07-27-2007, 03:04 PM | #1 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
6-spd into GC8
well, I'm an old head around here and did my searching but find only contradictions on what to do for front axles...
The tranny I'm looking at is a 03 JDM STi six speed (ty856wb3ka) and from the pictures of it, it requires innies for the front cv's. What axles can I run? will the STi's (1" longer per side) cv's fit with the GC control arm? Thanks, Micah
07-27-2007, 04:10 PM | #2 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Did you find Jaxx's FAQ on axles? I think the information you seek lies within. I don't know the answer, but if you continue to have trouble finding it, I've got a local tech that's done a few of these and knows what's what...
07-27-2007, 04:30 PM | #3 |
Member#: 33782
ok, I'll look up jax's faq...didn't see it in any of my searches...?...
I wish my 5spd straight cut dog box would have held...would have made things soo much easier and cheaper... 6-spd dog boxes are 6200 for gears!! |
07-27-2007, 05:02 PM | #4 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
don't know that i have any thing on 6 speed in there
and 03 6 speed may still have the outtie stubs |
07-27-2007, 08:02 PM | #5 |
Member#: 33782
definately innies |
07-28-2007, 12:17 AM | #6 |
Member#: 177
NWIC
it can be converted to outties but .. you will need rear axels too
07-28-2007, 01:41 AM | #7 |
Member#: 76586
RMIC
Vehicle:2006 9-2x Aero |
just curious, how do you break a straight cut dogbox trans?
07-28-2007, 04:20 AM | #8 |
Member#: 63977
NESIC
Vehicle:2005 STi WRB |
dump the clutch from one meeeeellion rpms
I'd really like to know too, that's quite a feat. |
07-28-2007, 08:32 AM | #9 |
Member#: 5810
Vehicle:2001 S366 2.5RS |
if you actually broke a dog box, what do you think is gonna happen to the 6spd???
Which dog box was it? no way in hades it was a PPG box. |
07-28-2007, 09:10 AM | #10 |
Member#: 33782
07-28-2007, 09:12 AM | #11 |
Member#: 33782
didn't break yet but PAR (had) and PPG both told me that their 5-spd dog boxes would not hold the power I am looking to make...so cut my losses and sold the box before I broke it.
Now I have to go to a dog box 6-spd as they are rated for more power...hence the 6-spd conversion damn extra 80lbs |
07-28-2007, 09:15 AM | #12 |
Member#: 33782
so anyone have solid answers?...I'm trying to think to a couple years back of the first gc's that crammed 6-speeds and see what they did...
07-28-2007, 09:21 AM | #13 |
Member#: 5810
PPG doesnt even know what power they will hold.. and dont say you are trying to make over 800whp.
07-28-2007, 10:37 AM | #14 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Let's all second guess Homemade WRX, he never knows what he's talking about!!! Homemade, any reason you couldn't convert to GD control arms? I guess if you're trying to stuff big rubber in the fenders that wouldn't help you much. Pat Olsen |
07-28-2007, 10:55 AM | #15 |
Member#: 5810
Did I say that? did I even remotely hint to that? no.
give them a call and ask them. hell, give Andrew a call and ask him how much power they will hold. You wont get a straight answer. All they will tell you is "how much power are you looking to make" then they will say "well we recommend this..." They will not say oh, well this set will hold x amount and this one y amount. I've asked and asked and asked... many times. 8sec Skylines are running PPG dog boxes and havent broken them. So yes, I will second guess him.. I have personally NEVER seen a PPG failure due to structural limitations of the PPG gears, infact... I dont think there has been any documentation of failures of the gears. |
07-28-2007, 11:15 AM | #16 |
Member#: 7022
Vehicle:2001 Forester Arcadia green |
Dogbox 6mt jebus
Will you be doing the 4 or 5 gear dogbox? Actually thinking about your orginal question. I'm not the best with trans tech, but this is my setup: I am running RS axles w/ JDM wrx front hubs on a 03 JDM 6mt. Last edited by DoctorNick; 07-28-2007 at 11:22 AM. |
07-28-2007, 11:38 AM | #17 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
The stock axles wont hold at the power you want to make so just ask the driveshaft shop to make you a GC8 length outie setup. I am pretty sure the stock STi shafts will work in a GC8....I cant remember ever hearing about half shaft bind.
07-28-2007, 12:36 PM | #18 |
Member#: 33782
well, I'm going to go dss..for now I'm trying to get the 6-spd in and running...just a 35R for now...the 4202R will be about 2 months out
sideways, Andrew himself said for me not to got the 5 spd because they are only rated to 800... and patrick I had thought of GD control arms except I will need to tuck some rubber |
07-28-2007, 01:45 PM | #19 | |
Member#: 120
AKIC
That's what I figured. Of course, you could do like Luke Russell did on his red Brighton track car - flare that bitch! |
07-28-2007, 02:28 PM | #20 | |
Member#: 25952
NWIC
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
Hey Micah, I used 04 STI axles on my car (95 Brighton, 05 STI Swap with GT30R, soon to be GT35R). The Early 04 STI Axles seem to be the biggest factory axle. To use them you need ton convert the transmission to using "outie" axles. The conversion is very simple, and I have the kit if you want to do it (Basically consists of two stub shafts and two front diff seals) |
07-28-2007, 03:17 PM | #21 | |
Member#: 33782
and patrick the car will be going back to the 35r for track fun, so I had thought heavily about fender flares...problem is finding an pair that works with a 4-door |
07-28-2007, 06:35 PM | #22 | |
Member#: 51282
SCIC
Vehicle:98 RS black & blue from parking |
07-28-2007, 11:05 PM | #23 |
Member#: 33782
if you can get me a part number that would be awesome...I get parts at the dealership for well...my parts guy turns the screen around for me...haha
07-29-2007, 01:42 AM | #24 |
Top Scoob 015
Member#: 18175
Vehicle:99 STI RA Ltd #450 WRB blue |
if you get all the STI drive train then you are fine. i did to my 94 STI(GC8). your rear member might be different so the studs in the back of the rear diff might need to be changed out for the longer ones. just take the rear studs off of the old GC8 diff.
you probably have the R160 drivetrain(most GC8 have this) and all the STI(GDB) comes with the R180. if you have the R180 suspension then it will clear your CV boots. if you use the old GC8 suspension then the bottom of the suspension might not clear the boot and cause it to wear out fast and break. everything else will fit. i didn't read any of the above post... just wanted to throw my 2 cents |
07-29-2007, 09:42 AM | #25 |
Member#: 33782
the rear end is fine...already have the r180 done but appreciate the help anyhow.
V7 STi 6 Spd into GF/GC Writeup | cdnsigop | Transmission (AT/MT) & Driveline | 0 | 02-14-2010 02:28 PM |
Liberty 6 cylinder into gc8? | Miggidy | Subaru Conversions | 6 | 05-04-2005 12:21 PM |
6-Spd with DCCD into a WRX? | Neil Wallerstein | Subaru Conversions | 8 | 09-12-2003 12:22 PM |
Where do have to hammer to get the 6-spd into a GC8 | underground-mpyre | Subaru Conversions | 3 | 07-11-2003 02:40 AM |
6 Speed into GC8? | Simon Lines | Transmission (AT/MT) & Driveline | 22 | 10-23-2001 02:36 PM |
