09-24-2003, 01:42 PM | #1 |
Member#: 653
Vehicle:1993 STI V3 wagon green |
6 Speed Tranny To Fit Into Gc8
yes I need to know if a 6 speed tranny with electric center diff(2004 sti usdm) fit into my gc8 1993 impreza wagon....
I got a STI V4 conversion.... thanks Faf
09-24-2003, 07:06 PM | #2 |
Member#: 1185
Vehicle:I flap my gums and now I'm a specialist |
Both 6-speeds with EMCD/viscous center have identical gearbox cases. The EMCD has extra wiring and plug on the rear case, but both should fit.
09-24-2003, 07:14 PM | #3 |
Member#: 242
Vehicle:MY05 PSM GGA !STOCK MY99 RS-RIP / MY95 MX-5 |
Some people have had issues with tunnel clearance.. That were subsequently solved with judicious use of a hammer.
09-25-2003, 11:39 AM | #4 |
Member#: 653
thanks a lot
Faf |
09-27-2003, 03:31 AM | #5 |
Member#: 24827
Vehicle:2008 Kia Spectra |
Gosh dangit! Would some one come up with a definite answer? Does the 6-speed fit or not? I've seen people say it fits no problem, and I've seen people say you gotta bash the tranny tunnel. What's the truth? If it fits no problem, I may have to consider that instead of the MRT gearset...
-Nic |
09-27-2003, 01:32 PM | #6 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
It fits, but I'm 95% sure the only clearancing you have to do with a hammer is for the shifter linkage - so not a whole hell of a lot.
09-27-2003, 01:36 PM | #7 |
Member#: 2258
Vehicle:1999 gc8 ver7 6mt GT35R 504.7whp;) |
keep in mind too since it's bigger it will be alot harder to install and uninstall, as the regular one is quite a pain itself.
09-28-2003, 03:17 PM | #8 |
Member#: 10441
BAIC
It will fit with some use of a hammer to bang the tranny tunnel out a little bit, but as far as I know if you want the DDCD capability, you also need the 2004 STI ECU, as well as the gauge cluster (?). Hope that helps
-Josh |
No-dccd center diff fits a DCCD 6 speed and DCCD fit no mater the year of the tranny? | mudbug | Transmission (AT/MT) & Driveline | 24 | 02-04-2019 09:09 PM |
Has anyone here successfully modified 5-speed knob to fit on a 6-speed? | ScoobyNubieToo! | Interior & Exterior Modification | 11 | 03-19-2007 09:59 PM |
6-Speed Tranny - Where to buy? | Julio | Transmission (AT/MT) & Driveline | 13 | 10-07-2003 07:06 AM |
So how strong is the STi 6 speed tranny supposed to be? | loanshark | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 10-26-2001 01:21 PM |
upgrading to 6 speed tranny | annointed | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 07-16-2001 02:14 AM |
