Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 11-28-2018, 07:36 PM   #30951
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Pelco View Post
What are the good ones? I was thinking about just renting then from the Autozone
that would probably be ok.
the cage ones are best (safest), but i have never used them myself, i always have used the long bolt style ones and they can be scary.
Old 11-29-2018, 01:38 AM   #30952
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
I've had success with those. Just take care in placing them, crank them evenly and don't put your body in the same axis as the spring.
Old 11-29-2018, 02:18 AM   #30953
Pelco
Member#: 435599
2016 Impreza Sport
Update. The seller on eBay just informed me that the price I payed was only for 1 spring front and 1 spring rear. that means if I want the set I'll have to pay double! I decided that 800$ for springs would be better served towards coil overs.
So much for my pipe dream. What is your take on coilovers for the car. Worth it? Or OEM stock all day? I don't have snow to plow through, and I rarely ever go on soft-road adventures. My Impreza is my street and city car. The only thing I'd want to retain, is the utility of the car but tighten up the body roll. The universe has told me it wasn't suppose to happen.
Pelco is offline   Reply With Quote
Old 11-29-2018, 07:33 AM   #30954
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I personally donít like coilovers, but that doesnít mean they are bad.
Old 11-29-2018, 11:56 AM   #30955
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Default 2012 Impreza thread
Phone camera messes with the color, they arenít a perfect match but are pretty dang close
Old 11-29-2018, 01:00 PM   #30956
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Unless you are adding a turbo to this car I wouldnít change anything.
It has plenty of grip for its power.
Seems kind of a waste to put a bunch of performance stuff on an econo box.
I would save it for a 2nd sporty car myself.
DieselDorf is offline   Reply With Quote
Old 11-29-2018, 02:37 PM   #30957
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I can understand the desire to corner better, and eventually mine will get Ď10 oem shocks/springs, but im not paying a premium to swap to coilevers
Old 11-29-2018, 11:37 PM   #30958
Commander Keen
Member#: 319157
Anti-sway bars do that nicely. Have you upgraded those?
Old 12-03-2018, 01:26 PM   #30959
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
A little salty...
Old 12-05-2018, 05:11 PM   #30960
Angelus911
Member#: 89967
2012 Impreza Sport
So I was doing some simple rear brake maintenance earlier this week, and noticed that my rear exhaust pipe is no longer connected to the exhaust hanger - it's rusted through. No holes in the exhaust that I saw, so should I just leave it, epoxy it back together, or replace the rear exhaust pipe?
Old 12-05-2018, 07:44 PM   #30961
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Bring it to an exhaust shop and have a new hanger welded on, maybe 25.00?
Old 12-05-2018, 07:44 PM   #30962
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Not surprised but 0w40 looks to be no worse than any other oils I have used in my car
I will post the UOA later when I have the computer
Old 12-05-2018, 08:42 PM   #30963
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
For the hanger I would just do some metal wire. Once more rust off or if it really starts coming down then itís time for a new exhaust.
Twisted wire will hold really well.
I switched to 0-40 on my last change as well, went from losing 1q per 3000miles on 0-20, to about 3/4q per 6000miles.
I wouldnít hesitate to recomend it to anyone with even mild consumption issues or none at all.
Old 12-05-2018, 09:39 PM   #30964
Angelus911
Member#: 89967
2012 Impreza Sport
Thanks, appreciated
Old 12-05-2018, 11:00 PM   #30965
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Old 12-07-2018, 10:44 AM   #30966
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Had about 8Ē of snow yesterday and while parked for about 30s on an incline after moving I noticed some greenish yellow fluid in the snow.
Iíve never had my car leak anything and all fluid levels are fine.
You guys think it could be some old stuff leaking out of the catch pad on the splash guard? It was pretty clear definitely not pure coolant.
The snow was pushed flat from the underside of my car so maybe it caught something that had been sitting on the underside?
Old 12-08-2018, 08:34 AM   #30967
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Unless you changed the blue coolant to green (why????) we donít have any fluids that are that color
Old 12-08-2018, 02:04 PM   #30968
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I havenít. I think itís a combination of oil/coolant/ windshield washer fluid that has accumulated on the catch pad over the years turning some weird color.
Old 12-08-2018, 05:09 PM   #30969
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Washer fluid doesnít land there unless you canít pour
My tray/pad is still dry, even with 160k on it
Old 12-08-2018, 09:10 PM   #30970
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I think it was washer fluid. I havenít put my scraper in my car and used a ton on the windshield that day. I think finally when I went up my driveway which is really steep it leaked out of the drains.
Old 12-09-2018, 01:43 AM   #30971
Pelco
Member#: 435599
2016 Impreza Sport
I've upgraded the rear to a STI 20mm. I hear that it is possible to upgrade the front to an aftermarket 24mm? , But that would mean I'd have to upgrade the rear up to 22mm to get it back to the neutral it already is.
Sway bars might be all I need. Cheaper than coils. I kind of like the plushness on rough roads.
Old 12-09-2018, 11:36 AM   #30972
Pelco
Member#: 435599
2016 Impreza Sport
I just read (on the internet's) the Crosstrek has a 24mm front sway bar. This is pretty big compared to the 16mm that comes stock accompanied on the rear.
If this is true then a OEM Crosstrek front sway bar could be put on the Impreza. That's massive.
Old 12-09-2018, 08:04 PM   #30973
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I just read (on the internet's) the Crosstrek has a 26mm front sway bar?! This is pretty big compared to the 16mm that comes stock.
Front =\= rear
Our front is 22, rear is 16. My sti rear bar is 19, new are 20?
Old 12-09-2018, 08:43 PM   #30974
Pelco
Member#: 435599
2016 Impreza Sport
Front =\= rear
Yes. They have a 19 and a 20mm rear.
So If 24mm is what the cross trek is running on the front, and the 22mm on the Impreza.
A 20mm rear works to complement the 22mm front on the Impreza, I would think with 24mm on the front an adjustable 22mm rear would work.
If this is sane, then I might just order myself a 24mm Crosstrek OEM front sway bar.
This should stiffen up the imprezas roll without having to upgrade the shocks.
Old 12-10-2018, 12:04 AM   #30975
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
If this is sane, then I might just order myself a 22mm Crosstrek OEM front sway bar.
i would assume it may or may not work. i know they are similar enough, just not sure the bars are completely compatible
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
