Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 05-24-2015, 07:27 AM   #176
livid_wrx
Member#: 399786
2002 02 wrx Saab 92x
Originally Posted by carruthers23 View Post
So if I purchase the IAPerformance AVCS wiring kit do I need to go through the hassle of adding wires and re-pinning the ECU on the JDM ECU?
Did you ever get this answered?
livid_wrx is offline   Reply With Quote
Old 05-24-2015, 08:15 AM   #177
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Originally Posted by AWDWRXLOVER View Post
There are links on romraider on how to change the NPS on the ecu but use caution because you can brick the ecu if you mess with the wrong line of code. My tuner said he would prefer for me to buy the right sensor.
^ this is good advice. IMO you actually have more risk with messing with the rom. JDM STi ECU's are fetching a premium now days and are not cheap if something should go wrong. Do the mechanical fix by getting the right NPS. You can swap it out with an open end wrench on the car. fwiw, i use an 02-03 wrx NPS on my JDM 6sp.
fastnoypi is offline   Reply With Quote
Old 05-24-2015, 10:37 AM   #178
subaruty37
Member#: 348543
Rihht on, Would I need a retune for active avcs?last time I tuned, the avcs werent working. But itwas only a 20 hp gain compared to
The tune before that when avcs was working
subaruty37 is offline   Reply With Quote
Old 05-24-2015, 02:38 PM   #179
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
Avcs will help spool turbo faster and give better throttle response. A retune is must IMO.
AWDWRXLOVER is offline   Reply With Quote
Old 05-24-2015, 02:46 PM   #180
subaruty37
Member#: 348543
But if I got my nps. And hooked it up. Then the avcs would work again. Would there be any bad effects on the motor? Just wondering becuase when I went from the 5 speed to the 6 speed (and lost the avcs) I really couldnt tell there was any difference. .. the car ran the same as far as I could tell
Old 05-24-2015, 02:50 PM   #181
subaruty37
Member#: 348543
I would love to retune with avcs... but itd the 400$ that gets me lol
Old 05-24-2015, 02:52 PM   #182
AWDWRXLOVER
Member#: 50267
02 built hybrid
I'm not saying the car won't run OK, just saying if your going through the trouble of getting avcs working wouldn't you want the car to be optimized? You probably couldnt tell because the difference in gearing between the 5 speed and 6 speed changes the whole feel of the car.
Old 05-24-2015, 02:53 PM   #183
AWDWRXLOVER
Member#: 50267
02 built hybrid
I would hope tuner wouldn't charge full price to touch up your map BTW...
Old 05-24-2015, 03:05 PM   #184
subaruty37
Member#: 348543
Yea... lat time I went and got a map touch up it was 400... and i thought it was bogus... I do see what youre saying about optimizing tge tune tho... I know i probably should go get tuned
Old 05-24-2015, 04:37 PM   #185
subaruty37
Member#: 348543
Could I just splice the two nps wires into each other ? So the car thinks its always in gear?
Old 05-24-2015, 10:04 PM   #186
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
nice job! following
Titter is offline   Reply With Quote
Old 05-24-2015, 10:07 PM   #187
livid_wrx
Member#: 399786
This thread hasn't been updated by some of the different op's in 2 years.
Old 05-27-2015, 03:33 PM   #188
mazdaboi
Member#: 281797
EVO Graphite Gray
this looks like the OP's car EJ207 Swap
mazdaboi is offline   Reply With Quote
Old 08-13-2015, 10:46 AM   #189
Maly1906
Member#: 81955
Maly1906 is offline   Reply With Quote
Old 08-13-2015, 04:46 PM   #190
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Yimisport reversed the polarity of the NPS in the ROM for my EJ207 swap. It's easy if your tuner knows what he is doing.
Fierysun is offline   Reply With Quote
Old 04-18-2017, 07:58 PM   #191
S1mmo
Member#: 466277
2001 SF5 Forester
01G Silver
Originally Posted by Hawken View Post
OK, another question for the experienced...
Everythings running sweet. I've modified the splitter so all the intercooler gets air, sorted the exhaust, got the aircon working etc. I'm happy withe the power increase but It's always nice to get a little more.
So now It's time to start fiddling.
The only problem is I can't get the ECU to go into programing mode.
I've connected the 2 green plugs and shorted the 2 pins of the white plug under the dash but the fans don't cycle and my Tactrix cable wont download the ROM.
I can get logging data fine and the cable itself will log, so it's not a problem there.
Are there any other wiring changes that need to be made?
Did you ever get this sorted out?
I am having the same problem, RomRaider will talk to the ecu but ECUFlash wont, and it wont go into test mode with or with out the white plug jumpered and the green plugs connected.
S1mmo is offline   Reply With Quote
Old 04-19-2017, 04:02 AM   #192
Hawken
Member#: 316735
2000 WRX with EJ207
Dark blue
Unfortunately I didn't sort this out. Got sidetracked on other projects.
Hawken is offline   Reply With Quote
Old 05-18-2017, 08:17 PM   #193
APriestOfGix
Member#: 280305
2003 JDM v9 STi WRX
Are you just trying to do a RomRaider Tune?
APriestOfGix is offline   Reply With Quote
Old 05-18-2017, 08:42 PM   #194
S1mmo
Member#: 466277
2001 SF5 Forester
01G Silver
I sorted my issue out, it turns out that I had pinned the test connector into the wrong pin...once I moved it all was fine. I can flash it with ECU Flash now.
Old 12-02-2017, 12:53 PM   #195
Arguss
Member#: 474032
03 wrx wagon vf48
have a bug eye and want to eventually do the 207 swap.
posting to find this later.
cheers
Arguss is offline   Reply With Quote
Old 12-08-2017, 07:27 AM   #196
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
although I'm in this thread already, I think this author has a detailed write up about idlers and want to find this for my soon to come second timing belt replacement.
Old 06-06-2018, 04:28 PM   #197
ssotelo11
Member#: 373870
02 wrx
blue
Default Help
so i am doing the same swap but my car anit getting no power idle with no power seems like wants to die.after i hook up the computer got any suggeugestions i got a jdm ecu has (v 8) on it,factory wiring harness and jdm block (eg207)?does the ecu have to be usdm
ssotelo11 is offline   Reply With Quote
Old 06-06-2018, 05:09 PM   #198
ssotelo11
Member#: 373870
02 wrx
blue
rapa is the ecu (V 8) you have listed a jdm ecu or a australian?
Old 06-24-2018, 02:10 PM   #199
02mbp
Member#: 195047
2002 wrx
midnight black pearl
Subscribed for future reading. Thank you
02mbp is offline   Reply With Quote
2005 STI into 2002 Bugeye Swap psychorunner Subaru Conversions 20 03-08-2012 08:28 PM
My STI swap into 02 Bugeye Tweeder Member's Car Gallery 19 06-04-2011 03:13 AM
JDM V7 ej207 into my 05 WRX CamTunedSti Built Motor Discussion 6 11-10-2010 04:40 PM
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi STepeci Subaru Conversions 8 09-18-2009 07:26 PM
dash/interior swaps into 02 bugeye? ricky05 Interior & Exterior Modification 4 01-25-2007 04:03 AM
