Welcome to the North American Subaru Impreza Owners Club Thursday January 24, 2019
Old 04-29-2018, 07:33 PM   #26
racerjim
Member#: 93545
+1 for Doctor Color chip. Good product
racerjim is offline   Reply With Quote
Old 06-26-2018, 01:18 AM   #27
Repcal
Member#: 487636
Can you use Dr. Colourchip with oem paint?
Repcal is offline   Reply With Quote
Old 06-26-2018, 11:42 AM   #28
transmutation
Member#: 467769
2018 STI Limited
Are you asking if you can mix the two or use Dr ColorChip on oem paint? I would say the answer to the first is no but I've never tried it.
transmutation is offline   Reply With Quote
Old 06-26-2018, 08:55 PM   #29
chaelvick
Member#: 474010
Rock chips give it character!
chaelvick is offline   Reply With Quote
Old 06-26-2018, 08:56 PM   #30
chaelvick
Member#: 474010
On a serious note, my bumper is peppered with rock chips. Plan to do a respray eventually and run the thick clear vinyl overlay
Old 06-28-2018, 04:05 PM   #31
Saamuraikc
Member#: 263396
2008 Forester XT
I can definitely attest to the quality of German paint. Years of highway driving and and the BMW is fine, after only a few months with the forester and I can already see chips I should have gone with the clear bra.
Saamuraikc is offline   Reply With Quote
Old 06-30-2018, 02:35 PM   #32
origin8dontimit8
Member#: 487798
yeah i put on touch up paint last week and this is pretty much what i did:
- washed my car
- clay bar
- quick rinse
- dried off
- applied touch up paint to the front end/hood
- let it sit for a couple hours
- sanded lightly any parts that stuck out
- polished entire car including sanded areas
- waxed
came out great i think
origin8dontimit8 is offline   Reply With Quote
Old 07-06-2018, 12:21 AM   #33
Amplified2000
Member#: 86389
2011 WRX Hatch
- washed my car
- clay bar
- quick rinse
- dried off
- waxed
That's basically the procedure I use.. overfill the chips on purpose.. let the paint cure.. I try for at least 24 hours and then wet sand down to level with 2k or 3k grit then polish out the fine scratches
Amplified2000 is offline   Reply With Quote
Old 07-06-2018, 03:55 PM   #34
Max2003WRX
Member#: 487816
2003 Impreza WRX
WR Blue
Originally Posted by Jasondk View Post
my 2016 has rock chips as well, I have used very small amounts of touch up paint. Seems like Subaru paint is not the best, you can look at a clear bra in the future but you may have to learn to live with them or use touch up paint. No amount of detailing will remove a rock chip. I have heard dealerships have a new technique using a paint wand? I've never seen or heard much about it.
Can you give a recommendation of what brand of touch up paint? Or will any OEM paint on amazon do?
Max2003WRX is offline   Reply With Quote
Old 07-09-2018, 07:44 AM   #35
F3NTANYL
Member#: 424121
2007 Sti
Obsidian Black Pearl
Maybe check out your local autobody paint supplier and see if they can mix you up a bottle of touch-up paint using the paint code (I think it's usually in the glovebox or under the hood). If you'd like it near seamless then dab some on, allow it to cure, wet sand, then polish/wax etc.
Wax won't help with stone chips, just repels contaminants.
Xpel/clear bra films are supposed to be nice and will protect your paint from stone chips.
F3NTANYL is offline   Reply With Quote
Old 07-21-2018, 02:18 PM   #36
RamuhRx7
Member#: 452711
I don't know if it is STI or on all cars, but seem to be more prone to rock damage. I just got my Type-r and put XPEL PPF on the full front end so I get piece of mind.
RamuhRx7 is offline   Reply With Quote
Old 07-23-2018, 12:34 PM   #37
Chiba
Member#: 368677
2013 WRX
Pearly White
So I also see Langka as recommended for paint chip repairs as well.
Which one is better?
Chiba is offline   Reply With Quote
Old 08-30-2018, 11:32 PM   #38
idiazs
Member#: 490845
What about for does damn bugs on the front? Same thing clear bra?
idiazs is offline   Reply With Quote
Old 09-02-2018, 09:52 AM   #39
holzphoto
Member#: 490940
2013 Imprezza WRX
3M clear bra, def worth it!
holzphoto is offline   Reply With Quote
Old 10-08-2018, 12:23 PM   #40
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
I was at a local car show yesterday for the first time in maybe 10-12yrs and I was surprised to see almost no one ran clear bra on their cars and had chips all over their show cars.
Usually the first thing I do after taking delivery is to clean the front bumper and apply clearbra. It is a worthy investment. You don't even need to spend a fortune on those 'self-heal' films, just get a simple Ventura shield or 3M/Scotch and reapply every couple of years. If one is patient, it is a user installable product. I do all my clearbra installs at home and have no professional training. My tint guy says it looks professionally installed.
oichan is offline   Reply With Quote
Old 12-09-2018, 06:59 PM   #41
bennbennett
Member#: 425236
2010 Impreza 2.5i
Gray
Originally Posted by whiplash willy View Post
You can try to repair it yourself with DR Color Chip, or if you want to spend money, take it to a pro. Check out the other recent threads on rock chips.
My Thoughts on Clear Film & Dr Colorchip Application - YouTube
How to use the Dr. ColorChip System to fix rock chips on your car! - YouTube
Personally, I have had a good experience with DR Color Chip. It will fill the chip, but you will still have a divot, but that isn't visible, unless you are close up.
They also have a "road rash" kit, that makes it easy to fill multiple small chips in a pass, which it sounds like is what you have.
Does this work on Bondo? One of my doors was repaired by a previous owner and I've always wanted to get those white specs out.
bennbennett is offline   Reply With Quote
Old 12-24-2018, 05:11 PM   #42
Jacky Treehorn
Member#: 204966
2015 WRX owner here. Subaru has the thinnest most brittle garbage paint Iíve ever experienced on a car. Unless you spent the money on PPF then yeah, expect your front end to look like it got blasted by birdshot. I stopped caring, eventually it all blends in and Iím not about to spend the money on PPF for a Subaru at this point.
In the 4 years I owned this car I think Iíve only hand-washed it twice. When my friends apologize about dirty shoes or their dog in my car, my response is always the same ďdonít worry, itís a Subaru.Ē
Jacky Treehorn is offline   Reply With Quote
Old 12-24-2018, 11:24 PM   #43
jasonwrx86
Member#: 472037
2018 WRX Limited
CWP
I avoid interstate and expressways and so far I only got two big ones that went though the paint. The rest is pretty good. Just increase following distances and make sure you are not following trucks.
At the end of the day it's just a Subaru and no one will notice when you trade it in or sell it.
jasonwrx86 is offline   Reply With Quote
Old 12-26-2018, 05:54 PM   #44
viprklr
Member#: 464041
2008 WRX STI
I would first go the route of trying to do a DIY repair with Dr. ColorChip. Inexpensive first alternative.
viprklr is offline   Reply With Quote
