Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 10-29-2019, 08:34 PM   #51
UncleFester
Member#: 488783
Originally Posted by stlfd View Post
Has anyone determined if the FA24 is swappable into a VA chassis?
(Props to Prime Motoring on that sweet build!)
I'm surprised more people aren't asking about FA24 swap into VA. I've been thinking about an IAG built block for my 2018, but I'd go OEM FA24 all day long if it fit with minimal customization. Could the 2.0l heads fit the FA24? Maybe with some shop work?
A new FA24 shortblock can be had for less than 2k from Subaru..(now I'm just dreaming)
UncleFester is offline   Reply With Quote
Old 10-30-2019, 09:36 PM   #52
wuuusaa
Member#: 92894
2015 Wrx - fury kit
silver duh
^^ These guys sell 2.4 blocks for $2493.
https://parts.bestbuysubaru.com/p/Su...1010AB49A.html
Old 10-30-2019, 10:11 PM   #53
WRXnick16
Member#: 447898
2022 Tesla M3P
2019 STI CWP
The short block assembly is around $1700 at my local dealership.
https://parts.subaru.com/p/Subaru_20...0103AC95A.html
If this FA20 cylinder heads bolt on, I'm guessing that they would at least need the combustion chambers opened up to compensate for the FA24's larger bore (86 vs 94 mm).
Then there's the question of the block dimensions to know if the intake manifold, intercooler, etc. will still fit in the same location. I'm guessing the intake manifold may not be interchangeable since Prime Motoring retained the FA24 intake manifold rather than using IBR's BRZ manifold kit.
I believe Ron also purchased a FA24 to swap into his WRX a while ago, but I haven't heard anymore about that.
WRXnick16 is offline   Reply With Quote
Old 10-30-2019, 10:52 PM   #54
adam99
Member#: 480524
2015 WRX
Just waiting on some good Samaritan to do the swap and make all of the details public.
adam99 is offline   Reply With Quote
Old 11-07-2019, 10:33 PM   #55
dankor
Member#: 460043
Makes me wonder if the FA24 intake manifold off the Ascent will fit under the hood of a WRX.
dankor is offline   Reply With Quote
Old 11-13-2019, 12:07 PM   #56
3eyesraver
Member#: 504042
2018 WRX
ISM
Imma just mod the 18 WRX, baby it, and hope can transfer all of those mods to 21STI muahahaha.
3eyesraver is offline   Reply With Quote
Old 01-20-2020, 03:14 PM   #57
gurusan
Member#: 258165
2015 WRX
No one has swapped one of these in a WRX yet? Beefier rods sound nice along with OEM reliability.
gurusan is offline   Reply With Quote
Old 01-20-2020, 03:51 PM   #58
adam99
Member#: 480524
2015 WRX
Apparently there is alot of work that goes into it. IBR was supposed to come out with a list on how to do it. Also if you want beefy rods with oem reliability take a look at TurninConcepts stage 1 block.
Old 02-10-2020, 11:58 AM   #59
HyperBSTI
Member#: 498589
2016 WRX STI
Hyper Blue
This is pretty awesome and something I've been watching for for a while. Even more so now that my STI sounds like it developed a cracked ring land on cyl. 2.
I saw another thread somewhere claiming that the CANBUS system would make swapping the FA24 into WRXs or other cars very difficult. That doesn't seem to be the case here considering the engine works with the FA20 ECU.
HyperBSTI is offline   Reply With Quote
Old 03-03-2020, 12:13 PM   #60
PyroguyFTW
Member#: 473226
2022 WRX
What about just the shortblock or the longblock? If the heads share a bolt pattern it would be easy enough to just do some polishing/port work and add a thicker head gasket. I did some quick math and it looks like a 1mm gasket with about 1.5cc worth of porting from the cylinder heads would net around 11:1 which is perfectly manageable for 93 and/or e85 and 18~20psi. So I guess the next question becomes do you make the 2.0 heads fit the 2.4 short block? Or do you make the 2.4 long block fit the exhaust/intake/accessories?
PyroguyFTW is offline   Reply With Quote
Old 03-05-2020, 11:54 PM   #61
jakesubie
Member#: 511228
2017 Subaru WRX
Red
Wow, this is awesome. I've been curious to see what someone could do with the FA24. I hope they actually end up putting it into the next STI.
jakesubie is offline   Reply With Quote
Old 05-22-2020, 11:18 AM   #62
WRXnick16
Member#: 447898
2022 Tesla M3P
2019 STI CWP
Progress. BRZ manifold in thanks to IBR.
Old 05-22-2020, 12:17 PM   #63
adam99
Member#: 480524
2015 WRX
"Crosstrek back up and running thanks to @ibuildracecars allowing me to adapt the BRZ manifold to the FA24 and making a fuel rail solution that will allow us to offer the FA24 swap to our customers. Issue we had prior was the DI system creating too much pressure and bending the brackets made which would lift the injectors out of the seat. These new rails are brick **** houses, there is ZERO movement now and perfectly safe for operation." -Prime Motoring
Old 06-06-2020, 10:41 PM   #64
Ryanlwlr
Member#: 479490
Will you guys be uploading a video on youtube with all the progress you have made and maybe some dyno pulls? Everyone I have talked to is excited to see what comes of this.
Ryanlwlr is offline   Reply With Quote
Old 06-07-2020, 02:55 PM   #65
DarkGreyMetallic
Member#: 487896
2018 WRX
Dark Grey Metallic 6MT
It melted a piston on the 26th because it ran out of fuel and went very lean
There are pulls and graphs on their Instagram @primemotoring
DarkGreyMetallic is offline   Reply With Quote
Old 06-09-2020, 10:45 PM   #66
SubbieNoob
Member#: 305546
2016 WRX
World Rally Blue
Any news on the swap process?
