Brakes & Suspension Forum sponsored by The Tire Rack |
01-31-2007, 09:55 PM | #1 |
Member#: 121212
SWIC
Vehicle:2007 Sti Limited Urban Gray Metallic |
under power, pulls to the left, but under coast, it pulls to the right
I have a 07 sti limited with 3K miles and it's done it since day 1. took it back to the stealership and they rotated tires, adjusted tire pressure, said alignment was fine, and dinged up one of my wheels! Problem didn't change one bit. Still pulls to the left under power, and to the right under coast.
Trying to contact SOA now via email... so far, not much response from them. Has anyone else noticed this problem?
01-31-2007, 10:55 PM | #2 |
Member#: 129765
Vehicle:2006 EVO 439whp/412wtq (MD) |
Check to see if you motor mounts are straight.
02-01-2007, 07:28 AM | #3 |
Member#: 17332
NESIC
Vehicle:2004 Black STI Not stock anymore |
I recollect a recent thread about rear subframes being out of position or bent...
02-01-2007, 09:55 AM | #4 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Alignment is off. When the dealership says the alignment is good, that means it is in spec. In spec is not a good alignment by any means. Take it to a performance alignment shop and have them fix it.
02-01-2007, 10:46 AM | #5 |
Member#: 103015
Vehicle:07 STi/ 08 2.5 World Rally Blue |
My new STI with 400 miles does the same thing... I have not gone to the dealership yet, but have checked pressure, and rotated the tires, and no luck. I am guessing that it is also an alignment issue. I will see what the dealership has to say...
02-01-2007, 11:39 AM | #6 |
Member#: 17332
NESIC
where are you?
02-01-2007, 11:44 AM | #7 |
Member#: 121062
NWIC
Vehicle:2006 STi [STU Trim] World Rally Blue |
this is very true. I don't have my alignment sheet from the local shop I went to, but subaru's tolerances are pretty wide -- even for things like toe and caster.
02-02-2007, 02:18 AM | #8 |
Member#: 121212
SWIC
I'm in Tucson Arizona.
We have no good performance alignment shops in Tucson. I have been to 3 different shops (all touted as "good") with previous cars and none were able to solve a pulling problem (on another car) which was finally solved by taking it back to the dealership (Mazda). If anyone knows of a real performance alignment shop with true professionals in Tucson, I'd be happy to have them look at it. (nix to Alignment Brake Suspension, never fixed a pulling problem on two vehicles, one of which the car now drives pulling and the steering wheel is offcenter.) (nix to Precision Alignment & Brake, unable to fix pulling problem.) (nix to Duke & Jay's Service , unable to fix pulling problem.) |
02-02-2007, 02:22 AM | #9 | |
Member#: 121212
SWIC
If you have any luck with the dealer, please let me know what you found. Thanks to everyone who replied. If anyone knows what this is, I'd love to hear it. For now... I'll just keep searching. |
02-02-2007, 03:12 AM | #10 |
Member#: 121212
SWIC
02-02-2007, 07:34 AM | #11 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
motor mounts ain't gonna make the car pull to one side.
it could be a suspension mounting point with free play in it. ie, control arm bushing in the front, loose trailing arm link in the rear, etc. does the pull to the R under coast get worse when you brake? under power the wheel moves forward and toes in, and under braking the wheel moves backward and toes out. since it pulls L under power and R while braking, the issue is either on the right hand side front, or the left side rear. as the RF gets power, it toes in, pushing the front of the car to the L. as the LR gets power, it toes in, pushing the rear of the car to the R. the effect is that the car rotates left, and you have to correct by turning the steering wheel R. what is the wear pattern like on the tires, front and rear? |
02-02-2007, 09:10 AM | #12 |
Member#: 105096
TXIC
Vehicle:2007 WRX/STI Black |
Sounds like you could have a problem with your brakes.
02-02-2007, 10:13 AM | #13 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
02-02-2007, 12:26 PM | #14 | |||
Member#: 121212
SWIC
Well I was reading on the net about a guy with some chrysler that had a similiar problem after an axle replacement and that's what it turned out to be.
02-02-2007, 06:52 PM | #15 |
Member#: 112332
My 04 does this a little, the dealership said everything was in spec when I got it a few months ago. But I live in Minnesota, and have snow tires on, I'll wait untill spring and my next tire change to get it done right.
02-02-2007, 07:34 PM | #16 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
This is an incredibly long shot, particularly on a new car, but my car did the same thing when I snapped the left rear axle. Maybe you got unlucky and your car came off the ship with a bad CV?
As for alignments, I've generally had good luck at Sears. I give them the specs I want, they say, "We won't warranty this," I say, "Whatever, just align the car to those numbers," and they do it. I say "generally" because I just got it "aligned" two weekends ago and they hosed it up because the guy put my specs into the computer wrong and I didn't catch it. When it took him 4 tries to get the phone number of the guy in line ahead of me I should have realized he wasn't good with numbers and that I would need to 2nd check his work. Pat Olsen '97 Legacy 2.5GT sedan |
My Evo loves the R34...but how does it feel about the E92 M3? | AlvinHuyN | Member's Car Gallery | 68 | 10-16-2008 08:27 PM |
Why does my car pull to the left and also is it dangerous? | subyboy828 | Newbies & FAQs | 11 | 08-15-2007 06:04 PM |
car pulls to the left hard under WOT | OvrClkdPmp | Brakes, Steering & Suspension | 18 | 02-23-2006 11:35 PM |
Want to add a cat to the system but have no Ide where to put it? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 07-26-2004 12:46 AM |
