Welcome to the North American Subaru Impreza Owners Club Friday February 28, 2020
Old 10-12-2019, 01:44 PM   #2926
1qukSti07
Member#: 326585
2007 STi
Originally Posted by '05CrystalGray View Post
2005 STi, stock motor, Full Race EFR 7163 kit.
Does anyone have issues with the car going to wastegate boost when shifting really fast? If I shift normal/fast the car hits target boost each shift. But when I race or do flatfoot shifting, the car will hit target, shift happens and then sits at wastegate boost until I feather the throttle.
Could this be because I need the stiffer BOV spring?
As a side note, will a stiffer spring require a retune? Anybody switched between the two? I've heard it helps with spool and response.
I switched to the stiffer BOV spring at the suggestion of Full Race. There was no noticeable difference beside the reduction of the whistle/surge noise in vaccume (10inHg). That spring change will not require a retune, but a wastegate spring change will require a retune.
1qukSti07 is offline   Reply With Quote
Old 10-15-2019, 09:25 PM   #2927
Gipp8
Member#: 507432
Default Bolt ons
What other bolt ons do you need to reach that 500wtq at the lower rpm range?
Gipp8 is offline   Reply With Quote
Old 11-11-2019, 12:59 AM   #2928
RckyMtnGT
Member#: 440549
2007 LGT EFR6758 6mt
https://www.turbosmart.com/news/gen-...port-released/
Interesting stuff from Turbosmart. EFR focused actuator. Flexible rod and better sealing, sounds like? The position sensor is interesting, but not something I would be able or need to make use of.
Speaks about it here for a bit, along with the electronic wastegate stuff, which is pretty neat sounding -
I suppose as I'm still on a single port actuator, seems like a good opportunity to pick one up in Jan' 2020 release and go for a retune. Currently on a 14psi spring, and peak at 24psi, and tapers quickly. "Ran out of wastegate", per my tuner, definitely leaving power on the table.
@YamahaSHO, what spring pressure are you running on your twin port setup? Are you using the MAC 4port solenoid to control it? Did you settle on a preload setting?
RckyMtnGT is offline   Reply With Quote
Old 11-25-2019, 08:25 PM   #2929
PrinceVegeta
Member#: 428946
2008 JDM WRX
I would like to ask if it's possible to fit the T4 Twin Scroll 7163 in stock location?
Has anyone done it successfully?
PrinceVegeta is offline   Reply With Quote
Old 11-25-2019, 10:32 PM   #2930
mazdan
Member#: 322018
Yes it fits.
mazdan is offline   Reply With Quote
Old 11-25-2019, 10:52 PM   #2931
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Originally Posted by mazdan View Post
Yes it fits.
I don't know of anyone doing stock location twin scroll kits? KB only had single scroll kits right?
Old 11-26-2019, 12:32 PM   #2932
mazdan
Member#: 322018
Right, you have to make your own. If you start with an own twin scroll header then you only need to make an up-pipe.
Old 11-26-2019, 01:07 PM   #2933
PrinceVegeta
Member#: 428946
2008 JDM WRX
Who can make a T4 Twin Scroll Up Pipe that fits with the JDM OEM TS Equal Length Headers in Stock Location for me ?
Old 11-26-2019, 04:25 PM   #2934
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
I'm not sure about the smaller frame turbos but I run the Full-Race rotated 7670 kit and to me, it doesn't look like it would be possible to keep twin scroll with the T4 hotside in stock location.
Old 11-26-2019, 10:19 PM   #2935
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Dig into the Borg Warner size sheets and see how much longer the housing is for the T4. It could be do-able.
Old 11-26-2019, 11:19 PM   #2936
mazdan
Member#: 322018
I'm sure you're right, the B2 frames are too big.
The B1 twin scroll frame turbos will definitely fit though. I've been running one for years. I've never posted results because I still haven't tuned it...
I have a couple of pics on instagram: solomotive
Old 11-26-2019, 11:20 PM   #2937
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I was running 12-13 PSI spring setup in my 2-port TurboSmart actuator, using the BW supplied 3-port EBCS.
I actually sold my car a couple weeks ago. The new owner, which is a car collector, wanted it on 91 octane. I swapped over the fuel and did some quick road logs and then put it on the dyno. I actually make something like 368 whp, but dialed it down a touch as the new owner didn't care for the extra power... He loved the way it was at 350whp. This tune actually made more power after some heat soak from a back-to-back pull. Sounds perfect for a street car.
Here is my E85 vs 91 octane dyno's.
yamahaSHO is offline   Reply With Quote
Old 11-27-2019, 02:22 PM   #2938
NighthawkSTI
Member#: 495630
Originally Posted by 1qukSti07 View Post
I finally finished break-in and got the car tuned. So far the car is running amazingly, this turbo rocks!
Main components for the build:
-Built block (Darton sleeves, Manley pistons and rods, king bearings)
-Built heads (stock cams, Manley springs and titanium retainers, GSC valves, and in-house PnP)
-EFR7163 with external WG routed back into the downpipe
-Custom FMIC with rotated intake mani
-FIC 1650cc injectors with hardwired walbro 450
I do all my own fab and engine building, aside from the machining.
I mainly use the car for AutoX and track days. On the last build and tune (26psi) I ran 11.5 @123 (I'm not much into drag racing). I'll take the track soon and try to dip into the 10s.
The current tune is by Mikey Botti, peaks at 29.6psi and tapers to 27psi by redline. We pulled a few degrees out of the tune in the midrange to keep some kind of longevity for this engine lol
Below is the virtual dyno, I'll be taking the car to a real dyno in the next few weeks for a comparison.
I highly recommend this turbo for anyone from a daily to track car!
WOW! That car is amazing and engine looks great!
NighthawkSTI is offline   Reply With Quote
Old 11-29-2019, 01:49 PM   #2939
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Got some left over stuff that someone here might be able to use. Both are new, but I have a Boost Resource/Turbomotiv turbo blanket for a B1 frame and a Full-Race mount for a 4-port EBCS on a B1 frame.
Open to offers...
Old 11-30-2019, 12:19 PM   #2940
NighthawkSTI
Member#: 495630
$20 ?
Old 11-30-2019, 01:09 PM   #2941
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Open to more reasonable offers.
Old 12-02-2019, 05:27 PM   #2942
Waddlz
Member#: 395275
2012 STi
$10 ?
Waddlz is offline   Reply With Quote
Old 02-22-2020, 12:26 PM   #2943
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Any other fabricators build rotated kits for the EFR7163 EWG?
QwaktastiK is offline   Reply With Quote
Old 02-22-2020, 07:07 PM   #2944
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
ballpark price for the bracket?
Hyper is offline   Reply With Quote
