Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 10-30-2017, 01:06 PM   #126
Kessel Run
Member#: 253044
2013 WRX Limited
Originally Posted by JourdanWithaU View Post
Extra drop, not the same drop.
With the same springs, inserts will drop ride height a little, struts will drop even more.
Spacers should solve the problem.
Thanks!
Kessel Run is offline   Reply With Quote
Old 11-07-2017, 05:37 PM   #127
SG02WRX
Member#: 151814
2014 WRX SWP
Would this rallitek 1/2" spacer help with strut drop?
SG02WRX is offline   Reply With Quote
Old 11-07-2017, 06:30 PM   #128
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Yeah, I imagine that would do it.
JourdanWithaU is online now   Reply With Quote
Old 11-20-2017, 11:21 PM   #129
syn3rgyz
Member#: 290619
found this thread after finding out that my stock rear struts are leaking and need replacing. I find the stock setup a bit harsh and i bottom out on ****ty roads pretty often. What would be a good strut to upgrade to for a better ride while keeping the height and not have cornering feel suffering too much?
syn3rgyz is offline   Reply With Quote
Old 11-21-2017, 12:04 AM   #130
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Uhhh... Koni?
This isn't really a thread about strut options. It's about Konis and their fitment.
Old 11-25-2017, 01:00 PM   #131
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info
Quick update: one of the Epic rear springs broke so I ordered a set of 2010 STi SE rears part # 20380FG111 and installed yesterday. Only settled overnight but measuring 13.75", hoping they settle another 1/4"-ish to match the fronts. They ride great and very happy with the 250# spring rate.
Recap: Koni sport struts, front OE 11 WRX springs & 10 STi SE rear springs with no additional spacers yield roughly 13.5-13.75" fender gaps. Ride quality is very good with rebound set 1/4 turn off full soft.
darkstarmoto is offline   Reply With Quote
Old 12-11-2017, 11:39 AM   #132
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
My secret weapon arrived last week.
Rear went together fine.
Sleeves didn't fit on the front.
Measuring the sleeve, it had a 52mm diameter.
Measuring the strut body, that had a 51mm diameter.
So it will fit. But there's a disk at the top that's a 55mm diameter.
Nothing a bench grinder can't handle.
Boom, sleeves on!
Suspension assembled.
Not on the car yet. Will probably get these on next week if I can get an alignment scheduled. Otherwise, they will have to wait for January.
I'm thinking that with these adjustable sleeves, I can counter the rake from the short struts.
Old 12-15-2017, 12:42 AM   #133
Defibrillation
Member#: 473001
2013 WRX Hatchback
Question I've been wondering. I've read through this thread and xluben's thread regarding the 08-10 struts in an 11+ and how it'll drop the car 1/2 - 5/8". If I were to get the full front/rear struts for my 2013 and used King Standard Height springs (raise the car about 1/2 inch per an email to Primitive ), would there be any issue with this setup?
Last edited by Defibrillation; 12-17-2017 at 11:06 AM. Reason: Adding email from Primitive Racing and what I would like to install this setup on.
Defibrillation is offline   Reply With Quote
Old 12-21-2017, 01:33 PM   #134
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info
@ defib: I 'think' your rear will sit higher than the front using the same springs, you may want to question Primitive if the rears don't work out can you purchase/exchange for Kings lowering rear springs to even out the rake.
Old 12-24-2017, 05:37 PM   #135
Defibrillation
Member#: 473001
2013 WRX Hatchback
@darkstar, good point, rake would be present and would prob need springs to calm it down, for lack of a better word. I also found a great deal for inserts recently and will most likely pull the trigger for those instead of the 08-10 WRX donors.
Old 12-26-2017, 05:38 PM   #136
Svobatron
Member#: 464986
2013 WRX
Default Any updates?
Originally Posted by GTEASER View Post
The lower mount coming off the strut tube is different (0.5" longer for the widebody cars) and they need to design the stamping and tooling for it. Yes the perch is the same and they already can produce that.
Believe me, I have made Koni well aware of all the differences and similarities of the struts and told them exactly what they will need to design and build to get a product to market. It will come, we just need to be patient.
Any updates, is Koni still working on a solution? I see on their site the complete kit is still listed as TBA.