SubbieNoob is offline   Reply With Quote
Old 06-19-2020, 03:34 PM   #67
WRXnick16
Member#: 447898
2022 Tesla M3P
2019 STI CWP
Update:
"A glimpse into the future" demonstrating the potential of the next gen, FA powered STI.
537 whp & 490 lb-ft @ 22 psi on E56 before running out of fuel.
Modifications:
  • FA24DIT OEM Ascent long block
  • STI drivetrain
  • FP XR Blue 73HTZ twin scroll ball bearing turbo
  • Killer B IWG twin scroll header
  • Invidia J pipe w/ 3" catback
  • Cobb intake
  • Cobb FMIC
  • IBR BRZ intake manifold conversion w/ complete TGV deletes
  • Stock WRX ecu w/ Cobb AP & SD tuning software
  • Cobb EBCS
  • Cobb Flex Fuel kit
  • Hardwired fuel pump
  • Nostrum HPFP
  • Stock injectors
  • IAG AOS
-Non-power related: OEM STI 19" wheels, STI Type RA Brembos & Recaro seats
They continued pushing to 560+ whp but ran out fuel and leaned out to ~15:1 AFR (melting a piston). Should be capable of 600+ whp with auxiliary port injection (aka dual injection).
I will update the original post.
Old 06-19-2020, 04:03 PM   #68
WRXnick16
Member#: 447898
2022 Tesla M3P
2019 STI CWP
And let the controversy begin!!
FA24DIT vs EJ257
Both setups are equipped with an FP XR Blue ball bearing turbo, full bolt-ons, FMIC, stock long block, STI drivetrain & tuned on ethanol at Prime Motoring. Same dyno, same tuner, same turbo, ~10 days apart.
Modern FA24DIT
Power: 537 whp
Torque: 490 wtq (lb-ft)
Fuel: E56
Boost: 22 psi
Displacement: 2387cc (2.4L)
Bore & Stroke: 94mm x 86mm
Bore/Stroke ratio: 1.09 (oversquare)
Rod/Stroke ratio: 1.5
Compression: 10.6:1
Effective compression: 26.5:1
Injection: Direct
Turbo: Low mount, twin scroll, ball bearing, 22 psi
Specific output: 225 WHP/L (~265 HP/L)
BMEP: ~41 bar (~242 lb-ft/L)
Old School EJ257 ('19 STI Series.Gray)
Power: 463 whp
Torque: 448 wtq (lb-ft)
Fuel: E85
Boost: 26 psi
Displacement: 2457cc (2.5L)
Bore & Stroke: 99.5mm x 79mm
Bore/Stroke ratio: 1.26 (oversquare)
Rod/Stroke ratio: 1.65
Compression: 8.2:1
Effective compression: 22.7:1
Injection: Port
Turbo: Single scroll, ball bearing, 26 psi
Specific output: 188 WHP/L (~222 HP/L)
BMEP: ~36 bar (~215 lb-ft/L)
Peak numbers aside, look at the monster torque curve that the FA24DIT produces compared to the EJ257. The FA24 dominates in area under the curve!
The future of the STI looks promising if it's powered by an STI-tuned version of the FA24DIT!
Turbo specs for both setups:
FP XR Blue 73HTZ ball bearing turbocharger.
Flow rating: 57 lb/min.
Compressor wheel: 52.6mm inducer/73mm exducer.
Turbine wheel: 60.8mm inducer/54mm exducer.
CHRA: Xona Rotor ball bearing.
Disclaimer: The EJ257 uses single scroll housing as FP does not make a twin scroll housing for the EJ. Twin scroll setups (header, uppipe, downpipe, turbo, etc) are rare to come by for the EJ257 since they're costly and typically JDM as we didn't receive a twin scroll EJ in the US. Whereas, the FA24DIT uses twin scroll housing as it comes with a twin scroll setup from the factory. Every other aspect of the turbo is the same.
This is probably as close to a fair comparison as we'll ever see between the EJ257 & FA24DIT in terms of setup, dyno, tuner, etc.
And yes, I own a '19 STI equipped with the EJ257, but I can't resist:
Old 06-19-2020, 05:12 PM   #69
Straight6
Member#: 419593
That FA24 is a beast
Straight6 is offline   Reply With Quote
Old 06-20-2020, 07:35 PM   #70
wuuusaa
Member#: 92894
2015 Wrx - fury kit
silver duh
Good stuff right there Nick, thank you! Hopefully I can find a decently priced FA24 to make that swap. I want the all the torque.
Old 06-20-2020, 09:14 PM   #71
Comikazi
Member#: 402552
2016 WRX
Which Engineering Explained video is that in those pictures?
I don't remember watching this one.
Comikazi is offline   Reply With Quote
Old 06-21-2020, 04:20 PM   #72
bloodyBug_
Member#: 389775
2017 WRX premium
Crystal white
I tried looking for it as well and had no luck
bloodyBug_ is offline   Reply With Quote
Old 06-21-2020, 08:27 PM   #73
Rexy18
Member#: 500337
I believe it to be other guys' show called everyday driver or something similar, buncha Kanadians.
Rexy18 is offline   Reply With Quote
Old 06-22-2020, 08:24 AM   #74
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
Originally Posted by Rexy18 View Post
I believe it to be other guys’ show called everyday driver or something similar, buncha Kanadians.
Throttle House.
bicycle_wreck is offline   Reply With Quote
Old 06-25-2020, 05:56 PM   #75
WRXnick16
Member#: 447898
2022 Tesla M3P
2019 STI CWP
Prime Motoring has the FA24DIT back up & running with a GTX3852R Killer B Fury turbo kit. Stock long block with ARP head studs.. seeing how well it holds with 700 whp
