cars get wheel speed off of wheelspeed sensors (DCCD Pro makes a fix for this) instead of off the transmission. So in reality your bugeye or STi 6-spd (already swapped into FA cars) would bolt right up to the FA20DIT MT. (CVT has a different pattern from FSM pics, as does the NA FA20).
I've been looking into doing an FA20DIT swap into my GC as well. My big question comes in terms on the canbus and integration of all the sensors (or satisfying the ECU for their absence), when swapping over. What is really required? I'm guessing fuel tank sensors, gauge cluster, SI-drive stuff, vehicle control sensors, and buttons, etc...?
Old 11-30-2018, 12:31 PM   #29
ggogle
Member#: 440611
2016 WRX
Gray
Honestly, this whole engine swap has come out of some crazy circumstances so I haven't even had too much time to look anything up. I was hoping to hook up most (if not all) of the wiring harness from the donor and put it all together. Including the gauge cluster and center gauges. My project is dependent on how much insurance offers me to keep the car, so I didn't want to get ahead of myself.
Old 11-30-2018, 12:46 PM   #30
Homemade WRX
Member#: 33782
96 in the garage
Ah, I see you have a wrecked 2016 now...wanna sell it?
Yeah, if you do a full wiring swap over to the bugeye chassis, the ECU and all shouldn't even know it's in a new chassis. It's be a lot of mechanical things to that most likely. Brackets for dash parts, maybe ABS related (brake lines), etc...
Old 11-30-2018, 12:54 PM   #31
ggogle
Member#: 440611
2016 WRX
Gray
That's what I was thinking. Not 100% on the engine yet anyways. Didn't even attempt to start it. Looked alright but you never know.
Old 11-30-2018, 03:05 PM   #32
vincent9993
Member#: 464101
Honestly the CANBUS stuff has turned out to be quite easy. Subatronics has a great CAN emulator that takes care of all the cub systems (ABS, SRS, etc) and even has an input for SPEED and REVERSE to feed into the canbus. All you do is connect the 5sp/6sp speed sensor wires into the emulator and bingo. The Reverse is there in case you want to be able to activate the backup camera...
My main concern was being able to cope with the immobilizer but as long as the stock dash, stock ignition, BCU and ECU are wired in, you're good to go.
Ref
http://www.subarugears.com/subatronics/
Old 12-01-2018, 01:36 AM   #33
Homemade WRX
Member#: 33782
96 in the garage
I knew Subaru gears but the canbus side of their business is new to me. Awesome!
Do you know if a Cobb Accessport can still communicate with it? The page talks nothing about flashing the factory ECU.
Old 12-01-2018, 05:00 PM   #34
vincent9993
Member#: 464101
I have not tried it yet but led to believe it will work.
Old 12-11-2018, 11:46 PM   #35
GC84U2NV
Member#: 469875
2001 Impreza 2.5 RS
Sedona Red Pearl
sub'd can't wait to see finished product
GC84U2NV is offline   Reply With Quote
Old 12-17-2018, 08:18 AM   #36
vincent9993
Member#: 464101
For anyone interested in this project, here a small clip of it moving under its own power. We only drove it to the 2nd shop th finish some welding.
Still need to wire up the VSS from the transmission to the Subatronics module.
Got the lower dash and driver seat mounted last weekend.
Wheels are being made and should arrive in early Jan.
I'll try to report on progress more often...
Thanks for the help and interest
Old 01-18-2019, 12:59 PM   #37
ggogle
Member#: 440611
2016 WRX
Gray
Still going strong??
