Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 08-11-2018, 03:29 PM   #151
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by Zee Biker View Post
So itís been two minutes...
Anyone have something new to contribute?!
Especially curious about 2.34ís with relatively smaller turbos.
I dont think you understand the whole idea of what the 2.34 is supposed to be. its a rev monster. So a small turbo would be not work very well on that engine
Old 08-18-2018, 11:47 AM   #152
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Small is always relative. While most of the motors have been paired with 35R or larger turbos, I remember this from a while ago:
https://forums.nasioc.com/forums/sho...&postcount=169
I would say an HTA Green is smaller, but that is just me.
As always, thank you to the contributors!
Old 08-20-2018, 04:14 PM   #153
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
I want to put a 7163 onto the next 2.34 I do. Not going for kill mode but fun without the torque spike you get on a 2.5.
Old 08-27-2018, 11:45 AM   #154
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Originally Posted by smoky View Post
Here is the info on the build and the results
  • Cobb access port v3
  • Speed density
  • Cobb flex fuel sensor, Canadian 94 and E85
  • Garret G25-660 with 0.72 hotside rotated custom setup
  • Process West TMIC
  • TGV delete
  • Custom parallel fuel rail
  • Walbro 450 fuel pump, hardwired
  • Aeromotive A1000 FPR
  • Cobb 1300X top feed injectors
  • Rebuild engine 2.35 (ej257 with 2l crank)
  • Manley 8.5 compression ratio 100mm, heavy duty piston pin
  • Manley MPS h-tuff rods +2mm
  • 11mm head studs
  • MPS 10mm oil pump (ported +1 shim)
  • Static and dynamic balancing
  • Heads
  • Bowl blend porting
  • Power division S1 cams
  • Tomei high rev springs
  • Tomei headers
  • Custom catless downpipe and Cobb axle back
  • Grimmspeed electronic boost controller
  • External wastergate, tial 38mm
  • EFI Logics tune
1 pull on 94:
https://www.youtube.com/watch?v=pE2Z_ookMBk
Final results:
Very impressed with results so far. We had to limit boost on E85 since we maxed the injectors (93%). TMIC was also limiting we had quite high temperature. Probably close to a point where a closed deck would be a good idea. Last point I wanted to rev up to 8500 but the ECU started acting weirdly pass 8000 and we had to stop. It's a 04 STI ECU, could be limited as they were upgraded from 05 and up.
Tx to EFI Logics, Calvin, Cory, Pete, Ben all professionnals, they did a crazy jobs. http://www.efilogics.com/
Tx a lot to Freedom Shop for the custom turbo setup http://freedomshop.ca/
I've not driven the car yet on track, will have to wait a few weeks before I autocross it. Car is built for hardcore autocrossing. It was a bit of a gamble to test that turbo and try a destroke 2.35 at the same time. Looks like there is more to this turbo and that the 550 would have probably given similar result with even better spool. I'll report back with more info once I tested it on the track.
Expension plan for the future would be to go up to 8500-9000rpm to help with short gearing of the subaru in autocross. I could also try a slighly higher compression ratio (9.0 or 9.5) to help with spool and response. Anybody that reached 9k rpm and would like to share info on how to achieve this you can contact me in private
Chased down from Built Motor.
Old 10-16-2018, 07:37 PM   #155
clubspectom
Member#: 478096
I've got a 2.1 running ELH, 256 cams, ported heads (non avcs) and a big16g on 18.5psi tapering to 17.5psi. Only a baby turbo as I still run a 5 speed. Makes 290whp/300ftlbs.
Being a GC8 is still plenty fast, would probably do a 105-106mph with a good launch.
Need to get a GTX30xx and a 6 speed for a street weapon.
[IMG]image_6106 (1) by Thomas Caruana, on Flickr[/IMG]
clubspectom is offline   Reply With Quote
Old 10-04-2019, 06:59 PM   #156
2004-STi
Member#: 199135
'00 RSTi, '99 STi
Both Silver
I have a Darton sleeved 2.1L stroker in my kitchen.
EJ205 halves
Darton stepped sleeves
Manley Turbo Tuff I Beam
CP 92.5mm Pistons Swaintech coated skirts and domes
EJ257 Nitrided 79mm Crank
Going into a 1999 STi, will be using my Ver6 EJ207 Non-AVCS heads and some 272 cams with a Garrett Gen2 GTX3584RS turbo.
2004-STi is offline   Reply With Quote
Old 10-05-2019, 01:20 AM   #157
subaru_gc8
Member#: 29292
2004 WRX wagon
EJ205 halves
man if you can get the avcs heads espeically with those cams and turbo, its going to be a long time to see power
Old 10-05-2019, 01:32 AM   #158
2004-STi
Member#: 199135
'00 RSTi, '99 STi
Both Silver
Yeah I'm considering it, and I might wait to see what the G35 turbos are all about when they come out.
I figured on maybe 4800-5000 with the current plan.
I'm also trying to figure out what people are revving to with the extra stroke, hopefully I can still achieve 8,500 safely.
Maybe a saving grace is that in expecting it to be around 9.5:1 so might help pack a little extra punch down low.
Old 10-05-2019, 10:18 AM   #159
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Should be fine taking 2.1 to 8500 assuming the oil pressure holds well
I’d look into trading/selling GTX3584r for a GTX3576r. The 84 will be a dog compared to the 76 and doubt the extra power will make up for it.
What do you use the car for and what’s your power goal?
Old 10-05-2019, 10:39 AM   #160
2004-STi
Member#: 199135
'00 RSTi, '99 STi
Both Silver
I was considering the GTX3576r as well.
I was hoping that on E85 and over 35psi (I say that loosely, hopefully i can test my luck and go higher even with the 9.5:1 comp) i could try for as close to 1,000 or so.
Really just street and track double duty, I have a RSTi that I'm building for the daily duty.
Old 10-05-2019, 11:03 AM   #161
subaru_gc8
Member#: 29292
2004 WRX wagon
its going to be a dog on the street, I have a 3067 with tomei pon cams and it doesnt really hit power til 4200 so with that big fo a turbo its not going to hit power til like 5000ish.. just saying
Old 10-05-2019, 11:22 AM   #162
2004-STi
Member#: 199135
'00 RSTi, '99 STi
Both Silver
I figured as much, i'm ok with late peak boost.
My 04 sti didn't get it until 4300 on a 3582r (30psi)
I say you only get lag once when you're going for it
Old 10-06-2019, 02:36 AM   #163
subaru_gc8
Member#: 29292
2004 WRX wagon
i guess.. my car is a 2.1 with v9 heads and tomei cams with a 3067 spoolinator kit. its fun and my power band is from 4000 to 8000. I wasnt looking for a huge peak boost, but I have about 400 and im pretty happy with that. the first tuen I got was on the usdm ecu and that sucked.. no power below 4100, but it was night and day when I got my avcs working. how the power is more linear and it feels like it starts to pull at 3700 all the way to red line. great for the street but yeah to each their own.
Old 10-08-2019, 11:09 AM   #164
2004-STi
Member#: 199135
'00 RSTi, '99 STi
Both Silver
Yeah maybe the GTX3576r may be a better choice, I was hoping to get close to 650whp minimally, on E85.
I hope with the Darton sleeves, my limiting factor would be fueling and not the block itself.
