Welcome to the North American Subaru Impreza Owners Club Friday February 28, 2020
Old 07-15-2016, 09:45 AM   #26
DavC825
Member#: 201736
12 IS-F Sold!! :(
Slowest 07 STi
Originally Posted by nysti06 View Post
i went with ID 1300 on green hta 8cm w/e85
Do you have the dyno plot? Interested
DavC825 is offline   Reply With Quote
Old 07-15-2016, 10:42 AM   #27
everkain
Member#: 84150
2013 WRX Hatchback
Originally Posted by bboygreddy View Post
17.5 psi (track map) - 407/375
20 psi (everyday map) - 435/397
Could easily swap in bigger injectors as the turbo has plenty more room to breathe. At 20psi the injectors were at 90% IDC so the tuner felt safe there
05 WRX with built ej255 (forged piston and rods, heat treated crank) stock heads (DBC so no avcs, hence the slight lag)
FP Green HTZ with 84mm FAP
Modified stock injectors
Walboro 255 fuel pump
Tomei ELH
Catless turboback
TGV deletes
FMIC
That thing is a monster. How much would AVCS help the lag?
everkain is offline   Reply With Quote
Old 07-15-2016, 12:47 PM   #28
02bugeye1
Member#: 270483
2005 impreza wrx sti
World rally blue
I made 380 on pump with meth
02bugeye1 is offline   Reply With Quote
Old 07-15-2016, 01:53 PM   #29
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
Do it Dave
Str8Gone is offline   Reply With Quote
Old 07-15-2016, 06:12 PM   #30
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
Look like laggy ? Peak torque 5500...
alakazoo22 is offline   Reply With Quote
Old 07-16-2016, 04:05 PM   #31
MetalRex69
Member#: 367985
13 Wrx
Update I got the car back but they could not street tune it comfortably (there dyno is down) so I made an appointment for Wednesday at another shop for the tune.
I will say this turbo is super loud lol sounds awesome you can start hearing it around 3500rpm. Can't wait for the tune it will be on a Mustang dyno.
MetalRex69 is offline   Reply With Quote
Old 07-16-2016, 04:09 PM   #32
MetalRex69
Member#: 367985
13 Wrx
They did provide a base map so I'm good to drive for the mean time
Old 07-16-2016, 08:18 PM   #33
DavC825
Member#: 201736
12 IS-F Sold!! :(
Slowest 07 STi
Originally Posted by Str8Gone View Post
Do it Dave
Coming soon sir, coming soon. motors out
Old 07-18-2016, 10:22 AM   #34
banny sti
Member#: 118815
what does 450whp translate to at the crank?
banny sti is offline   Reply With Quote
Old 07-18-2016, 10:59 AM   #35
alakazoo22
Member#: 230730
05 FXT 18GXTR
black
450 whp around 20%
Old 07-21-2016, 07:42 PM   #36
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
Any updates?
Threw one of these on my built ej205 and cant wait to see what it will do.
Fwiw-
manley pistons
Crower rods
Bc280 cams
Bc springs and retainers
King bearings
Arp studs
BnM madusa header
Ewg tial 38
2.5i manifold swap
Treadstone fmic
Meth inj
Etc etc..
Horner is offline   Reply With Quote
Old 07-22-2016, 06:42 PM   #37
MetalRex69
Member#: 367985
13 Wrx
Update
I was gonna tune my car, I was driving it with the shops "base map" and it started ticking..
Went back to the they did a compression test and cylinder 4 is at 130psi and the rest at 150. They're saying it's the bearing. Not sure what to do.
Old 07-26-2016, 07:22 PM   #38
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
Sorry to hear that dude. Pretty much it needs to come apart to see what all happened and the extent of the damage.
Old 07-26-2016, 07:38 PM   #39
MetalRex69
Member#: 367985
13 Wrx
Yeah sucks because I just got the car together and barely drove it on there base map..
