Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 07-27-2006, 06:09 PM   #1
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
Default Knock sensor cel p0328 occurs only while Auto-Xing
So I've been having problems while racing. I've gotten the knock code twice now after resetting the ecu. Other times, there's no code, but the car goes into limp mode and I can only boost to 7psi.
It seems so only happen when autocrossing. I've never had the problem while just normally driving.
Anyone have any idea how this could happen? The car only has 23k miles on it.
xcdhridr is offline   Reply With Quote
Old 07-31-2006, 02:49 AM   #2
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
anyone got some help on this?
Old 08-03-2006, 06:38 PM   #3
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
=-( anyone
Old 09-22-2006, 01:46 AM   #4
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
anyone? still poor so no idea what's going on...
Old 10-29-2006, 07:16 PM   #5
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
time to spread some knowledge since the DTC was not present in my shop manual... a friend over on Cobb's board dug this up for me and I wanted to spread it around some since people seem to have problems finding any REALIABLE info on this DTC.
Texas25RS is offline   Reply With Quote
Old 11-03-2006, 03:39 PM   #6
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
how the heck do I test this?
Old 11-03-2006, 05:00 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....unplug/replug the knock sensor....if that dosen't fix it....replace it
Old 04-08-2010, 06:42 PM   #8
*Ulimited*
Member#: 139249
What is this info? I recently threw this code while auto-xing, replacement of the sensor didn't fix the code.
*Ulimited* is offline   Reply With Quote
Old 04-09-2010, 10:49 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
http://forums.nasioc.com/forums/show...7&postcount=10
Old 04-11-2010, 08:29 PM   #10
surowrxa
Member#: 102895
'12 Forester
'17 Outback
Did you reset the ECU/clear the code? And how much torque did you put on the bolt? If you did more than featherdust it, you crushed the sensor plate. Also, you should sand off the corrosion on the block with some fine grit first.
surowrxa is offline   Reply With Quote
Code 22 Knock Sensor CEL Snazzyjoe Pre-2002 Factory Turbo Powertrain 7 08-19-2008 09:57 AM
Cleaning 3m scotchgard film - hit traffic cones while auto xing dphoenix Car Care & Detailing 5 07-28-2008 04:35 AM
Knock Sensor CEL snow111 Normally Aspirated Powertrain 12 06-07-2007 09:19 PM
Trouble with boost dropping while Auto-Xing xcdhridr AccessPort 14 07-19-2006 01:00 AM
alarm settings changed while auto-xing...anyone know why? supersport Car Audio, Video & Security 4 09-13-2005 12:16 PM
