05-27-2006, 07:20 PM | #26 | |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
05-27-2006, 07:24 PM | #27 |
Member#: 110273
Vehicle:450 whp 30R STI 10.96@126 |
I'm suprised i have never found anybody talking about this before. So i'm wondering how much wrapping everything woud help? The only thing is i hate the way the wrapping looks, but if it helps out that much i might consider it. Please write back Jays05 after you have tried this and please let me know if you noticed any difference.
05-27-2006, 07:45 PM | #28 |
Member#: 60142
Vehicle:2011 WRX Grey |
This makes sense if you think about it. The Perrin intake and MAF is 100% under the hood so initial heatsoaking doesn't surprise me at all. In my case, it isn't a factor since I don't drag.
I assume this would be a problem for any system (including bone stock) where the MAF and intake are totally underhood. I'll ask PDXTuning about this and see what they have to say. |
05-27-2006, 07:54 PM | #29 | |
Member#: 70708
SCIC
Vehicle:2005 STI PSM & back to stock! |
05-27-2006, 09:58 PM | #30 |
Member#: 110273
Yeah it totally makes sense it's just that i have NEVER heard about this until now. I'm hoping that it's not as drastic as he is making it out to be but i guess we will see.
The reason i didn't go with the UR kit is because i think 500-700 is better spent elsewhere. Both kit's put down basically the same power and i didn't want to pay extra for the dump tube running off the external wastegate to be rerouted back into the exhaust. Plus i think the Perrin kit looks better, minus the intake, but hopefully Dan can make me an aluminum intake that won't effect the performance. Do any of you guys have problems with your idle or is it pretty rock solid? I heard that if you raise the idle a couple hundred rpm it should stay rock solid, but i would rather hear it from first hand experience. Last edited by STimo; 05-28-2006 at 02:06 AM. |
05-28-2006, 01:43 AM | #31 |
Member#: 37664
South East
Vehicle:2005 GT30R Forester Built to the Teeth :) |
STimo.....I think you are taking my statement and making more out of it than there truly is there to be searching for.
I didn't mean to make you think that this is some huge unavoidable problem. It is a problem without a doubt, but the fix is rather easy. Just take the perrin Intake and cut it just before the Recirc tube. Then have a 3 inch diameter pipe cut and bent to direct the intake into the fender well where the stock airbox hole is already cut out. It shouldn't be much of a problem at all, and cost is very low. and then just have Harman lengthen the wires of your MAF and stick it all in the fender well.....Here is what I am talking about. This is what Gruppe-S does on their Customer's Cars, it solves the problem 100% And the reason the stock setup isn't affected by the under hood temps is because the stock MAF housing isn't made of metal. I hope this helps you buddy, and since Harman Motive is subscribed to this thread they ought to be able to confirm to you, that this is a fairly easy solution, and something that they are more than capable of fabbing up for you in an afternoon or a day, if they need someone else to bend the piping. |
05-28-2006, 01:45 AM | #32 |
Member#: 60142
My idle is stock normal and steady. I think this issue may be more a function of injectors and tune.
05-28-2006, 01:59 AM | #33 |
Member#: 37664
South East
My idle is as rock solid as it can be....and my tune was from someone whom is concidered to be one of the premier tuners in the United States, so I hate to differ, but that has nothing to do with the problem. The problem plain and simple is that the Perrin Kit uses a Metal MAF housing. And that isn't a problem unless the car is being tuned on a Dyno that actually loads the wheels. However, flycaster I'd be interested for you to log what your intake temps are after you drive around for about 20 minutes and then come to a stop for a bit. You'll notice that your car will start pulling timing, which will go away once you start to take off again, but it's a problem regardless.
05-28-2006, 02:15 AM | #34 |
Member#: 110273
Yeah i was definately overreacting to your statement, you had me worried a bit. I was actually already talking to Dan about the different options for an intake since i'm not too fond of the one that comes in the Perrin one. We didn't get into detail, but Dan didn't mention the problem of the maf housing heating up and pulling timing, but i'm sure we will go over everything on Monday.
What i really wanted to do was have a cold air aluminum intake made so it fixes this heatsoak problem, but i had some unexpected bills come in recently so i have a pretty tight budget to work with now. If the cost is more than the Perrin intake i unfortunately won't be able to do this until a later date. Thanks again for all the great info, this has helped me raise a couple more questions that i will be asking Dan on Monday. BTW-2LTL2L8 I like the way you have your intake/maf housing setup. I was wondering how much did you pay to have this done? The Perrin intake is almost 400 so if it's less i'm hoping Dan can fab something like this up for me. Thanks for the pictures i really appreciate your help. Last edited by STimo; 05-28-2006 at 02:21 AM. |
05-28-2006, 07:21 AM | #35 | |
Member#: 78022
NWIC
Vehicle:PdxT built 2.5L 6sp 30R.82, 274/276, H2O+meth |
05-28-2006, 12:43 PM | #36 | ||
Member#: 60142
IOW, this problem, to the extent it exists, is likely to be far more predictable and repetitive in real-world scenarios (i.e., on the street). Last, I don't have the capacity to log otherwise I'd oblige you - but, again, it is simply unimportant to me since I have trouble putting 100% of the power to the wheels in 1st and 2nd gear even when it is hotter then hell outside and I've been sitting at a stop light. And in the winter, it's suicide. To someone who drag races, however, I totally understand the problem. |
05-28-2006, 05:41 PM | #37 |
Member#: 110273
I drop my car off tomorrow around noon so i'll find out some more details. I'm not sure how Dan has his dyno setup but i'm almost positive he has a fan or two blowing. He has a dynojet if that tells you anything about the load, but i don't know one thing about dyno's so i'll have to ask him tomorrow if his puts load on or not.