The shop that did all the work doesn't want anything to do with the damage. The "base map" on my car says cobb stage 2 map 91 fuel. When they knew my car was on e85. After some inspection they hooked up my boost lines incorrectly so it basically can hit whatver boost it wants to. Not sure if that has anything to do with what happened.
Already looking around to behind the built engine.
Old 08-17-2016, 01:19 PM   #40
Rideit636
Member#: 275099
Got mine tuned last night. Tuner wanted to keep torque low at spoolup to keep the stock engine together. 364whp/330wtq on 93 pump. Once the built block goes in, 420ish whp on pump doesn't look unreasonable. Do not get the internal wastegate. We could not keep it from creeping to 21-22psi.
2015 STI Limited
-Cobb Accessport V3
-GrimmSpeed 3-Port EBCS
-Invidia Catted Down Pipe 2 Bungs
-Invidia Q300 Burnt Tips
-Cobb SF Intake with Box
-Turbosmart Kompact BPV
-Perrin Turbo Heatshield
-Deatchworks 300C Fuel Pump
-FP HTZ Green Turbo 2.4 Inlet Internal Wastegate
-InjectorDynamics 1000cc Injectors
-HKS Equal Length Header
-ETS Top Mount Intercooler
-GrimmSpeed Air Oil Separator
-NGK LFR7AIX Spark Plugs
-Cobb GR Style FPR
-PTP Lava Turbo Blanket
-PTP Lava Exhaust Wrap (100ft)
-DEI Lava Wrap (50ft)
-DEI Reflect-a-Gold 2"x50'
-Perrin Pitch Stop Brace
-Perrin Inlet
-Vibrant 90 y-pipe elbow
Rideit636 is offline   Reply With Quote
Old 10-12-2016, 06:21 PM   #41
bboygreddy
Member#: 107937
2005 WRX 18G OBP
@kamphotography_khoi
bump for the htz!
bboygreddy is offline   Reply With Quote
Old 10-14-2016, 12:30 PM   #42
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Bump. Considering the new green as well and want 400 on pump no meth. Fbo 1100 cc injectors. Is my goal doable?
silversurfer05 is offline   Reply With Quote
Old 10-14-2016, 01:27 PM   #43
everkain
Member#: 84150
2013 WRX Hatchback
i think its doable. gonna need a ewg and run about 22-24psi.
Old 10-17-2016, 03:31 PM   #44
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Got the Fp green just waiting on the injectors to show up. Will post results when done hoping for around 500 whp on e85 as long as the trans holds together!
nate_fisher is offline   Reply With Quote
Old 10-17-2016, 03:56 PM   #45
everkain
Member#: 84150
2013 WRX Hatchback
sounds like a good plan. are you going to do a 93oct. tune as well?
Old 10-17-2016, 06:50 PM   #46
nate_fisher
Member#: 270482
2011 turbotek fxt
Probably just for emergency purposes but I haven't really run 93 in the last 4 years.
Old 10-17-2016, 09:48 PM   #47
Boxer112
Member#: 78751
2017 Sti
ISM
What injectors are you getting?
I was going to get the HTZ Green for my build, but I figured for the same price, I might as well get the Red with room to grow. I'm worried I will run out of injector on E85 though. (ID 1300's) Sea level
Boxer112 is offline   Reply With Quote
Old 10-17-2016, 10:03 PM   #48
nate_fisher
Member#: 270482
2011 turbotek fxt
Id1300 and they will be maxed im sure at 30 psi and e85 it will be close.
Old 04-19-2017, 12:04 AM   #49
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Not to take over the thread but has anyone had a problem with the internal wastegate on the HTZ FP Green? Because mine wont open until it hits 25psi on the dyno.
BlackFighter is offline   Reply With Quote
Old 04-20-2017, 01:33 PM   #50
tylerandreas
Member#: 377747
That is weird. I got tuned on wastegate pressure just last night and was pushing about 17psi on it. Might wanna get it checked out.
tylerandreas is offline   Reply With Quote