Svobatron is offline   Reply With Quote
Old 01-22-2018, 11:37 AM   #137
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
My master plan worked. The GC setup brought my front height to 2.5" above stock and I was able to adjust it down to 0.5" below stock.
Front to rear height is pretty even.
Old 02-05-2018, 01:42 PM   #138
Kessel Run
Member#: 253044
2013 WRX Limited
Does Koni usually have a spring sale?
Old 02-06-2018, 04:03 PM   #139
GTEASER
Member#: 410767
2012 Legacy GT
2009 Forester XT
Yes, I believe sometime between March and May.
GTEASER is offline   Reply With Quote
Old 02-08-2018, 01:38 PM   #140
maxsubaru1
Member#: 428260
Are those drop in?
This thread mentions that Konis 1140-0461S are a pain to install https://forums.nasioc.com/forums/sho....php?t=2686604
Also can the lowering be adjusted? I might not want to lower from stock ride height
maxsubaru1 is offline   Reply With Quote
Old 02-08-2018, 02:12 PM   #141
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Did you read the thread?
8710 1454LSpor and 8710 1454RSpor are full struts. That's what this whole thread is all about.
It seems that 1140-0461S is the old sport kit. The thread you referenced is 4 years old. Koni currently lists 1145 1050 on their website. That one is probably different and may include struts and not inserts.
Honestly, the inserts aren't that bad. If you have a set of donors and can work a drill and a pipe cutter, you'll be fine.
I had inserts on my old car ('09 2.5i) and they were fine. I went for the full struts on my new car because I think the geometry is better.
Old 02-08-2018, 02:25 PM   #142
maxsubaru1
Member#: 428260
Ok thanks although to me it's not clear what's the difference between 8710 1454RSpor and 8710 1454LSpor
Also are they compatible with a base 2009 Impreza (non-wrx)? Thank you
Old 02-08-2018, 03:14 PM   #143
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
One is Right (8710 1454RSpor) and the other is Left (8710 1454LSpor). Being full struts, there is a difference between right and left. If they are inserts, being the same on both sides, there would be one part number. Much like the rears.
They should work on a 2.5i, yes. If you get WRX springs, the ride height will be a little wonky. The NA models have less weight in the front.
Old 02-10-2018, 07:37 AM   #144
maxsubaru1
Member#: 428260
Ok thanks. So if I put the stock springs I currently have on top of these new Konis, is it fine for a sportier ride that can still handle potholes?
I'm reading here that one should replace front strut mounts as well? Subaru OEM? https://www.rallitek.com/assembled-s...2008-2010.html
Old 03-18-2018, 03:28 PM   #145
jojo69
Member#: 309196
2012 Hatch
wrb
so, Koni did not (yet, and probably won't) make a full strut for the 11-14. So for us with 11-14 wrx, we are either doing the insert or going with the 08-10 gen full strut that they offer.
Am i correct in making the above statement?
I want to make sure if I were to go with the full strut setup, would it be a plug & play (and it seems I would re-use my springs for now) for a 12. Seems like based on the OP, just trying to make sure I am not overlooking something here. Thanks
jojo69 is offline   Reply With Quote
Old 03-18-2018, 09:33 PM   #146
motorbykemike
Member#: 273868
they fit
see post 143
motorbykemike is offline   Reply With Quote
Old 04-20-2018, 12:27 PM   #147
Kessel Run
Member#: 253044
2013 WRX Limited
Quick question, when assembling the rear Koni struts, should the lower spring perch be free to move around? Is it fine as long as the spring is in the perch stop? On the stock strut it is welded..
Old 04-20-2018, 02:08 PM   #148
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Yeah it can spin freely without load, but once the spring is installed, it'll hold it tight.
Also, be sure to install it like a bell, not like a cup.
isotopesope is online now   Reply With Quote
Old 04-20-2018, 04:11 PM   #149
Kessel Run
Member#: 253044
2013 WRX Limited
Thanks!
Old 05-08-2018, 05:21 PM   #150
zugu
Member#: 77863
2013 WRX
Originally Posted by dellromero View Post
I got my yellows and koni struts installed. The rears are so damm high. Maybe i should have gotten blacks for my 13 hatch
So your setup is WRX RCE Yellows with Koni Sport struts? (87101454LSpor / 87101454RSpor)
zugu is online now   Reply With Quote