05-28-2006, 05:50 PM | #38 |
Member#: 19221
South East
Vehicle:2005 Legacy GT (STi) UR35R/Rotated Intake Mani |
You could just buy my Ultimate-Racing Rotated Mount CAI I have for sale.
I am running a Hydra so I have no need for it any longer. -Matt |
05-28-2006, 10:10 PM | #39 | |
Member#: 110273
05-29-2006, 05:37 PM | #40 |
Member#: 110273
I just dropped my car off at Harman a couple hours ago. I decided to just go with the Perrin intake for now and later i will get either a utec or accessport and do a blow-thru maf setup. I still don't know if i'm going to need a boost controller so i wanted to put aside some money for that because i think that is more important than what intake i go with. Hopefully i can scrape up enough money to go with an electronic boost controller but we'll see.
Dan said the car should be done by Friday so hopefully by the end of the week i will have some numbers. I should know by wednesday or thursday wether or not i will go with a boost controller. |
05-29-2006, 11:40 PM | #41 | |
Member#: 60142
Good luck - you've done your homework and you're gonna love it. |
05-29-2006, 11:51 PM | #42 |
Member#: 81102
South East
i heard that sz55 is horrible on pump gas....but you wouldn't have run pump anyway, but to mix like that all the time would be a p.i.a and expensive as hell...
05-30-2006, 12:14 AM | #43 |
Member#: 110273
^^ I just bought a drum (54gal) of VP ms109 (105 octane). I am only running 93 octane so i only have to mix 2 gallons of race gas for every 8 gallons of regular 91 octane. Honestly it isn't that big of a deal, right before i leave my house and go get gas i just toss 2 gallons of race gas in, go to the gas station and toss in another 8 gallons of regular gas. I think it will be worth it since it is easier to tune this way, is better for the car, and puts out a little bit more hp.
05-30-2006, 12:19 AM | #44 | |
Member#: 110273
As for the boost controller, i'm hoping that if i do end up going with one, i can work something out with Dan and pay like 3/4's of it now, and then after i sell my stock turbo and intercooler pay the other 1/4. I dunno we'll see. I will definately keep you guys updated though. |
05-30-2006, 12:59 AM | #45 |
Member#: 78022
NWIC
Good luck on your tune!
If you do get a UTEC, consider getting a 91 octane map so you can take your STi out of town more than half a tank away from home. Or you could get a pump + Torco map since Torco's concentrated and a lot easier to take with you than race. Meanwhile... you've got a nice set-up and I hope it delivers the performance you're looking for! |
05-30-2006, 01:35 AM | #46 | |
Member#: 60142
05-30-2006, 01:44 AM | #47 |
Member#: 110273
^My plan for now was to just run the 93 map and if i do a long car drive (farthest i go is vegas ) just use torco and not go into boost. I know this isn't the most ideal setup but i don't do long car drives really. Once i have enough money i'll get a Utec and do a 91oct tune and 105oct tune. I just don't really want to run 91oct because it is too crappy IMO.
Thanks for all the support from everyone too. I hope it is everything i expected and then some. |
05-30-2006, 02:21 AM | #48 | |
Member#: 105948
Vehicle:2005 wrx w/sti block Crystal Grey Metallic |
05-30-2006, 02:25 AM | #49 |
Member#: 110273
^also a good idea that i didn't even think of. I'm sure if i turned down the boost and didn't get on it much 91oct should be fine.
05-30-2006, 02:27 AM | #50 |
Member#: 105948
what do you think I do when i can't get to the 101oct station or another 93oct station and I have to use that so called 91oct crap,if it's even 91. I whip out the hex key and turn it down a few psi |
Agile built '08 Sti w/ rotated 30R | Agile Auto | Proven Power Bragging | 16 | 10-02-2009 03:01 PM |
FS: AZ - 2002/2005 WRX/STI - Full STI Swap with Rotated 30R | dcheyne55 | Private Vehicle 'For Sale' Classifieds | 9 | 05-20-2009 12:07 AM |
best rotated 30r kit? | Jkonquer | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 33 | 11-09-2006 11:40 AM |
Fp green or rotated 30r | Ctracer911 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 07-03-2006 12:25 PM |
Got my Perrin Rotated 30r kit(Pdxtuning Rocks) | 02WRX2.5 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 193 | 02-19-2006 10:07 PM |
